Pagina 2 di 2 PrimaPrima 12
Risultati da 11 a 20 di 20
Discussione: [USA] Buick Regal (Foto Ufficiali)
  1. #11
    May 2004
    25.164
    Predefinito Re: [USA] Buick Regal (Foto Ufficiali)
    Domanda:
    Quest macchina è definibile "premium" in USA e "generalista" qui?
    Se le riviste USA facessero un confronto con la A4 e la Classe C sarebbe una minkiata?
    No, tanto per capire, eh....:
  2. #12
    Team Manager L'avatar di Motron
    Jan 2006
    Milano
    4.303
    Questa, per il posizionamento del marchio in usa, sarà concorrente di Chrysler su D-evo?
    Fiat Punto I 55 sx '97
    Toyota Prius V2 '06
  3. #13
    HYBRID Team Member L'avatar di Touareg 2.0
    Dec 2003
    Palermo
    26.276
    At a sneak preview of the Regal GS, GM Vice Chairman Bob Lutz told us in no uncertain terms, "We are officially not announcing this today." What he meant was that the Regal GS in not yet confirmed for production. However, given that most of its components are already in production and the level of detailed information revealed, all indications say that a Regal GS will debut a few months after its lesser siblings hit the streets.
    The Regal GS is based directly on the high-performance OPC version of the Opel Insignia, but instead of using the foreigner's 325-horsepower turbocharged V6, Buick is sticking with its four-cylinder-only strategy for the Regal. The GS is powered by a higher output version of the 2.0-liter direct-injected EcoTec four-cylinder that we've come to know and love in numerous GM products over the few years, with the tell-tale dual portholes on either side of its hood indicating its intentions. In this application, powertrain engineers have re-tuned the engine from its original 260 hp and 260 pound-feet of torque to 255 hp and 295 pound-feet. The GS is also equipped with a six-speed manual gearbox... in a Buick! While we tend to favor three-pedal configurations, we're confident that the GS will also be available with a self-shifting option when it arrives in showrooms.
    Back in the glory days of the GNX, turbo Regals offered plenty of capability for ramping up velocities. But when it came time to slow down or chang direction... well, when's the last time you saw a tight left-hander or chicane at your local drag strip? Being a true European sport sedan this go-'round, Buick has apparently covered all the bases when it comes to managing kinetic energy.
    To convert that forward momentum into thermal energy Buick went with one of the top names in the business: Brembo. The front wheels are equipped with 14-inch cross-drilled rotors and four-pot mono-block calipers... again, on a Buick! Match it all up with 19-inch wheels wearing appropriate rubber and the GS should haul down in a hurry.
    The last time a Regal had any serious performance, the tractive effort was handled only by the car's rear axle. Since this new version is a normally front-wheel drive, having any real credibility means adding an all-wheel drive system. Fortunately, the Epsilon II platform has already been engineered for this. Using the latest edition of the Haldex-based torque vectoring system that served duty in the Saab Turbo-X, the Regal should be able to send power to the wheels that need it most and move the car in any direction the driver wants with ease.
    Proper control of a performance car also requires a proper working environment for the driver. In the Regal that means a thick-rimmed steering wheel with a flattened bottom. That last bit should help ease getting in and out of the heavily bolstered Recaro thrones. (Hey GM, if a Buick Regal can sport Recaros, when will we get some better seats in the Corvette?) While ensconced, the driver can use an Interactive Drive Control System (IDCS) to select different settings for the throttle response, adaptive damping, steering and shifting (presumably when equipped with an auto-box).
    As we said, Maximum Bob made it clear that GM was officially not announcing anything yet. This is technically a concept for the moment – a show car only – but the smiles among GM staffers when talking about the GS, and the fact that the car is already engineered to go, indicates that we'll likely see the Regal GS in dealer showrooms sooner rather than later. We expect it to arrive sometime in 2011 with a price tag somewhere in the mid- to upper-$30K range.
    As much as we like what we've seen of the Regal GS, however, it still doesn't help us understand exactly what kind of brand Buick is supposed to be going forward. Perhaps we can contemplate the answer while letting the brakes cool after blasting some back roads... in a Buick!
    autoblog.com
    La versione sportiva della Regal.
    Nonostante si possa pensare ad un semplice rebadging dell'Insignia OPC, qui le cose stanno diversamente : la Regal Gs monta un 2.0 da 255 cv.. e non il V6 Turbo da 325cv della Opel.
    News Aggiornate al 23/05/2012 : Lamborghini (Tutta la Gamma) .
