Ciao e benvenuto nella nostra comunità! Questa è la tua prima visita?
Registrazione
Risultati da 1 a 10 di 10
    HYBRID Team Member L'avatar di Touareg 2.0
    Dec 2003
    Palermo
    29,617
    [USA] Subaru Impreza WRX/GT 2009 (Foto Ufficiali)
    The 2009 Subaru Impreza WRX has had its internals and exterior tinkered with resulting in a performance upgrade from its predecessor. A 265hp (198kW) turbocharged intercooled boxer engine provides the grunt, while a retuned suspension system and wider, lower-profile summer performance tires improve the handling and ride.
    The engine is fitted with a larger turbocharger than the 2008 model, leading to increased boost. Coupled with a low-density catalyst for reduced exhaust backpressure, the WRX engine now produces 41hp (31kW) more than its predecessor and increases torque by 20lb-ft (27Nm), up to 244lb-ft (330Nm).
    The suspension has been improved by increasing spring rates and adding thicker stabilizer bars, and the summer tires are a departure from the all-season tires that used to adorn the WRX. The 2009 Impreza WRX also gets a 5-speed manual transmission, AWD, and an ‘Incline Start Assistant’ that stops the car rolling back when taking off.
    The Impreza WRX moves closer to the high-performance STI, picking up the same grille, integrated front spoiler, body-side moldings and gunmetal gray alloy wheels. The WRX interior for 2009 gains new WRX-exclusive carbon black upholstery, accented by red stitching. A standard tilt and telescoping leather-wrapped steering wheel is accented by red stitching, and standard aluminum-alloy pedal covers now include the driver’s footrest.
    The optional ‘Premium Package’ gains a power moonroof for 2009; other contents carry over, including the 10-speaker audio upgrade with auxiliary input jack, projector-beam fog lights, dual-mode heated front seats, heated exterior mirrors and a windshield wiper de-icer. A navigation system with video jack inputs is also available.
    A new GT model has been added to the lineup as well. The car features a 224hp (167kW) version of the 2.5L turbocharged boxer engine and comes standard with a 4-speed automatic transmission. Both the 2009 GT and WRX also feature larger front brakes than the outgoing model.
    autoblog.com
    La sedan sembra quasi meglio così.. rispetto alla versione WRX
    **EDIT** Specificato.
    Ultima modifica di Touareg 2.0; 31-07-2008 alle 14:55
    News Aggiornate al 18/05/2013 : Subaru Forester.
    Aug 2004
    7,331
    Predefinito Re: Subaru Impreza WRX/GT 2009 (Foto Ufficiali)
    no dai..la berlina fa pietà...molto molto molto meglio la 2 volumi..
    Dec 2003
    Palermo
    29,617
    Sono tutte ancora troppo anni 80.. giusto ieri mi è capitato di vedere questa :
    Senza alettone fa paura..
    Il mio meglio era riferito rispetto alla Sedan WRX
  4. #4
    BANNED
    Jun 2008
    439
    la sedan vista da dietro sembra una berlinona, vista da davanti una wrx vecchia pompata.... sommando il tutto mi sembra degna dei migliori truzzi dell'entroterra calabrese o campano.
  5. #5
    Dec 2003
    Palermo
    29,617
    Ad un anno dall'arrivo della nuova versione due volumi arriva il primo aggiornamento per la Subaru Impreza. Ad essere interessata è però la versione WRX non disponibile in Italia e venduta negli USA come modello che si colloca un gradino sotto la top di gamma WRX STI. Il model year 2009 si ispira proprio alla "sorella maggiore", con alcuni miglioramenti mirati ad esaltarne performances e dinamica di guida.
