Audi RS5 Facelift 2012 [Coupé, Cabriolet]
Touareg 2.5
Messaggio Aggiornato al 15/08/2015
Audi-RS-5-FL-17.jpg Audi-RS-5-FL-16.jpgAudi-RS-5-FL-15.jpg Audi-RS-5-FL-14.jpg Audi-RS-5-FL-11.jpgAudi-RS-5-FL-10.jpg Audi-RS-5-FL-1.jpg Audi-RS-5-FL-20.jpg Audi-RS-5-FL-23.jpgAudi-RS-5-FL-2.jpg Audi-RS-5-FL-19.jpg Audi-RS-5-FL-18.jpg Audi-RS-5-FL-24.jpgAudi-RS-5-FL-25.jpg Audi-RS-5-FL-26.jpg Audi-RS-5-FL-27.jpg Audi-RS-5-FL-28.jpg Audi-RS-5-FL-29.jpgAudi-RS-5-FL-21.jpg Audi-RS-5-FL-3.jpg Audi-RS-5-FL-4.jpg Audi-RS-5-FL-9.jpg Audi-RS-5-FL-22.jpg Audi-RS-5-FL-5.jpg Audi-RS-5-FL-6.jpg Audi-RS-5-FL-7.jpg Audi-RS-5-FL-8.jpg Audi-RS-5-FL-13.jpg Audi-RS-5-FL-12.jpg
NCS - carscoop
Press Release Coupé :
The Audi RS 5
The RS 5 Coupé is the star athlete of the A5 family. It offers the power and handling of a powerful sports car packaged in the body of an alluringly elegant coupe. The design has now gained several new, sharp accents, with numerous features that characterize the other A5 models also making their way to the RS 5.
The Audi RS 5 Coupé uses a high-revving, normally aspirated V8 displacing 4,163 cc. This engine is closely related to the V10 that powers the R8 high-performance sports car. The 4.2 FSI delivers 331 kW (450 hp) at 8,250 rpm, with the peak torque of 430 Nm (317.15 lb-ft) available between 4,000 and 6,000 rpm. The engine has a specific output of 108.1 hp per liter of displacement. The potent response, the eager revving and the rich, melodious sound mark the V8 as a thoroughbred racing engine.
Hand-built at the plant in Györ, Hungary, the 4.2 FSI launches the Coupé from zero to 100 km/h (62.14 mph) in 4.6 seconds. Audi will increase the electronically governed top speed from 250 to 280 km/h (155.34 to 173.98 mph) upon request. Thanks to the combination of technologies from the Audi modular efficiency platform, which also includes a recuperation system, the high-tech V8 consumes significantly less fuel on average than its direct competitors.
With its high efficiency and its long top gear, the standard seven-speed S tronic also contributes to the good fuel economy. Drivers can let the lightning-fast dual-clutch transmission shift automatically or change gears themselves using the selector lever or with paddles on the steering wheel. The integrated launch control program provides for rocket-like starts by managing the engagement of the clutch at mid-level revs.
High end: quattro with crown-gear differential
Like all RS models, the RS 5 Coupé also applies its power to the road with quattro permanent all-wheel drive. The crown-gear center differential at its heart is compact and lightweight. It can vary the distribution of torque between the front and rear axles lightning-fast and over a wide range, with up to 70 percent flowing to the front or as much as 85 percent to the rear, as necessary. The default 40:60 ratio of the rear-biased configuration ensures sporty handling.
The crown-gear center differential works together with the torque vectoring system, which acts on all four wheels. If the load on the inside wheel is reduced too much while the car is being driven dynamically, that wheel is braked slightly before it can begin to slip. Audi offers the sport differential as a complementary option that actively distributes the power between the rear wheels via two superposition stages.
Precise and stable: the chassis
The chassis of the RS 5 Coupé unites fast and precise turn-in, high cornering speeds and supreme stability. Most of the components of the five-link front suspension and the self-tracking trapezoidal-link rear suspension are made of aluminum. The new speed-dependent power steering is an electromechanical system with a direct steering ratio for highly precise road feel. It supports the driver with slight steering corrections when braking on surfaces with different amounts of grip. Because the power steering draws no energy when driving straight ahead, it helps to enhance efficiency.
The taut setup lowers the body by 20 millimeters (0.79 in) compared with the Audi A5. Newly designed, 19-inch forged aluminum wheels with 265/35-series tires are standard; 20-inch wheels with 275/30-series tires are available as an option for the high-performance coupe.
