| | #101 (permalink) | |
| HALL OF FAME Data registrazione: 07/03/03
| | #102 (permalink) | |
| HALL OF FAME Data registrazione: 06/03/03
__________________ | |
| | #103 (permalink) | |
| | #104 (permalink) | |
| | #107 (permalink) | |
| leggasi aciesse Data registrazione: 25/10/04 Località: Bannockburn
Per i cacciafumo si apre un 10 anni di successo, poi non so...
__________________ ...'cause we all just wanna be big rockstars, and live in hilltop houses driving fifteen cars, the girls come easy and the drugs come cheap, we'll all stay skinny 'cause we just won't eat... When I die I don't want no part of heaven, I would not do heaven's work well. I pray the devil comes and takes me to stand in the fiery furnaces of hell... | |
| | #108 (permalink) | |
refinement and performance for a diesel with its maximum output of 240ps at 3800rpm and 46kg.m of peak torque in the 1700~3500rpm range, figures which equal if not better the best V6 diesels today. With a bore and stroke of 84mm/89mm and a compression ratio of 17.3:1, the S-engine’s six cylinders displace 2,959cc and are banked at 60 degrees, the optimal angle to minimize vibrations in a V6. Leading the list of refinements is the selection of Compacted Graphite Iron (CGI) for the cylinder block. Manufactured with SinterCast technology, the CGI block is lighter and quieter than conventional grey cast iron and demonstrates at least 80 percent higher tensile strength, 45 percent higher stiffness and Cover Story Hyundai Motor World approximately double the fatigue strength of iron and aluminum thus allowing Hyundai engine designers to improve performance, fuel economy and durability while reducing emissions to meet the very latest Euro IV regulations. The S-Engine breathes through an all-aluminum head fitted with 24 valves in a dual overhead configuration and incorporating hydraulic valve lash adjusters while fuel is delivered by a second-generation common rail injection system featuring 1600-bar piezoelectric injectors. The rapid switching high-pressure injectors rely on newly developed piezoelectric actuation technology specifically tuned to the new combustion process. Piezoelectric injectors allow finer atomization of the fuel ensuring more efficient combustion and enabling more fuel to be injected into the combustion chamber in a shorter time than would be possible with conventional solenoid injectors. S-Engine turbocharging is accomplished with an electronically controlled variable geometry system. A serpentine belt and steel timing chain lowers noise while raising overall durability and operating precision. An Electronic Exhaust Gas Recirculation (EGR) Valve helps control the engine’s emission of nitrous oxides by reducing combustion temperature. L ultima volta che ho controllato IV stava per 4....ora sta per 5?
| | #109 (permalink) | |
| HALL OF FAME Data registrazione: 23/02/04 Località: lucca. italia
Ultima modifica di simonepietro : 01/05/07 alle ore 21.59. | |
| Segnalibri |
| Strumenti discussione | |
