Visualizza Risultati Sondaggio: quanto ti piace l'Audi A1 Quattro?
Partecipanti
59. Non puoi votare in questo sondaggio
  • • Molto
    13 22,03%
  • • Abbastanza
    13 22,03%
  • • Poco
    14 23,73%
  • • Per niente
    19 32,20%
Pagina 1 di 6 123456 UltimaUltima
Risultati da 1 a 10 di 59
Like Tree3Likes
Discussione: Audi A1 Quattro (Foto Ufficiali)
    HYBRID Team Member L'avatar di Touareg 2.0
    Dec 2003
    Palermo
    26.276
    Discussione Ufficiale o Indicizzata nella lista dei ''TOPIC già APERTI'' Audi A1 Quattro (Foto Ufficiali)
    Messaggio Aggiornato al 20/02/2012
    carscoop
    Press Release :
    The new head of the compact class: The Audi A1 quattro
    - Limited-production (333 units) A1 quattro beginning 2012
    - 188 kW (256 hp), quattro drive, 0 – 100 km/h in 5.7 seconds
    - Dynamic look inside and out, thoroughly equipped
    Ingolstadt, December 21, 2011 – Audi is crowning its successful A1 model series with an exclusive top-of-the-line model. The dynamic A1 quattro, limited to just 333 units, moves to the head of the compact class. Its two-liter, turbocharged engine produces 188 kW (256 hp) and 350 Nm (258.15 lb-ft) of torque, which is delivered to all four wheels. The Audi A1 quattro sprints from zero to 100 km/h (62.14 mph) in 5.7 seconds and has a top speed of 245 km/h (152.24 mph).
    The A1 quattro is powered by the 2.0 TFSI engine. The 1,984 cc, four-cylinder engine combines gasoline direct injection with turbocharging in the classic Audi manner. Among its highlights are the adjustable intake cam shaft and the two balance shafts, which ensure smooth operation. Maximum torque of 350 Nm (258.15 lb-ft) is continuously available between 2,500 and 4,500 rpm, and peak power (188 kW/256 hp) is developed at 6,000 rpm.
    Every detail of the sporty, sonorous four-cylinder engine has been optimized for high performance and low fuel consumption. Common rail injection, a turbocharger with intercooler and a regulated oil pump are just a few examples. The Audi A1 quattro is expected to consume on average less than 8.5 liters of fuel per 100 km (27.67 US mpg). Yet it performs like a top-notch sports car: The standard sprint takes just 5.7 seconds, and top speed is 245 km/h (152.24 mph).
    The 2.0 TFSI delivers its power to the quattro permanent all-wheel drive system via a precisely shifting six-speed transmission, bringing Vorsprung durch Technik to the small-car class. The heart of this system is an electronically controlled, hydraulically actuated multi-plate clutch whose package of plates rotates in an oil bath.
    During normal driving, the clutch sends most of the engine's power to the front wheels. If traction decreases there, the clutch can transfer torque steplessly to the rear axle in just a few milliseconds by forcing the packages of plates together by a defined amount. A pressure reservoir helps the electric pump to develop the oil pressure. If a wheel on one of the axles should slip, it is braked by the electronic differential lock (EDL).
    The placement of the multi-plate clutch at the rear axle provides for a harmonious distribution of the axle loads, and the chassis of the Audi A1 quattro has been adapted to the dynamics of the drivetrain. It is much more tautly tuned than that of the production model. The front suspension is a McPherson construction; a four-link axle is used at the rear. The sensitive and efficient electrohydraulic power steering has a sporty, direct 14.8:1 steering ratio.
    The Audi A1 quattro rolls on 8.0 J x 18 cast alloy wheels. They are Glacier White, feature an exclusive turbine design and are fitted with 225/35-series tires. The internally vented front brake discs measure 312 millimeters (12.28 in) in diameter and are gripped by black calipers. The ESP stabilization program includes a sport mode and can be switched off entirely for a trip to the race track, for example.
    One look is all it takes to see that the Audi A1 quattro is a very special vehicle. It is available only in Glacier White metallic, and its roof is painted high-gloss black. The front bumper is muscular, the frame and grate of the single-frame grille are high-gloss black. The curved bars in the headlights – the wings – are red. The grille, the roof arch and the rear hatch sport quattro badges.
    The rear windows are tinted; the roof flows into a large, two-color wing. The color black accentuates the rear hatch and the diffuser. The LED rear lights are tinted; the rear bumper sports a distinctive look. The exhaust system terminates in two polished dual tailpipes on the left and the right, each measuring 100 millimeters (3.94 in) in diameter. The A1 quattro is 3,987 millimeters (13.08 ft) long, 1,740 millimeters (5.71 ft) wide and 1,416 millimeters (4.65 ft) tall, making it somewhat longer than the model on which it is based. Luggage capacity is 210 liters (7.42 cu ft); folding down the rear seats increases this to 860 liters (30.37 cu ft).
    Cool, sporty black dominates the interior of the Audi A1 quattro. The seats and the armrests on the doors are covered in Silk Nappa leather with contrasting red seams. The S sport seats up front have pronounced bolsters, integrated head restraints and a quattro badge on the backrest covers. The seats feature multi-way adjustment. The lower section of the center console shines in high-gloss black; the footrest and the pedal caps are made of brushed stainless steel. Red seams frame the floor mats, and the door sill trims bear A1 quattro badges.
    The instrument cluster has a number of eye-catching features, including white needles, a red tachometer, the quattro logo and the color display for the driver information system. The multifunction sport steering wheel is flattened at the bottom, wrapped in leather with contrasting red stitching and sports the car's serial number. The shift lever knob is made of aluminum. Many control elements have an aluminum-look finish.
