+ Rispondi alla Discussione
Risultati da 1 a 1 di 1
Discussione: MG6 - Prima prova
    Leader del campionato
    Aug 2008
    1.379
    Predefinito MG6 - Prima prova
    Autocar prova la nuova MG6 (Roewe 75 in Cina)...progettata quasi integralmente in Inghilterra e prodotta a Birmingham, pur essendo un esemplare di pre-produzione, pare avere già un comportamento dinamico da prima della classe...
    The MG6 will go on sale in the UK next year, and Autocar's chief road tester Matt Prior has had an exclusive drive of the Longbridge-developed car.Contrary to what many people think, the MG6 - or Roewe 75 as it’s called in China - is a clean sheet design, and not based on a shortened Rover 75 platform.
    The Roewe variant went on sale in China last year, and has already sold 100,000 units. The MG6 will be on sale in the UK from the start of 2011, with final assembly taking place at Longbridge.
    The good news is that not only was the 6 largely engineered in the UK, but it will also be sold here on a Europe-exclusive chassis set-up, honed and tweaked on the roads we tested it on. As a benchmark, we took a Ford Focus Zetec S along on the same route.
    The roads are in and around mid-Wales, and are some of the most challenging and demanding in the world. If a car works here, it'll work pretty much anywhere.
    Climbing aboard, there's a shock. The 6's cabin may be a belter by Chinese standards, but it's not on a par with better European cars. There are soft-touch plastics and a dark ambience, but it's a bit austere and the design looks flat in places. It's a pre-production model, but it could use finessing by a few notches.
    Moving off, I reckon the gearchange on the five-speed manual and NVH levels could (and I believe will) be improved too.
    The only engine at launch is a 1.8-litre turbocharged petrol, though diesels and other petrols will follow. It's a reworked K-series and - although it meets Euro5 emissions levels - accelerating away from a couple of roundabouts as we head west, it gets a little strained higher up the rev band.
    What the MG6 does do, though, is drive well. And I mean really well. MG's head of chassis, Andy Kitson, admits the Focus has been the firm's benchmark for ride and handling. The MG6 has a rare blend of suppleness and poise.
    The steering is still hydraulic rather than electric, and apparently it's slower than the Focus's, but it doesn't feel it. Kitson says there's still a little work to do on the valves to alter the feel at straight ahead but it's not bad now. And once there's a little lock wound on, it's excellent.
    Then there's the ride. Hopping to and from a Focus reveals that the Ford's cabin suffers less vertical intrusion over bumps, but it's obvious this is the car MG has benchmarked. In its poise and agility I'd even say the MG6 is superior. It feels more neutral than the Focus, with a pivot point further forward; the Ford in comparison feels led more by its front.
    The MG grips tenaciously before eventually letting slip from the front first, and it changes direction superbly. It is comfortable, tool greater vertical inputs into the cabin aside, there's no crash, even over bad bumps.
    Fact is, the MG6 is already (and there's still tweaking to do) borderline best in class to drive.
    Is that enough? Probably not on its own. But it's also spacious and expected to be priced competitively.
    If all goes well there's scope for up to 150,000 vehicles per year to be assembled out of MG Birmingham, even in its current size.
    http://www.autocar.co.uk/News/NewsAr...or-MG6/248727/
    Ultima modifica di wilderness; 09-04-2010 alle 14:18
  1. prova
    Di TEST nel forum Off Topics
    Risposte: 0
  2. prova..
    Di magg nel forum Off Topics
    Risposte: 1
  3. Prima prova punto 1.3mjtd
    Di dunnet nel forum Fiat
    Risposte: 8
focus zetec s diffusion
mg 6 launch
prova NVH
algérie forum automobile MG6
prova prima china
