Risultati da 1 a 9 di 9
Discussione: [USA] Chevrolet Equinox (Topic Ufficiale)
    HYBRID Team Member L'avatar di Touareg 2.0
    Dec 2003
    Palermo
    26.271
    Discussione Ufficiale o Indicizzata nella lista dei ''TOPIC già APERTI'' [USA] Chevrolet Equinox (Topic Ufficiale)
    Now when the federal government has approved a $13.4 billion low interest loan to General Motors and Chrysler, it is obvious that they will last through the first months of 2009.
    That also means GM will attend the Detroit Motor Show and show us new models and perhaps even concepts. Currently there is a rumor that GM will unveil a Volt based Cadillac.
    When it comes to new models, then the first one GM has revealed details about, is the second-generation Chevy Equinox. For 2010 this little CUV gets a complete redesign from inside-out.
    What’s most important in addition to the new design is better fuel-economy thanks to new direct injected engines.
    First one is the 2.4-liter direct injected I-4 with 182 hp that delivers estimated 30 mpg highway and 21 mpg city(old engine fuel economy was 24/17). Second in is the 3.0-liter DOHC direct injected V-& engine with 255 hp, which delivers an estimated 30 mpg on highway and 21 mpg in the city.
    2010 Equinox is available with either all-wheel or front wheel-drive. New Equinox makes its first public debut in Detroit next month, sales will start in mid 2009. For specific details take a look at the full press release below.
    Globalmotors
    autoblog.com
    -----> Altre Foto Live <-----
    il video.
    The media you are looking for does not exist! Please try again.
    Non vi ho messo la press release perchè è molto lunga..
    Comunque, non male anche se davanti non mi fa impazzire, lo trovo molto piu riuscito di quello che va a sostituire (foto sotto).
    Topic Spies : [USA] Chevrolet Equinox (Spy)
    Ultima modifica di J-Gian; 08-06-2009 alle 21:13
    News Aggiornate al 23/05/2012 : Lamborghini (Tutta la Gamma) .
    HALL OF FAME L'avatar di Arcy79
    Aug 2006
    Provincia di Napoli
    8.386
    Predefinito Re: [USA] Chevrolet Equinox (Foto Ufficiali)
    alla fine niente male anche se in fiancata mi ricorda il Kia Sorento
    Team Manager L'avatar di JOKEJOE
    Sep 2004
    Firenze
    4.900
    Il frontale anche se e' sempre la solita zolfa...(Grande mascherone con fanali scalinati) si lascia guardare.
    Il posteriore e' veramente tirato via....ANTICO..!!
    Ancora un bel cruscotto su ultimi modelli GM...
  4. #4
    Feb 2004
    lucca. italia
    8.114
    Partendo dai già anticipati propulsori, ultime versioni per gli USA della famiglia ECOTEC II e v6 HF,dimensioni e pesi, trasmissione e schema sospensioni.
    Type:
    2.4L DOHC I-4 DI
    3.0L DOHC V-6 DI
    Displacement (cu in / cc):
    145 / 2384
    182 / 2994
    Bore & stroke (in / mm):
    3.46 x 3.85 / 88 x 98
    3.50 x 3.15 / 89 x 80.2
    Block material:
    cast aluminum
    sand-cast aluminum with cast-in bore liners
    Cylinder head material:
    cast aluminum
    cast aluminum
    Valvetrain:
    DOHC, four valves per cylinder; variable valve timing
    Fuel delivery:
    electronic direct sequential fuel injection with electronic throttle control
    Compression ratio:
    11.7:1
    11.7:1
    Horsepower
    (hp / kW @ rpm):
    182 / 135 @ 6700
    255 / 190 @ 6500
    Torque (lb-ft / Nm @ rpm):
    174 / 235 @ 4800
    214 / 290 @ 5600
    Recommended fuel:
    regular unleaded
    regular unleaded
    Emissions controls:
    close-coupled catalytic converters; Quick-Sync 24x ignition system; returnless fuel rail; fast-response O2 sensor
    Estimated fuel economy
    (city / hwy):
    21 / 30 (FWD)
    20 / 27 (AWD)
    18 / 25 (FWD)
    17 / 24 (AWD)
    Transmission
    Type:
    Hydra-matic 6T45 six-speed automatic electronically controlled
    Hydra-matic 6T70 six-speed automatic electronically controlled with manual shift mode
    Gear ratios: (:1):
    First:
    4.58
    4.48
    Second:
    2.96
    2.87
    Third:
    1.91
    1.84
    Fourth:
    1.44
    1.41
    Fifth:
    1.00
    1.00
    Sixth:
    0.74
    0.74
    Reverse:
    2.94
    2.88
    Final drive ratio:
    3.23 (FWD)
    3.53 (AWD)
    2.77
    Chassis/Suspension
    Front:
    independent strut-type with tuned coil springs; direct-acting stabilizer bar; hydraulic ride bushings
    Rear:
    independent four-link with coil springs and trailing arm; stabilizer bar; hydraulic link bushings
