Pagina 1 di 3 123 UltimaUltima
Risultati da 1 a 10 di 25
Discussione: Volvo C30 Efficiency Concept (Foto Ufficiali)
    HYBRID Team Member L'avatar di Touareg 2.0
    Dec 2003
    Palermo
    26.276
    Predefinito Volvo C30 Efficiency Concept (Foto Ufficiali)
    Volvo has joined the "sub-120g/km CO2"-club with its C30 Efficiency, which it will premiere on September 11 in Frankfurt. So what's been modified this time? For starters, Volvo has made changes to the aerodynamics and the rolling resistance of the C30. Coupled with a higher gearing and an improved powertrain efficiency Volvo has improved fuel consumption of the 105 bhp 1.6-litre turbodiesel engine to 62.8 mpg (57.6 mpg in the current C30). The aerodynamic modifications include a reduced chassis height, a new rear roof spoiler, a new rear bumper, underbody panels, optimised engine cooling and optimised 16-inch wheels.
    The C30 Efficiency is Volvo's first model to obtain a B-band VED tax rating, and given that the proposed changes to the London Congestion Charge scheme go ahead in 2008, the C30 Efficiency will be exempt from the charge.
    In 2008, Volvo will launch a new diesel Powershift transmission in its C30, S40 and V50 model ranges. As stated in Volvo's press release, "the Powershift gearbox consists of two clutches that work in parallel and, since there is no disruption in torque delivery during the gearchanging process, gearshifts are instantaneous and the fuel efficiency rating is higher, delivering improved fuel consumption compared to a standard automatic gearbox."
    autoweek.nl e testo wcf
    Ultima modifica di Touareg 2.0; 20-08-2007 alle 14:01
    News Aggiornate al 23/05/2012 : Lamborghini (Tutta la Gamma) .
    Pilota Ufficiale L'avatar di Alby
    Jun 2007
    Motor land
    903
    Predefinito Re: Volvo C30 Efficiency Concept (Foto Ufficiali)
    A quanto mi pare di vedere la C30 già non vende molto... Non credo che questa versione ecologica possa aumentarne l'interesse.
    Secondo me le varie carenature avrebbero dovuto essere previste nella versione normale (ovviamente integrate nelle forme), e non aggiunte alla bene e meglio. Farà la fine della Lupo 3L.
    Idea interessante comunque.
    May 2005
    MI+BG
    40.025
    Con le ruotine e il finto estrattore plasticoso assume purtroppo un aspetto piuttosto deprimente.
    o chi lo sa...
  4. #4
    Pilota Ufficiale L'avatar di El Matador
    Oct 2006
    Prov. Pisa
    947
    Scusate... cosa sarebbe quella specie di griglia dentro i cerchi?
  5. #5
    Apr 2004
    Treviso
    28.568
    Citazione Originariamente Scritto da El Matador
    Penso serva a ridurre la turbolenza dell'aria, migliorando quindi l'aerodinamica.
  6. #6
    Feb 2004
    lucca. italia
    8.114
    purtroppo ho aggiornato in ritardo una mia vecchia discussione senza notare questa simile . Ripropongo l'immagine del compatto cambio a doppia frizione per il gruppo FORD che credo sia della famiglia con le frizioni a secco
    URL=http://imageshack.us][/URL]
    Ultima modifica di simonepietro; 20-08-2007 alle 15:27
  7. #7
    Oct 2006
    Prov. Pisa
    947
    Citazione Originariamente Scritto da J-Gian
    Lo stesso concetto dei cerchi "pieni" della Ferrari di Formula1?
  8. #8
    HALL OF FAME L'avatar di SaiKiSono
    Sep 2006
    nel mio mondo
    6.747
    da come mi avete fatto capire anche sembra qualcosa di simile ai cerchi "pieni" ferrari come concetto....
    Bannate SAIKISONO!!!
  9. #9
    Oct 2006
    Prov. Pisa
    947
    Appunto...
  10. #10
    World Championship Winner L'avatar di ISO-8707
    Aug 2006
    Cuneo
    2.503
    Avrebbero potuto inclinare un po' il frontale (è un muro)... vedeste quanti insetti si spiaccicano anche solo dopo 50km...
  1. Volvo V60 (Topic Ufficiale)
    Di Touareg 2.0 nel forum Volvo
    Risposte: 112
  2. [IMPRESSIONI DI GUIDA] Volvo C30 Electric (Foto Ufficiali e Prova)
    Di J-Gian nel forum Prove e Recensioni Auto
    Risposte: 3
  3. Volvo C30 Performance Concept Polestar (Foto Ufficiali)
    Di Beckervdo nel forum Concept & Anteprime
    Risposte: 12
  4. Volvo S60 Concept (Foto Ufficiali - Galleria a pag. 4)
    Di j nel forum Concept & Anteprime
    Risposte: 74
  5. Volvo S80 Foto Ufficiali
    Di JOKEJOE nel forum Concept & Anteprime
    Risposte: 5
aerodynamic volvo c30
estrattore aria volvo c30
estrattore volov c30
estrattore posteriore efficency c30
estrattore per volvo c30
volvo c30 efficiency