  4. #14
    World Championship Winner
    Mar 2004
    Deutschland - Italia
    2.698
    Citazione Originariamente Scritto da Touareg Visualizza Messaggio
    come mai c'è la foto del v6 turbo?
    '10 Citroën DS3 1.6 THP *funny car*
    In arrivo....Audi A6 Avant 3.0 TDI biturbo
  5. #15
    Jan 2007
    Mi son perso..
    21.167
    Citazione Originariamente Scritto da Matteo B. Visualizza Messaggio
    Domanda:
    la risposta è dentro di te...
    e mi sa che stavolta è quella giusta..
  6. #16
    Dec 2003
    Palermo
    26.276
    Citazione Originariamente Scritto da mmaaxx Visualizza Messaggio
    Domanda a cui ahimé non so rispondere , ma anche la press ufficiale da il 4 cilindri 2.0 255cv come motore in uso.
  7. #17
    Mar 2004
    2.698
    per queste foto avranno fatto un semplice rebranding
    per la versione di serie ci sarà il 4 cilindri
  8. #18
    Dec 2003
    Palermo
    26.276
    viene data come show car..
  9. #19
    Oct 2006
    11.423
    Citazione Originariamente Scritto da PaoloGTC Visualizza Messaggio
    It's GM global design, baby... a me sempre più spesso pare che s'influenzino non poco... negli anni 80-90 forse le GM Europee e le merrecane si erano allontanate di più (i cassoni cassonosi 60-70 invece, secondo me si somigliavano parecchio, al di qua e al di là dell'Oceano... vedi le enormi Opel d'alta gamma tipo Diplomat che non capivi se era un'americana o cos'altro ) ma, per esempio, l'altro giorno osservando gli interni della Caddy Converj Concept, ho rivisto un sacco degli interni di GTC Geneve che diede vita alla mia macchinetta.
    In effetti è cosi, anche se per motivi diversi: negli anni '70 la Opel cercava di somigliare alle auto statunitensi per sfruttare la "voglia d'america" che c'era allora. Oggi invece la Opel si è avvicinata allo "stile Buik sia per scrollarsi di dosso l'immagine triste delle ultime Astra e Vectra che per risparmiare sui costi d'industrializzazione: se usi la stessa carrozzeria non devi progettare due stampi diversi.
  10. #20
    HALL OF FAME L'avatar di T a u r u s
    Mar 2003
    12.085
    Citazione Originariamente Scritto da Stefano73 Visualizza Messaggio
    Meglio la lacrosse che è un insignia modificata che questa insignia rimarchiata che penso si posizionerà più in basso come prezzo.
    La LaCrosse e' una vettura di segmento superiore e usa la versione passo lungo del pianale Epsilon II che usa pure l'archiviata nuova Saab 9-5...con cui condivide molto piu' che con Insignia stessa...poi Insignia e' stata certamente sviluppata come un modello Saturn/Holden/Opel/Vauxhall, dopo la decisione di cancellare il marchio Saturn c'e' stata probabilmente l'idea di fare una versione Buick di tale modello da posizionare sotto la LaCrosse, comunque il design di Insignia in generale e' piu' da GM USA che Europe..
  1. [USA] Buick Regal Wagon (Spy)
    Di Beckervdo nel forum Rumors & Spies
    Risposte: 10
  2. [USA] Buick LaCrosse (Foto Ufficiali)
    Di JOKEJOE nel forum Concept & Anteprime
    Risposte: 19
  3. [China] Buick Regal (Foto Ufficiali)
    Di Touareg 2.0 nel forum Concept & Anteprime
    Risposte: 2
  4. [China] Buick Regal (Spy)
    Di Touareg 2.0 nel forum Rumors & Spies
    Risposte: 16
  5. Buick Enclave (Foto Ufficiali)
    Di Touareg 2.0 nel forum Auto Americane
    Risposte: 3
Buick Regal
buick
buick anni 70rispetto in cinesebuick regal gs fotofoto buikFOTO BUICK ANNI 30regalmacchine usa anni 80buick anni 60saab modificata cinaauto americane 6070buick anni 30buick regal anni 80foto macchine americane anni 70foto auto americane anni70autovettura buik americanabuick usaauto americana anni 30 buickBuick Regal o simile Buick Lacrosse AUTO americanamacchine americane anni 70 buicktutte le immagine della buick anni 30buick regal 80auto americane buick anni 70
Tag per Questa Discussione
