Type Liquid cooled 60-degree V6
Material Aluminum block and heads; deep-skirt block
Valves Chain driven DOHC with 24 valves and hydraulic end-pivot roller rockers
Displacement 220 cid / 3.6 liters
Bore x Stroke 3.78 x 3.27 (96 x 83 mm)
Fuel injection Returnless, sequential. Direct injection “may be coming.”
Compression 10.2:1
Fluid 6 quarts 5W20 oil; 14 quarts antifreeze; regular gas
Redline 6,400 rpm
Power 280 hp (209 kw) @ 6,400; 260 lb-ft (353 Nm) @ 4,800
Emission controls Dual three-way catalytic converters, heated oxygen sensors, internal features
Assembly First: Trenton South Engine, Trenton, Michigan
fonte allpar. com