The brake system of the RS Coupé features large, internally ventilated wave brake discs, with the front discs measuring 365 millimeters (14.37 in) in diameter. The steel friction rings with their wave-like outer contour are perforated and connected to the aluminum brake caps via pins. This direct structure reduces tensions, quickly dissipates the heat and prevents the transmission of temperature peaks. Moreover, the redesigned shape of the friction rings results in three kilograms (6.61 lb) of weight being saved in total, thus improving the balance of unsprung masses.
The calipers are painted high-gloss black; the front calipers have eight pistons each. The RS 5 can be optionally equipped with carbon fiber-ceramic discs up front. The electronic stabilization program (ESP) integrates a sport mode and can be switched off entirely.
Upon request, Audi equips the RS 5 with a particularly dynamic damping technology – the sport suspension plus with DRC dynamic ride control. The diagonally opposed pairs of shock absorbers are linked by hydraulic lines and a central valve. During fast cornering, the system intensifies the stabilization of the front outside wheel. The sport suspension plus features a three-stage, variable damping characteristic.
The Audi drive select driving dynamics system comes standard with the RS 5 Coupé. This system allows the driver to select between three modes – comfort, auto and dynamic – for the characteristics of the steering, the seven-speed S tronic and the accelerator. And if the car is equipped with an Audi MMI navigation system, there is also a fourth mode – individual – which can be configured by the driver. Audi drive select can also modulate the sound of the exhaust system, double-clutching when downshifting in dynamic mode.
Dynamic steering is another module available for Audi drive select beside the sport differential and the damping characteristic in the sport suspension plus. It uses a superposition gear to vary the steering ratio by nearly 100 percent as a function of speed and countersteers slightly at the cornering limit.
Unmistakable: The design
The RS 5 Coupé has an athletic road stance, and its classically elegant two-door lines dazzle with clear-cut accents. The new single-frame grille with beveled upper corners features a high-gloss, anthracite gray honeycomb structure and a matt aluminum-look frame. The standard xenon plus headlights are framed by narrow strips of LED daytime running lights. The air flows through large openings embedded in a distinctive bumper featuring a splitter edge like on a racing car. Sharper edges make the engine hood appear more three-dimensional so that the RS 5 looks even lower and wider when viewed from the front.
The flared aluminum front fenders and the rear side elements with the sharp horizontal upper edges are reminiscent of two classic Audi models from the 1980s – the all-wheel drive pioneer Audi quattro and the Sport quattro. The side sills sport chiseled caps; the trim strips and the side mirror housings have a matt aluminum-look finish.
The tail end is dominated by the two oval exhaust pipes of the dual exhaust system, which are integrated into the redesigned bumper. Audi also offers a sport exhaust system with a more voluminous sound and black exhaust tip bezels. The LED rear lights are also new and feature continuous light strips. The large diffuser extends far upward, and the spoiler in the rear hatch extends automatically at 120 km/h (74.56 mph).
The extensively clad underbody integrates air vents for the seven-speed S tronic and the front brakes. Thanks to its advanced aerodynamics, the RS 5 Coupé generates downforce at high speed to further enhance stability.
The dynamic looks alter the dimensions slightly. The RS 5 Coupé is 23 millimeters (0.91 in) longer and six millimeters (0.24 in) wider than the A5 Coupé, but six millimeters (0.24 in) lower. Eight exterior colors are available, from solid, metallic and pearl effect finishes to a specially pigmented crystal effect paint.
Dynamic elegance: The interior
The vehicle's dynamically elegant styling also extends to the interior. The standard sport seats with integrated headrests are power adjustable and covered in a combination of black leather and Alcantara. Audi also offers seat upholstery in Fine Nappa leather in a choice of black or lunar silver, both subtly accented with rock gray piping. Other options include bucket seats with folding backrests or comfortable, climate-controlled comfort seats with a ventilation function. The interior is bathed in black, with narrow chrome clasps at the switches and control elements providing delicate accents. Inlays are available in a choice of carbon, brushed or etched aluminum, a high-gloss piano finish or a light-colored stainless steel mesh.
The new leather multifunction sport steering wheel with its thick rim is flattened at the bottom and features a new, even easier control concept. The ignition key and the shift lever knob have also been redesigned. Even the steering column stalks have been updated. The instruments have black gauges and white lettering with special scaling. When the ignition is turned, the red needles of the speedometer and tachometer run quickly up to the limit before returning to zero for a touch of sporty flair. Typical of all RS vehicles, the door openers are two delicate bars.
