auooblog.com
Beh finalmente qualcosa di interessante da Subaru, ma faccio fatica a considerarlo appartentente a questo marchio..
auooblog.com
sembra un'evoluzione di una civic con il culone di una culona..
però non è male, anzi
a me ricorda vagamente la Brera..boh! però non mi dispiace!
carscoopBypassing the Hybrid Tourer Concept's rear end that is remarkably similar in design to the Alfa Romeo Brera (...), Subaru's latest prototype model will be displayed to the public for the first time at the 2009 Tokyo Motor Show in late October. The gullwing-door model features Subaru's first hybrid drivetrain that combines a 2.0-liter horizontally-opposed direct fuel-injection turbo gasoline engine and the firm's trademark Symmetrical All-Wheel Drive system with an electric motor at each axle and a high-performance lithium battery.
Power is primarily provided by the boxer engine that is linked to a new generation Lineatronic CVT (continuously variable transmission). According to Subaru, at start-up and extremely low speeds, the 20kW / 27HP rear electric motor can move the vehicle on its own while during acceleration, it kicks in to give an additional power boost to the gasoline engine.
As for the 10kW / 13HP electric motor located on the front axle, Subaru said that it is normally used as a power generator to recharge the lithium-ion battery while it also provides additional power for hill climbing.
Another special feature of the four-seater Hybrid Tourer Concept is the EyeSight + (yes, that stands for 'Plus'), a new driving assist system that utilizes "stereo camera technology" to detect any obstacles in the vehicle's path and advise the driver on appropriate driving maneuvers.
Specifications
Length x Width x Height: 4,630 x 1,890 x 1,420mm
Engine type: 2.0-liter Horizontally-Opposed direct fuel-injection turbo gasoline engine
Max output of Motor: 10kW (Front) / 20kW (Rear)
Transmission type: Lineartronic
Drive train: Symmetrical All-Wheel Drive with 2 motors assist
Battery type: Lithium-ion battery
Tutto il posteriore ha il concetto di brera ....
è un plagio spudorato !!
comunque adesso c'è la risposta a chi si lamenta delle dimensioni dei posti post della brera
LANCIA - Il cliente di questo prodotto è un cliente che cerca e pretende il meglio, che vuole distinguersi, che ha la cultura della premiumness (Olivier François)![]()
essendo le foto piuttosto grandi : mi si aprono prima a grandezza naturale e poi si ridemensionano:
la prime che si sono presentate sono quella di 3/4 dietro + quella laterale:
ho pensato : "Minkia la brera allungata"...che volevo
The US Air Force has ordered Passats for stealth duties –
Un frullato di Brera e Avantime, ad ali di gabbiano
Mah...
Ma il posteriore di brera su un auto più lunga non coupè e non con un passo da fiat uno non è affatto male questa ne è una riprova.
Nel frontale per assurdo (fari a parte) ci vedo qualcosa di revolve citroen mascherona, taglio spigilo paraurti.
