provo a richiedere, ho salvato solo il documento di testo.poi purtroppo il pd.f era realizzato dal conoscente per comodità sua infatti non vi erano le immagini che venivano indicate nel testo ,i cui riferimenti a queste ultime io ho tolto dal tutto
Ultima modifica di simonepietro; 10-01-2006 alle 01:07
specifiche tecniche complete del 2000 ecotec supercharger dgi e ci sono alcune novità. doppi variatori di fase e produzione in u.s.a. Ho l'impressione che ritroveremo parecchie soluzioni di questa unita GM sul probabile 2.200 jts turbo destinato alle alfa romeo
NEW ECOTEC 2.0-LITER DIRECT INJECTION TURBO ENGINE
Advanced Combustion Technology Improves Power and Efficiency in
the 2007 Pontiac Solstice GXP
PONTIAC , Mich. – General Motors introduces the Ecotec 2.0-liter Turbo
engine in the 2007 Pontiac Solstice GXP, making it GM’s first direct injection
offering in North America . Gasoline direct injection technology helps the
Ecotec engine produce more power while maintaining the lower fuel
consumption of a small displacement port-injected engine. It produces 260
horsepower (194 kW) and 260 lb.-ft. of torque (353 Nm),* making it GM’s
highest specific output engine ever, at 2.1 horsepower per cubic inch of
displacement (130 hp / 97 kW per liter), and the most powerful production
engine in the Ecotec family.
Variable valve timing and an intercooled, twin-scroll turbocharging system are
used to optimize the Ecotec 2.0-liter Turbo engine’s performance. It was
developed with the global resources of GM Powertrain in the United States
and Europe , drawing on expertise from the naturally aspirated Ecotec 2.2-liter
direct injection engine used in some European applications and the 2.0-liter
turbocharged engines already in production.
With direct injection, fuel is delivered directly to the combustion chamber to
create a more complete burn of the air/fuel mixture. Less fuel is required to
produce the equivalent horsepower, especially at normal cruising speeds, of a
conventional port-injection combustion system.
“Direct injection technology works well with turbocharging and helps deliver a
great balance of power and economy,” said Ed Groff, assistant chief engineer,
Ecotec 2.0-liter Turbo engine. “The Ecotec 2.0-liter Turbo produces the power
expected of a V-6, but in a smaller, more efficient package – and the driving
response is simply terrific.”
A dual-scroll turbocharger with a lightweight turbine provides nearly instant
power and an air-to-air intercooling system bolsters the turbo’s performance
by reducing inlet temperatures. Dual cam phasing complements the
turbocharging system by optimizing valve timing at lower rpm for best turbo
response and quick engine torque build-up time.
The Ecotec 2.0-liter Turbo uses a stronger, “Gen II” Ecotec engine block,
which was developed with input from racing experience to support increased
horsepower and torque. The cylinder block bulkheads – the areas where the
main bearing caps are attached – and the bore walls are enlarged for
strength. Other areas of the engine were enhanced to reinforce the structure
and the water jacket is deeper for added cooling capacity and improved
cylinder bore roundness. This architecture is shared with the 2.4-liter Ecotec
engine that debuted in the Pontiac Solstice roadster.
Highlights of the Ecotec 2.0-liter Turbo engine include:
• Steel crankshaft
• Forged connecting rods
• Forged oil-galley pistons
• Jet-spray piston cooling
• 9.2:1 compression ratio
• Aluminum cylinder head with sodium-filled exhaust valves
• High-pressure engine-driven fuel pump
• Variable pressure fuel rail
• Dual-scroll turbocharger
Components including the steel crankshaft, forged connecting rods and
forged pistons are high-strength items that provide strength and enhance
durability. Jet-spray oil cooling directed toward an oil-galley piston help reduce
piston temperatures. The system delivers pressurized oil to continuously
lubricate and cool the pistons, which reduces friction and noise and ensures
durability for the engine’s higher power levels. To enhance combustion, the
piston tops feature a dish shape that deflects injected fuel toward the spark
plugs.