The driver information system with color display includes an RS menu with a lap timer and an oil thermometer. It displays a special RS welcome screen when the car is started. A piano-finish fascia in the instrument panel frames the instrument cluster. The pedals, the footrest and the buttons of the optional MMI navigation systems shine in an aluminum-look finish. Aluminum inserts adorn the door sill trims, which are accentuated with RS 5 badges.
Audi also offers numerous exclusive features for the interior. A carbon design package is available for the engine compartment, as are a variety of styling packages for the body in black or matt aluminum look. A broad range of high-performance assistance and communication systems round out the optional extras program. Among these are adaptive cruise control, Audi side assist, adaptive light, MMI navigation plus, the Bluetooth online car phone and the Bang & Olufsen sound system.
The equipment, data and prices specified in this document refer to the model range offered in Germany. Subject to change without notice; errors and omissions excepted.
Press Release Cabriolet :
Dynamic performance where the sky's the limit - The Audi RS 5 Cabriolet
Audi extends its model series with a high-end convertible
4.2 FSI engine with 331 kW (450 hp), zero to 100 km/h (62.14 mph) in 4.9 seconds
Elegant and spacious body with lightweight cloth soft top
Dynamic performance where the sky's the limit - Audi introduces the RS 5 Cabriolet. The four-seat convertible with a cloth soft top entices with a unique combination of elegance and power. Its 4.2 FSI, a high-revving naturally aspirated V8 engine, outputs 331 kW (450 hp). It accelerates the high-performance sports car from zero to 100 km/h (62.14 mph) in 4.9 seconds.
Exterior design
In the RS 5 Cabriolet, Audi dynamics takes on an especially beautiful form in the car's flowing side profile with perfectly balanced proportions and sharp details. A frame in matt aluminum look surrounds the hexagonal single-frame grille; its honeycomb grille insert that sports an RS 5 logo shines in anthracite. Wedge-shaped headlights with wave-like lower edges illuminate with xenon plus lamps and LED strips that form the daytime running lights. Large air intakes are embedded in the distinctively shaped front apron whose ends run out into splitter edges.
Sill add-ons and wheel housing extensions dominate the car's appearance in side profile; the tornado line that defines the shoulder of the RS 5 Cabriolet was drawn to look especially sharp. The door mirror housings have an aluminum look, while the surface of the windshield frame and the decorative trim strips of the window channels and the soft top box cover are made of matt anodized aluminum.
The lightweight textile roof of the RS 5 Cabriolet spans over the generously proportioned interior space like a low curved dome; a special foam layer in the roof delivers high acoustic comfort. At the press of a button, the soft top opens and closes fully automatically in 15 seconds and 17 seconds respectively - even when driving at speeds of up to 50 km/h (31.07 mph).
When open, it hardly affects the size of the spacious luggage compartment - it only requires 60 liters (2.12 cu ft) of its 380 liters (13.42 cu ft) total volume. The split rear seatbacks can be folded over individually, and a load-through hatch from the trunk to the rear seating area improves variability. Special reinforcements contribute to the convertible body's high rigidity, and aluminum front fenders compensate for some of the added weight of the reinforcements.
Elegant LED light strips illuminate in the taillights, which operate without any conventional incandescent lamps. Like the lights, the rear bumper was also redesigned; its diffuser is now much higher, and a honeycomb screen insert encloses the two large elliptical tailpipes of the exhaust system. On the trunk lid there is a subtle matt carbon spoiler lip for more downforce; it may be painted in the exterior color as an option.
The Audi RS 5 Cabriolet measures 4,649 mm (15.25 ft) long, 1,860 mm (6.10 ft) wide and 1,380 mm (4.53 ft) high, and its wheelbase is 2,751 mm (9.03 ft). Eight exterior colors are available - a monochrome color, four metallic and pearl effect colors and three crystal effect paints. The soft top is available in black, gray, red or brown. As options, Audi can install a styling package in matt aluminum as well as an engine compartment design package that uses carbon fiber-reinforced polymer (CFRP) materials. The car's drag coefficient is 0.34; underbody panels make a significant contribution towards aerodynamic refinement.
Interior
A typical RS 5 highlight is its three-spoke steering wheel with flat-bottomed rim that is trimmed in perforated leather. The multifunction keys are intuitive, as are all other controls in the RS 5 Cabriolet. The terminal of the optional MMI navigation plus system, for example, only requires six permanent keys for the main menus, and just a single button control suffices for Audi drive select. White numerals on black dials provide a strong contrast and are easy to read. Sport-oriented drivers will find a lap timer for lap times and an oil temperature gauge in the driver information system.
