| | #71 (permalink) | |
| HALL OF FAME Data registrazione: 23/02/04 Località: lucca. italia
Ultima modifica di simonepietro : 07/03/07 alle ore 16.00. | |
| | #72 (permalink) | |
- ENLIGHTENMENT: CGI increased mechanical properties allow designers to project new engines with thinner walls and reduced ribs. 2 - POWER INCREASING: Maintaining the same geometry and using CGI, a remarkable increasing of working pressures and temperatures inside cylinders it’s possible. Obviously, that fact leads to an engine power increasing and also to an improvement in the combustion process. Consequently, a reduction in exhaust emission is also obtained. 3 - ENGINE VOLUME REDUCTION: An engine design realised adopting a cylinder block in CGI, especially in case of V configurations, could have dimensions which permit to improve, or at least to keep constant, the aerodynamic efficiency of the whole vehicle system. Machining The development and introduction of newest and advanced technologies of CGI production process control, jointly with the improvements in the study of specific tools allow to manage machining processes of series productions without loosing productivity. Teksid is able to support its customers in the activity of machining parameters optimisation. | |
| | #73 (permalink) | |
| HALL OF FAME Data registrazione: 10/08/06 Località: Provincia di Napoli
cmq in definitiva è un'operazione che consente di compattare il materiale riducendone di conseguenza il volume e quindi il peso
__________________ ![]() | |
| | #74 (permalink) |
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | sì, ha caratteristiche di resistenza meccaniche più elevate e quindi è possibile fare pareti più sottili.qui puoi trovare alcune foto e maggiori informazioni. http://www.teksid.com/medium-t.htm seleziona la voce sopra Rapid Prototyping |
| | #75 (permalink) | |
| Team Manager Data registrazione: 28/08/03 Località: Italia - Europa
__________________ | |
| | #76 (permalink) | |
| HALL OF FAME Team Member Data registrazione: 18/10/04
__________________ Some day you'll be asked to define the term "Sports Car". When that times come, just show 'em this ALFA ROMEO My Westie is so evolved, in comparison your honor student is like a primitive fish with legs! | |
| | #77 (permalink) | |
| | #78 (permalink) | |
per questo dico anche che le differenza tra i moderni diesel che si fa qua con il Bmw in linea vs gli altri che sono V6 non si possa fare del tutto alla pari.. la "quantita di testate" penso possa cambiare non poco il peso...
| | #79 (permalink) | |
| | #80 (permalink) |
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | per chi conosce appieno l'inglese può godersi la presentazione del v6 VM fatta direttamente dai boss GM. http://www.brightcove.com/title.jsp?title=607793291 |
| Segnalibri |
| Strumenti discussione | |