To accommodate the direct injection system, the Ecotec 2.0-liter Turbo has a
unique cylinder head and intake manifold. The cylinder head incorporates
mounting locations for the fuel injectors – which are typically mounted in the
intake ports or intake manifold on port injection engines. A high-pressure fuel
pump delivers fuel to a variable-pressure fuel rail. Fuel enters the combustion
chamber through precision multi-hole fuel injectors. The fuel pump, fuel rail
pressure, fuel injection timing, and injection duration are controlled by the
engine control module. In this way, fuel is metered and delivered in a finely
atomized spray.
Apart from the mounting positions of the fuel injectors, the cylinder head has
conventional port and combustion chamber designs, although both are
optimized for direct injection and high boost pressures. The sodium-filled
exhaust valves and stainless steel exhaust manifold are durable components
designed to stand up to the high-performance capability of the engine.
The unique cylinder head, fuel system, pistons, intake manifold, and the dualscroll
turbocharger are the only major components that differentiate the 2.0-
liter Turbo from other members of the Ecotec engine family. Mobil 1 synthetic
engine oil is installed at the factory. Synthetic oil was selected for its frictionreducing
capabilities and high-temperature performance.
How direct injection works
Gasoline direct injection differs from the fuel delivery process of a
conventional engine by delivering fuel directly into the combustion chamber,
where it is mixed with air drawn in to the chamber. The combustion process of
conventional fuel injected engines uses air and fuel that are mixed in the
intake port or intake manifold prior to being introduced into the combustion
chamber. Direct injection is a continuation of the evolutionary process of
moving the fuel introduction point closer to the combustion location to improve
control.
With the Ecotec 2.0-liter Turbo, fuel is introduced directly to the combustion
chamber during the intake stroke. As the piston approaches top-dead center,
the mixture is ignited by the spark plug, giving the name spark ignition direct
injection (SIDI). The fuel injectors are located beneath the intake ports. SIDI
allows the mixture to be “leaner” – less fuel, more air – at full power. SIDI also
permits a slightly higher compression ratio than if the fuel were delivered with
conventional fuel injection. The result is better fuel consumption at part and
full throttle. The engine uses conventional spark plugs similar to other Ecotec
engines.
A high-pressure, returnless fuel system is employed. It features a highstrength
stainless steel fuel line that feeds a variable-pressure fuel rail. Direct
injection requires higher fuel pressure than conventional fuel injected engines
and an engine-driven high-pressure fuel pump is used to supply up to 1,276
psi (150 bar) of pressure. The system regulates lower fuel pressure at idle –
approximately 752 psi (50 bar) and higher pressure at wide-open throttle. The
cam-driven high-pressure pumps works in conjunction with a conventional fuel
tank-mounted supply pump.
Direct injection’s precise fuel delivery enables more complete combustion to
help reduce emissions, particularly on cold starts – the time when most
engine emissions are typically created. Also, direct injection permits higher a
compression ratio in the engine which is a positive influence on fuel economy.
At certain power levels, the boosted SIDI engine can provide significant fuel
economy benefits to the vehicle compared to a larger displacement naturally
aspirated engine.
Turbocharging system
A unique, dual-scroll turbocharger is partnered with an air-to-air intercooling
system to provide up to approximately 20 psi (1.25 bar) of power-enhancing
boost. The dual-scroll turbocharger delivers nearly instant response, as dual
exhaust passages from the engine to the turbine housing guide exhaust gas
to the turbine. This reduces lag time, or spool-up, at low rpm.
“There is virtually no lag with this system,” said Groff. “Throttle response is
immediate. The engine acts like a larger displacement engine.”
The turbocharger is matched to the engine’s displacement and performance
objectives. It is supported by the air-to-air intercooling system, which uses
fresh air drawn through a heat exchanger to reduce the temperature of the
warmer compressed air forced through the intake system by the turbocharger.
Inlet temperature is reduced by approximately 212 degrees (100 degrees C),
enhancing performance because cooler air is denser and promotes optimal
combustion.
Dual cam phasing
The camshafts of the Ecotec 2.0-liter Turbo engine have phasers that support
the continuously variable intake and exhaust valve timing. They also have
cam position sensors, so that the engine control module can accurately
control valve timing. The crankshaft and camshaft position sensors are digital.