    Steering type:
    rack-mounted electric power steering with 2.4L; hydraulic power rack-and-pinion with 3.0L
    Steering ratio:
    18.1:1 (2.4L)
    17.4:1 (3.0L)
    Steering wheel turns, lock-to-lock:
    3.46 (2.4L)
    2.90 (3.0L with 18-inch wheels)
    2.80 (3.0L with 19-inch wheels)
    Turning circle, curb-to-curb
    (ft / m):
    40 / 12.2 (with 17- and 18-inch wheels)
    42.6 / 13 (with 19-inch wheels
    Brakes
    Type:
    power front and rear vented discs, standard anti-lock brakes
    Rotor diameter x thickness
    (in / mm):
    front: 12.6 x 1.18 / 321 x 30
    rear: 11.9 x 0.78 / 303 x 20
    Total swept area (cu in / mm):
    front: 20.7 / 526
    rear: 15.3 / 390
    Wheels/Tires
    Wheel size and type:
    17-inch aluminum (std. with 2.4L)
    18-inch aluminum (std. with 3.0L)
    19-inch aluminum (opt. with 3.0L)
    Tires:
    P225/65R17 all-season steel-belted radial blackwall tires
    P235/55R18 all-season steel-belted radial blackwall tires
    P235/55R19 all-season steel-belted radial blackwall tires
    Dimensions
    Exterior
    Wheelbase (in / mm):
    112.5 / 2857
    Overall length (in / mm):
    187.8 / 4771
    Overall width (in / mm):
    72.5 / 1842
    Overall height (in / mm):
    66.3 / 1684
    Track (in / mm):
    front: 62.5 / 1587
    rear: 61.8 / 1570
    Approach angle (deg):
    14.8
    Departure angle (deg):
    23.2
    Breakover ramp angle (deg):
    16.5
    Minimum ground clearance
    (in / mm):
    7.8 / 198.5
    Ground to rear load floor
    (in / mm):
    28.8 / 731.2
    Curb weight, base (lb / kg):
    3770 / 1710
    Weight distribution (front / rear):
    58 / 42
    Interior
    Seating capacity:
    5
    Headroom (in / mm):
    front: 39.8 / 1012
    rear: 39.2 / 995
    Legroom (in / mm):
    front: 41.2 / 1046
    rear: 37.2 / 946
    Shoulder room (in / mm):
    front: 55.8 / 1418
    rear: 55.3 / 1405
    Hip room (in / mm):
    front: 55.1 / 1399
    rear: 51.3 / 1304
    Capacities
    EPA interior volume (cu ft / L):
    130.5 / 3695
    Passenger volume (cu ft / L):
    99.7 / 2822
    Cargo volume (cu ft / L):
    Maximum behind rear seat:
    Maximum behind front seat:
    31.4 / 889
    63.7 / 1803
    GVWR, standard (lb / kg):
    4960 / 2250
    Payload, base (lb / kg):
    1190 / 540
    Trailer towing maximum (lb / kg):
    1500 / 680 (2.4L)
    3500 / 1588 (3.0L)
    Fuel tank (gal / L):
    18.8 / 71.1 (2.4L)
    20.9 / 79.1 (3.0L)
    Engine oil (qt / L):
    5 / 4.7 (2.4L)
    6 / 5.7 (3.0L)
    Cooling system (qt / L):
    8.9 / 8.5 (2.4L)
    10 / 9.5 (3.0L)
    *Pending SAE certification.
    Ultima modifica di simonepietro; 21-12-2008 alle 16:15
  5. #5
    Apr 2004
    Treviso
    28.566
    Bell'abitacolo e nel complesso meglio di quello che va a sostituire.
    Devo dire che le ultime Chevi stanno riuscendo molto bene...
  6. #6
    Apr 2004
    Treviso
    28.566
    Ma in pratica questa è quella che doveva fare pure la Saab?
    Anche gl'interni hanno un che, pur essendo coerenti con i recenti modelli Chevrolet...
  7. #7
    Dec 2003
    Palermo
    26.271
    Se intendi la 9.4x , beh la faranno ancora ma è stata soltanto posticipata.
  8. #8
    Apr 2004
    Treviso
    28.566
    Citazione Originariamente Scritto da Touareg Visualizza Messaggio
    Esatto, o anche la Caddy SRX
  9. #9
    j
    j non è collegato
    HALL OF FAME L'avatar di j
    Mar 2004
    11.411
    BYE BYE!
  1. Chevrolet Spark (Topic Ufficiale)
    Di Regazzoni nel forum Chevrolet Europe
    Risposte: 49
  2. [USA] Chevrolet Equinox (Spy)
    Di Touareg 2.0 nel forum Rumors & Spies
    Risposte: 10
  3. Chevrolet Captiva (Topic Ufficiale - 2005)
    Di Giovanni B. nel forum Chevrolet Europe
    Risposte: 30
  4. Chevrolet Matiz Facelift (Topic Ufficiale - 2006)
    Di j nel forum Concept & Anteprime
    Risposte: 9
  5. Chevrolet Lacetti (Topic Ufficiale - 2006)
    Di Coaster nel forum Chevrolet Europe
    Risposte: 1
Chevrolet Equinox
1chevrolet equinox italiachevrolet equinox in italiaEquinox Chevroletchevrolet equinoxechevroletchevrolet equinox fotochevrolet usachevrolet equinox dimensionichevy equinoxchevrolet equinox 2011chevrolet equinox immaginiequinoxdimensioni chevrolet equinoxwww.chevrolet.cominterni chevrolet captiva 2011chevrolet equinox 201052chevrolet equinox 20067usa chevrolet14foto di chevrolet equinox
Tag per Questa Discussione
