FORD FOCUS RS - TECHNICAL SPECIFICATIONS
ENGINE DATA
Engine Type 2.5L 20 V DOHC RS
Displacement (cc) 2522
Bore (mm) 83.0
Stroke (mm) 93.2
Fuel type, grade Unleaded petrol, 98 or 95 (RON)
Max power ISO
PS (kW)At engine speed (rpm) 305
PS (224kW) 6500
Max torque (ISO Nm)At engine speed (rpm) 440 Nm a 2300 – 4500
Compression ratio 8.5:1
Cylinders 5, in-line
Cylinder head Gravity die cast aluminium alloy with sintered valve guides and seats
Cylinder block High pressure die-cast aluminium alloy with bed plate, metal-sprayed bores
Crankshaft Forged Steel with 50 mm-diameter crankpins, fully balanced with ten counterweights, six 65mm-diameter main bearings and damped front pulley, overall weight 21,5 kg. Lead free bearing shells
Valves per cylinder 4
Valve gear DOHC
Included angle between valves 58 degrees
Valve sizes (mm) Intake: 31.0
Exhaust: 27.0
Turbocharger Borg -Warner K16 integrated turbo system, one-piece precision-cast thin-wall iron housing
Camshaft drive Tooth belt with dynamic tensioner, Ti-VCT (Twin independent Variable Cam Timing), timing variation 50° (intake), 30° (exhaust)
Pistons Lightweight, short-skirt silicon-aluminium alloy piston with graphite-coated piston sleeves
Connecting rods Forged steel with fracture-split big ends, 143 mm length Max engine speed (rpm)
Idle engine speed (rpm)
Engine speed at max speed (rpm) 7050 transient (3 seconds) with continuous at 6500
800
6175
Engine management Bosch ME 9.0 Motor-Management System for Injection and Ignition, EURO Stage 4
Fuel injection Sequential electronic fuel injection (SEFI)
Ignition Electronic distributorless
Emission controls Under-floor closed-loop three-way catalytic converter with oxygen sensor
Emission level European Stage IV, with electronic on-board diagnostics (EOBD)
FLUIDS
Fuel Tank (litres) 62
Cooling liquid (litres), incl. heater 7.1
Oil quantity, incl. filter
Oil Change
Service Interval 5.8
Every 20,000 km / 12,500 miles
Annual or every 20,000 km / 12,500 miles
TRANSMISSION
Transmission type Manual 6-speed, synchromesh on all ratios including reverse
Gear ratios
6th
5th
4th
3rd
2nd
1st
Reverse
Final Drive 0.7
0.868
1.088
1.433
2.05
3.385
3.231
4.00
Clutch type Single dry clutch with self-adjusting lash mechanism
and dual mass flywheel
Clutch diameter (mm) 240
Differential Mechanical, Quaife helical limited slip differential, 6 planet gears, 32-degree helix angle
SUSPENSION
Front Suspension Independent MacPherson struts with offset coil spring over gas filled damper units and lower L-arms. Anti-roll bar (24mm).
Ford RevoKnuckle with fixed mount to anti-roll bar (patented)
Rear Suspension Independent Short-Long Arm (SLA) Control Blade multi-link system mounted on reinforced sub-frame, gas-filled dampers and anti-roll bar (24mm).
STEERING
Type Rack and pinion, ratio 13.2:1, lock-to-lock 2.32
Turning circle (m) Kerb-to-kerb: 12.2
BRAKES
Type Dual-circuit, diagonally split, hydraulically operated discs front and rear. Vacuum servo-assist. Standard electronically controlled anti-lock braking system (ABS) with electronic brake force distribution (EBD). Specially-developed
ESP system.
Front 336 x 30 mm ventilated discs
Rear 302 x 11 mm solid discs
BODY
Structure Computer-optimised, high-efficiency, unitary-welded steel
Safety elements - body Computer optimized body structure using high strength steels and custom welded material.
Rigid occupant protection cell
Front and rear energy-absorbing crumple zones
Impact-decoupling chassis system to protect footwell
Side impact protection door beams
High strength instrument panel carrier beam and steering column support
Passive safety and restraint system features
Full-size driver & passenger airbags (featuring latest single stage inflator technology)
High power pyrotechnic belt pre-tensioners and belt load limiting for front-seat safety belts
Three-point seat belts in all four positions
Seat belt reminders for driver & front passenger
Inflatable side curtains for front- and rear-seat occupants
Horizontal stroking steering column for optimized energy absorption and leg protection
Collapsible pedal structure
ISOFIX child seat attachment anchors available on request for both outboard rear seats
Front passenger airbag deactivation switch available on request
Optimisation for wide range of human body profiles, from 5th percentile female to 95th percentile male.
Bumper system Damage-resistant, full-depth moulded reinforced polypropylene
Security system elements Perimeter alarm with interior scanning capability optional
Advanced Ford PATS immobiliser
Key fob-operated double locking
Key-locking bonnet
WHEELS/TYRES
Standard wheel type Alloy
Standard wheel size (in) 19x8.5
Tyres Continental 235/35 R 19
DIMENSIONS AND CAPACITIES
Exterior
Overall length (mm) 4402
Overall width, excl. mirrors (mm) 1842
Overall height (mm) 1497
Wheelbase (mm) 2640
Front tread (mm) 1586-1606
Rear tread (mm) 1587-1607
Interior
Headroom front/rear (mm) 999/978
Shoulder room front/rear (mm) 1414/1399
Max legroom front/rear (mm) 1100/906
Luggage compartment-VDA (litres) 385
CORROSION PROTECTION 24-stage paint and body protection process, including zinc pre-coatings for all exterior panels excluding the roof, optimised dip phosphate process, electrocoat corrosion protection, filler/surfacer and clear-over-base enamel topcoat, plus comprehensive cavity wax injection, PVC underbody coatings and stone protection. Thick PVC sealing beads for all flanges. Front plastic wheel arch liners, rear textile wheel arch liners, anti-scuff strips on inner doorsills and rear load sill. 12 years anti-perforation warranty.
AERODYNAMICS Fully optimized aero pack, including front splitter, side rocker mouldings, rear venturi and twin-element rear wing
Drag Co-efficient (cd) 0.38
Front surface (A), m2 2.35
Front / rear downforce -0.022 / 0.000
WEIGHTS
Basic kerb (kg) 1467
Gross vehicle mass (kg) 1860
Payload (kg) 543
Roof load (kg) 75
PERFORMANCE
Max speed (kph) 263
Acceleration (sec)
0-100 km/h 5,9 sec
50-100 km/h (in 4th. gear) 5,3 sec
consuni non dichiarati