The sport seats have power adjustments, high side panels for optimal lateral support, integrated head restraints, a lumbar support and a pull-out thigh support. They are upholstered in a combination of leather and Alcantara or in the optional black or lunar silver Fine Nappa leather. All leather types are pigmented to inhibit heating by sunlight. Seat alternatives are manually adjustable bucket seats or climate-controlled comfort seats with a ventilation feature.
The interior of the Audi RS 5 Cabriolet is styled in black, and the inner soft top liner can be ordered in the optional color star silver. Fine chrome highlights, understated high-gloss black trim and carbon inlays underscore the car's dynamic appearance. Upon request, Audi can deliver the inlays in Aluminum Race, piano finish black, matt brushed aluminum or stainless steel mesh at no additional cost.
There are RS logos on the backs of the seats, the aluminum inlays in the door sill plates, the steering wheel, the tachometer and the gear selector grip of the seven-speed S tronic. The inside door handles consist of two slender ribs, and the pedals and many other controls glisten in aluminum look. The Audi exclusive program offers many other customizing options.
Engine
Propulsive power for the RS 5 Cabriolet is supplied by a high-revving, naturally aspirated V8 engine with FSI direct injection. From its 4,163 cc of engine displacement, it outputs 331 kW (450 hp) at 8,250 rpm and produces a maximum torque of 430 Nm (317.15 lb-ft) between 4,000 and 6,000 rpm. The 4.2 FSI with red painted cylinder head covers that is manually assembled in the Hungarian plant in Gy?r achieves a specific power output of 79.5 kW (108.1 hp) per liter engine displacement; each hp only needs to move 4.267 kg (9.41 lb) of vehicle weight. The long-stroke engine with its aluminum crankcase breathes freely; flaps in the exhaust tailpipes vary the sonorous acoustic backdrop. As an option, Audi can deliver a sport exhaust system with black tailpipe trim.
The Audi RS 5 Cabriolet rockets from a standstill to 100 km/h (62.14 mph) in 4.9 seconds. The car's top speed is limited to 250 km/h (155.34 mph); at customer request, Audi can boost this to 280 km/h (173.98 mph). The powerful V8 has a combined fuel consumption of 10.9 l/100 km (21.58 US mpg). Its cylinder liners and chain drive are optimized for minimal friction, and the oil pump is only driven as needed.
Power transmission
Dual-clutch transmissions like the seven-speed S tronic of the RS 5 Cabriolet are distinguished by a high level of efficiency, which is further improved in this model by the long ratio of the highest gear. Shifts are performed so quickly and smoothly by alternating the clutches that they are hardly perceptible. The driver can have the seven-speed S tronic shift automatically in the D or S program, or he/she can manually shift with the gearshift lever or the paddles on the steering wheel. The Launch Control function is a useful drive-off assistant for the race course. It enables an optimal start by letting out the clutch at an ideal drive-off engine speed.
The quattro permanent all-wheel drive system gives the RS 5 Cabriolet a decisive advantage in traction and stability. Its technological centerpiece, the crown-gear center differential, is lightweight and compact. In normal driving operation, it distributes torque between the front and rear axles at a 40:60 ratio; if necessary, it can direct up to 70 percent to the front or a maximum of 85 percent to the rear. Torque vectoring - an intelligent software solution - completes the center differential's work tasks.
If a wheel at the inside of a curve begins to lose its grip when cornering at speed, it is braked slightly before any slip occurs - this keeps the RS 5 Cabriolet neutral for an exceptionally long time in extreme driving conditions.
As an option, Audi can install a sport differential that actively distributes power between the rear wheels via two superposition gears. A perfect supplement to the quattro drivetrain, it presses the RS 5 Cabriolet into the curve at the handling limits, counteracting any tendency to oversteer or understeer right from the outset.
Chassis
The chassis of the four-seat convertible exhibits a high level of technical complexity. Many components of the five-link front suspension and the self-tracking trapezoidal-link rear suspension are made of aluminum. The speed-dependent power steering system utilizes an electromechanical drive unit; it provides direct and sensitive steering feedback and is highly efficient. The body is 20 mm (0.79 in) lower than that of the Audi A5 Cabriolet; its mounts are stiffer, and its anti-roll bars are larger and stronger. The standard wheels are forged aluminum wheels in machine-polished ten-spoke design, size 9 J x 19 with 265/35 tires; 20-inch wheels in three attractive designs with tires in 275/30 format are available as options.
