ed eccoci qui, in attesa del grande dio unico conoscitore di tutti gli alesaggixcorsa dei fire, il mitico stev66 che ha fatto finta di non capire nel topic della biemme..
TU
TU9 /K 70.0 x 62.0 mm 954 cm3 45 ch Carbu simple corps
TU9 M/Z 70.0 x 62.0 mm 954 cm3 50 ch Injection, catalyseur
TU1 /K 72.0 x 69.0 mm 1124 cm3 55 ch Carbu simple corps
TU1 F2/K 72.0 x 69.0 mm 1124 cm3 60 ch Carbu simple corps
TU1 M/Z 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU1 JP 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU2 4A 75.0 x 73.2 mm 1294 cm3 95 ch 2 carbus double corps
TU2 4A/K 75.0 x 73.2 mm 1294 cm3 103 ch 2 carbus double corps
TU2 J2/Z 75.0 x 73.2 mm 1294 cm3 100 ch Injection, catalyseur
TU3 A 75.0 x 77.0 mm 1360 cm3 65 ch Carbu simple corps
TU3 A/K 75.0 x 77.0 mm 1360 cm3 70 ch Carbu simple corps
TU3 F2/K 75.0 x 77.0 mm 1360 cm3 75 ch Carbu double corps
TU3 M/Z 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 JP 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 S 75.0 x 77.0 mm 1360 cm3 85 ch Carbu double corps
ET3 J4 75.0 x 77.0 mm 1360 cm3 90 ch Injection, catalyseur
TU3 FJ2/Z 75.0 x 77.0 mm 1360 cm3 95 ch Injection, catalyseur
TU3 FJ2/K 75.0 x 77.0 mm 1360 cm3 100 ch Injection
TU5 JP 78.5 x 82.0 mm 1587 cm3 90 ch Injection, catalyseur
TU5 J2/L3 78.5 x 82.0 mm 1587 cm3 105 ch Injection, catalyseur
TU5 JP4 78.5 x 82.0 mm 1587 cm3 110 ch 16 soupapes, catalyseur
TU5 J4 78.5 x 82.0 mm 1587 cm3 120 ch 16 soupapes, catalyseur
TUD3 75.0 x 77.0 mm 1360 cm3 53 ch Diesel
TUD5 77.0 x 82.0 mm 1527 cm3 58 ch Diesel, catalyseur
e sbrigati che non hai tempo per lavorare, devi fare la tabellina![]()
LinkBack URL
About LinkBacks
Rispondi Citando