A new engine controller, specific to the engine, is used to sense and control
the engine’s performance parameters.
Variable intake and exhaust timing works synergistically with both the
gasoline direct injection and turbocharging systems. The variable engine
timing enabled by cam phasing allows the combustion process to be
optimized. Also, valve “overlap” at low rpm can be adjusted by the controller
to increase the response of the turbocharger, providing a more immediate
feeling of power.
Ecotec family traits
The Ecotec 2.0-liter Turbo is built on a global platform that was designed at
the outset for a range of performance and combustion capabilities. The Gen II
block supports the high-performance demands of the engine, but it is merely a
strengthened version of the original Ecotec architecture. The oil pump, for
example, is the same as used in all other Ecotec engines. It was originally
designed to support high-performance applications of future engines.
“The 2.0-liter Turbo is the pinnacle of Ecotec performance to date, with
additional growth planned. The groundwork for its capabilities was layed on
the drawing table at the very beginning of the Ecotec’s development,” said
Groff. “Prior work and a far-thinking engine design continue to help GM
respond to market demands around the globe more quickly and with greater
accuracy.”
This new Ecotec family member also has traits that have helped forge a
reputation for durability and sophistication:
• Dual overhead camshafts (DOHC) and four valves per cylinder
• Twin counter-rotating balance shafts for operational smoothness
• Electronic throttle control
• Low-friction, roller-finger follower valvetrain with hydraulic lash
adjusters
• Low-maintenance chain-drive for the camshafts
• 58X crankshaft positioning
• Direct-mount accessories, which reduce or eliminate traditional sources
of noise and vibration
• Full-circle transmission mount to reduce noise and vibration
• GM Oil Life System, which can reduce the frequency for oil changes
• Innovative cast-in oil filter housing, which eliminates the need to crawl
under the vehicle to perform oil changes and eliminates throwaway oil
filter cans that retain used oil
As with other engines in the Ecotec family, the 2.0-liter Turbo engine also has
premium features designed to ensure smooth and quiet operation, including a
polymer coating and skirt design for the pistons that reduces noise during cold
starts. An automatic hydraulic tensioner also is used to maintain optimal
tension on the timing chain, which reduces noise and vibration.
General Motors Corp. (NYSE: GM), the world’s largest automaker, has been
the global industry sales leader since 1931. Founded in 1908, GM today
employs about 325,000 people around the world. It has manufacturing
operations in 32 countries and its vehicles are sold in 200 countries . In 2004,
GM sold nearly 9 million cars and trucks globally, up 4 percent and the
second-highest total in the company’s history. GM’s global headquarters are
at the GM Renaissance Center in Detroit .
GM was the first auto manufacturer to
begin using the procedure and expects to use it for all newly rated engines in
the future.
Ecotec 2.0-liter Turbo Specifications
Assembly site: Spring Hill , Tenn.
Application: 2007 Pontiac Solstice GXP
Type: 2.0-liter DOHC turbocharged I4
Displacement
(cu in/ cc):
122 / 1998
Bore x stroke
(in x mm):
3.38 x 3.38 / 86 x 86
Block material: 319 aluminum
Cylinder head material: 356 T6 aluminum
Intake manifold: cast aluminum
Exhaust manifolds: cast stainless steel
Compression ratio: 9.2:1
Valve configuration: overhead cam; four valves per cylinder
Valve lifters: hydraulic lash adjuster, roller finger follower
Firing order: 1-3-4-2
Fuel system:
Gasoline high-pressure, variable-rail pressure, spark
ignition direct injection (SIDI)
Horsepower
(hp / kW):
260 / 194 @ 5300 rpm (SAE certification pending.)*
Torque (lb.-ft. / Nm):
260 / 353 @ 2000 – 5300 rpm (SAE certification
pending.)*
Fuel shut off: 6300 rpm
Crankshaft: forged steel
Connecting rods: forged steel
Ultima modifica di simonepietro; 11-01-2006 alle 05:28