The brake system employs internally ventilated and perforated discs in a weight-saving wave design; the front discs are 365 mm (14.37 in) in diameter. The wave-shaped outer contour of the friction rings reduces unsprung mass by a total of about three kilograms (6.61 lb). Pins are used to join the discs to the aluminum brake pots - a concept adopted from motorsport. The brake calipers are painted black; the front brakes operate with eight pistons each. The ESC stabilization system has a Sport mode and can also be completely deactivated. Audi can deliver the car with carbon fiber-reinforced ceramic front discs and six-piston calipers as an option.
Audi drive select is a standard feature in the RS 5 Cabriolet. The driver can use this function to vary the characteristics of the steering system, seven-speed S tronic, throttle valves and exhaust system sound flaps to one of the modes comfort, auto or dynamic; if an MMI navigation system is installed, the ‘individual' mode is also offered.
The sport differential, adaptive cruise control and dynamic steering - whose gear ratio can be varied by nearly 100 percent as a function of vehicle speed - can also be incorporated into the system.
Another option that is controlled by Audi drive select is sport suspension plus with Dynamic Ride Control (DRC) - a purely mechanical system that operates without any delays. Each pair of diagonally opposing shock absorbers is interconnected via hydraulic oil lines and a central valve; when cornering at speed, the system increases support of the spring-deflected front wheel at the outside of the curve. The shock absorber characteristic can be adjusted over three levels.
Equipment
The Audi RS 5 Cabriolet is delivered with an extensive set of standard features. They include the parking system plus, driver and front passenger seat heating, automatic belt feeder, wind deflector, lighting package, driver information system with rest recommendation and a comprehensive package of restraint systems. In case of an impending roll-over accident, strong aluminum plates deploy upwards behind the rear head restraints. Sporty and luxurious options include three-stage head-level heating, convenience key, high-beam assistant, adaptive light and three-zone deluxe automatic air conditioning.
All assistance systems offered in the A5 model lineup are available as options in the RS 5 Cabriolet as well. Adaptive cruise control maintains the four-seat convertible at the desired distance to a vehicle driving ahead in traffic and supports the driver in braking. At speeds below 30 km/h (18.64 mph), it initiates a full brake application in an emergency situation. Audi side assist monitors the space behind the vehicle, which helps to ensure safe lane changes. Audi active lane assist makes it easier to stay in a driving lane. The parking system plus can be extended to include a reversing camera.
In the multimedia field, Audi is offering a comprehensive modular component system; at the very top there is MMI navigation plus which includes a large hard drive, DVD drive and seven-inch color monitor. An ideal complement is Audi connect with car phone, which connects the RS 5 Cabriolet to the Internet. Audi connect lets passengers freely surf the web with their mobile end devices via an integrated WLAN hotspot. Customized online services from Audi connect are also available to the driver - they range from Audi traffic information online to navigation with Google Earth images and Street View.
Customer deliveries of the Audi RS 5 Cabriolet begin in early 2013 in Germany. The base price in the home market will be 88,500 euros.
Audi
Prezzi:
Benzina:
4.2 FSI V8 S-Tronic (450 CV):
RS5: 86.600€
RS5 Cabriolet: 98.000€
Topic Spies : freccina19rossaiy0.gif Audi RS5 Cabriolet (Spy)
Modello Precedente - Coupé : freccina19rossaiy0.gifAudi RS5 2010
Bellissima anche questa, se possibile ancora più cazzuta!! Sono tanto bravi ad Ingolstadt in sto periodo.. ma quando la finiranno di ritoccare il rosso di sta maniera :roll: ?
Spero che Audi abbia terminato con le presentazioni.. :lol: !
Modificato da Touareg 2.5
 News al 02/12/2015: Mazda 2.
  • Risposte 34
Quella specie di faro nella griglia anteriore cos'è ?
Sensore anti collisione..... ;)
grosso in quel modo?Sembra abbiano fatto un potoshop per aggiungere i fendinebbia :lol:
A me l'intero restyling dell'A5 sa di posticcio... Nel senso che si vede chiaramente come sono stati limitati dalle vecchie lamiere nel disegnare i fari, che sono piccoli e male angolati.
Avrei preferito che mantenessero i fari per cui era pensata.
Non so se mi spiego.. Da un confronto con la nuova A6 disegnata PER quei fari è evidente quello che intendo dire
Firma
