2 makkine che hanno fatto sognare personalmente credo che siano bellissime!!
per una 037 stradale dell'82 con 10.000 km ci vogliono 85.000 euro
la S4 nn so quanto costi ma credo molto anke piu' della 037
Engine
No. cylinder
4 in line
CC (x1.4 if turbocharged)
1759 (2462)
Bore / Stroke (mm)
88.5 / 71.5
Comp. Ratio
7,0:1
Max.Power (bhp)
450
Revs.
8000
Max.Torque (kg/m)
46
Revs.
5000
Induction
Weber-Magneti Marelli
Turbo
KKK+Roots compressor
No. Valves
16
No. + Position Cams
2 Overhead Camshaft
Location
Mid-Longitudinal
Transmission
Location
4WD
Differential (Front-Central-Rear)
Clutch (Manufacturer)
2 plate
Gearbox (Manufacturer)
5 speed
Brakes
Front
DV300
Rear
DV300
Suspension (shock absorbers)
Front
Wishbone+Coil
Rear
Wishbone+Coil
Dimensions
Length (mm)
3990
Widht (mm)
1880
Height (mm)
1360
Wheelbase (mm)
2440
Front track (mm)
1510
Rear track (mm)
1535
Weight (kg)
890
Date 1st Homologation (number)
1.11.1985 (B276)
1st Major Rally
1000 Pistes 1985
1st WRC Event
RAC 1985
WRC Wins (5)
RAC 1985 (Toivonen)
Monte Carlo 1986 (Toivonen)
Argentina 1986 (Biasion)
Italy 1986 (Alen)
USA 1986 (Alen)
LinkBack URL
About LinkBacks
Rispondi Citando
