What is it?
We’ve been hearing a lot about cylinder deactivation recently. And not surprisingly given the tough emission standards car makers are being forced to adhere to in an effort to meet upcoming EU6 regulations set to come into force in September 2014.
However, most of
it has been reserved for larger petrol engines such as Audi’s excellent new twin-turbocharged 4.0-litre V8, as offered in the in the A8 and soon to become available in the Bentley Continental GT.
But in a move that proves such technology also has a place in smaller engines, Volkswagen has unveiled a heavily reworked version of its widely used turbocharged 1.4-litre four-cylinder petrol powerplant running an innovative valve system developed in partnership with Audi.
The system is capable of shutting down the middle two cylinders on light throttle loads, effectively turning
it into a 700cm3 twin for lower consumption and emissions, particularly in city driving and highway running at constant speeds.
The new unit, of which only the 82mm cylinder bore spacing is shared with the older EA111 engine
it replaces, forms part of Volkswagen’s new modular EA211 engine range that is set to begin rolling out throughout various Volkswagen models bound for the UK in the not-too-distant future, including the Polo driven here in prototype form.
Among the more significant changes over the existing turbocharged 1.4-litre four cylinder TSI engine is a smaller 74.5mm bore and longer 80.0mm stroke – something that suggests there will also be larger capacity variants of the EA211, too. The compression ratio has also risen.
What’s it like?
With 138bhp and 184lb ft of torque at 1500rpm – some 34bhp and 55lb ft more than the existing Polo 1.2 TSI, the four-valve-per-cylinder engine provides the Polo 1.4 ACT with spritely off-the-line qualities, a satisfyingly flexible in-gear character and, thanks to long gearing, a relaxed cruising nature.
Nothing is official just yet, but expect on a 0-62mph time around 8.0sec and top speed around 125mph for seven-speed DSG (dual shift gearbox) equipped versions like that tested. Creditable performance, then.
However,
it is the engine’s ability to seamlessly switch from four to two cylinder operation that impresses the most.
It takes a steady application of throttle at engine speeds above 1250rpm to make the transition, but when
it does the only hint two cylinders have been deactivated is an advisory in the instrument panel and slightly raw exhaust note – something Volkswagen’s development engineers say will be altered before production begins. There’s no loss of momentum, as the revs are immediately matched to take into account the lower capacity.
Ease into the throttle gently and
it is immediately obvious there is less power on tap in two-cylinder mode. But at city speeds and at a constant cruise
it does not hinder progress. Push beyond 4000rpm and
it automatically switches back into four-cylinder mode, instantly providing the full level of performance.
Volkswagen denies the deactivation of the middle two cylinders could lead to a potentially disastrous cooling of middle section of the aluminium block engine, saying the internal water and oil system has been conceived to heat the middle two cylinders even when they are shut down.
Should I buy one?
The Polo fitted with ACT technology is still at the prototype stage, but
it’s clear that the new cylinder deactivation system brings lower consumption and emissions without spoiling performance or the potential for fun.
Overall, the new system is claimed to bring a claimed 0.4 litres per 100km reduction in consumption and 8g/km lowering of CO2 emissions – figures that are likely to see the upcoming Polo 1.4 TSI ACT come close to matching its 1.6 TDI sibling for overall economy and efficiency.