    Sono nuovi la griglia di areazione, lo spoiler anteriore, le modanature laterali e i nuovi cerchi in lega da 17 pollici. Tutti elementi che richiamano le sensazioni del nuovo propulsore boxer turbo da 2.5 litri, abbinato al cambio manuale a 5 velocità, che ha guadagnato ben 41 CV. Il turbo è la chiave di tutto: attraverso una turbina di volume più ampio ed un catalizzatore a bassa densità l'unità giapponese passa dai 224 CV della versione americana 2008 a ben 265 CV a 6000 giri ed anche la coppia è salita da 306 Nm fino a 330 Nm a 4000 giri. La precedente unità da 224 CV non andrà però in pensione, ma andrà ad equipaggiare la nuova Impreza 2.5 GT, che per il momento sembra destinata al solo mercato nordamericano.
    Oltre che sul motore, la Casa delle Pleiadi per la Impreza WRX 2009 ha profuso i suoi sforzi anche sulla parte telaistica, aggiornando le sospensioni. Molle indurite e barre stabilizzatrici più spesse ne hanno migliorato la precisione di concerto con le nuove gomme. I precedenti pneumatici di misura 205/50 sono stati infatti sostituiti con gomme più performanti da 225/45, che godono di un profilo ribassato e una maggiore impronta a terra. Ovviamente è ancora presente la classica trasmissione "Symmetrical All-Wheel Drive" con controllo di stabilità, traction control e assistente per le partenze in salita, che saranno standard in tutte le Impreza 2009 che seguiranno.
    Sulla WRX 2009 sono stati inoltre rinnovati i rivestimenti degli interni, adottati sedili sportivi con poggiatesta integrato e una nuova pedaliera in alluminio. Ancora non ci sono notizie certe al riguardo, ma è assai probabile che alcune di queste novità - almeno il nuovo propulsore in questa sua versione aggiornata - possano arrivare anche in Europa.
    Per ora metto [USA] nel titolo..
  6. #6
    Team Manager L'avatar di JOKEJOE
    Sep 2004
    Firenze
    4,900
    Predefinito Re: [USA] Subaru Impreza WRX/GT 2009 (Foto Ufficiali)
    USA?
    E' una Global car..
  7. #7
    Aug 2004
    7,331
    Citazione Originariamente Scritto da Touareg Visualizza Messaggio
    guarda, davvero, questa berlina normale grigia è identica alla hyunday accent vecchia..
    e questa è identica alla wrx
    va bene per la sostanza, ma anche se fai qualcosa di decente di linea o di interni, non muore mica nessuno..
    anche in questa ultima subaru, cazzo niente serigrafia sui tasti dei vetri, quindi niente retroilluminazione e plancia assemblata bene (perché quel che è giusto è giusto, è fatta bene, non scricchiola, non rumoreggia, non ci sono sbavature), ma i amteriali sono al pari della 206 o della punto 55s..roba inguardabile adesso..
    non dico mettere la plastica morbida o rifinita in pieno fiore (), però qualcosa di normale si..
  8. #8
    Dec 2003
    Palermo
    29,617
    Non mi sembra che la WRX sia in vendita in Europa ..
  9. #9
    Aug 2004
    7,331
    quale, quella viola?
    la puoi sempre importare
  10. #10
    Dec 2003
    Palermo
    29,617
    Quella viola non è una Sr.1 Coupè?
  1. Subaru Impreza XV (Topic Ufficiale - 2010)
    Di Touareg 2.0 nel forum Subaru
    Risposte: 30
  2. [USA] Subaru Impreza WRX Sedan (Foto Ufficiali)
    Di Beckervdo nel forum Concept & Anteprime
    Risposte: 14
  3. Subaru Impreza WRC 2008 (Foto Ufficiali)
    Di Touareg 2.0 nel forum Sport Motoristici
    Risposte: 11
  4. Subaru Impreza WRC Concept (Foto Ufficiali)
    Risposte: 2
  5. Subaru Impreza WRC Concept (Foto Ufficiali)
    Di JOKEJOE nel forum Concept & Anteprime
    Risposte: 38
Tag per Questa Discussione