    The Audi A1 quattro will be available from the second half of 2012 and will be supplied to customers with a full range of equipment. It includes many features taken directly from the luxury class, including xenon plus headlights, high-beam assistant, adaptive brake lights, LED interior lighting package, light and rain sensor, automatically dimming interior mirror, rear parking system, automatic air conditioning, alarm system, storage package, convenience key and cruise control.
    The infotainment equipment likewise leaves nothing to be desired. It includes a CD changer, a digital radio tuner, the Audi music interface and MMI navigation plus. The Bose sound system drives 14 speakers with 465 watts of power; the woofers in the doors are indirectly lit with light guide LEDs. Audi connect uses the Bluetooth online car phone to connect to the Internet and deliver special web services, including Google Earth, to the car. Passengers can also connect their mobile devices to the integrated WLAN hotspot.
    Non chiamatela RS1 perchè così non si chiama.
    Questa è la nuova A1 Quattro, e sebbene vi farà urlare al raccapriccio e allo sdegno... a me fa troppo sangue . La trovo spettacolare, son davvero felice!
    Produzione limitata a 333 esemplari.
    Ultima modifica di Touareg 2.0; 20-02-2012 alle 15:05
    News Aggiornate al 23/05/2012 : Lamborghini (Tutta la Gamma) .
    HALL OF FAME L'avatar di Nick for Speed
    Feb 2010
    Rossano Veneto (VI)
    5.100
    Predefinito Re: Audi A1 Quattro (Foto Ufficiali)
    La A1 in sè la detesto, ma questa mi piace! Soprattutto il fatto di essere integrale ed avere quei bei cerchi da Delta integrale del tempo che fu... !
    Apr 2004
    Treviso
    28.571
    Madooo...
    Non si può guardare! Tuttavia mi farebbe piacere provarla...
    PS...
  4. #4
    Dec 2003
    Palermo
    26.276
    Tra l'altro notavo che è praticamente uguale alla Clubsport Quattro presentata al Wörthersee.
    Primo messaggio sistemato al solito, mancan solo i video. Foto bellissime, imho.
    Ultima modifica di Touareg 2.0; 21-12-2011 alle 01:56
  5. #5
    HALL OF FAME Moderatore L'avatar di Wilhem275
    Jun 2004
    Genova, o Venezia, o più probabilmente in viaggio, neppure lui sa dove.
    8.624
    Quella spadellata di rosso nel fanale, unita al blocco di plastica nera nella parte bassa del paraurti, le dona quell'orrendo aspetto che ho io la mattina dopo avere dormito per due ore: occhio iniettato di sangue e gigantesca borsa al di sotto.
    L'unico artifizio che mi sembri degno di nota e lo scurimento della fascia del portellone, così tanto per fare qualcosa di diverso. Negli anni '80 sarebbe stato un fascione di plastica nera...
    [Parlando di tedeschi coi baffoni] "Io adoro questi uomini "(Cosimo)
    [Parlando di TonyH] "TonyH non ha figli. Quindi, o è ricchione o è impotente." (TonyH)
    [Chiarendo il pensiero] "Neanche le donne sono indispensabili." (TonyH)
  6. #6
    Collaudatore
    Jan 2011
    183
    A me piace un sacco!...cura nei dettagli e prestazioni! solo cambio manuale?
  7. #7
    World Championship Winner L'avatar di ISO-8707
    Aug 2006
    Cuneo
    2.504
    Citazione Originariamente Scritto da RayLaMontagna Visualizza Messaggio
    IMHO non ci stava il DSG, a meno che con esso non si avesse un raggio di sterzata di un autotreno
  8. #8
    Dec 2003
    Palermo
    26.276
    Altro motivo per cui son felicissimo !
  9. #9
    Collaudatore
    Jan 2011
    183
    Citazione Originariamente Scritto da Touareg 2.0 Visualizza Messaggio
    aspettiamo il prezzo, ho davvero brutti presentimenti a riguardo....40K...
  10. #10
    Aug 2006
    Cuneo
    2.504
    Con la tiratura che avrà, possono sparare qualsiasi prezzo, tanto troveranno sicuramente 333 persone che domattina andranno di corsa in concessionario a fare un pre-ordine......
  1. Audi Quattro Concept (Foto Ufficiali)
    Di FJSS7 nel forum Concept & Anteprime
    Risposte: 208
  2. Audi A1 Clubsport Quattro Concept (Foto Ufficiali)
    Di Touareg 2.0 nel forum Concept & Anteprime
    Risposte: 22
  3. Audi TT Clubsport Quattro (Foto Ufficiali)
    Risposte: 13
  4. Audi A3 TDI Clubsport Quattro Concept (Foto Ufficiali)
    Di JOKEJOE nel forum Concept & Anteprime
    Risposte: 17
  5. Audi A1 Metroproject Quattro Concept (Foto Ufficiali)
    Di Regazzoni nel forum Concept & Anteprime
    Risposte: 180
audi a1 quattro
audi a1 nera
a1 quattropresa daria tuningpresa daria punto gtaudi a1 quattro prezzoAUDI AI QUATTROcerchi punto gtmodifiche audi a1audi tt INTERIOR PARTE DESTRAaudi a1 rsaudi del trotacerchi audi rs1punto del 2003 tuningc3 picasso whiteaudi as 1a1 nerapunto cerchi delta 14audi a1 english plateswww.nuova a1sport quattroquattro deltaaudi a 1 neraaudi a1 sport quattrovw golf 6 gti intercooleraudi a1 nera nuova prezzo
Tag per Questa Discussione
