Pagina 1 di 2 12 UltimaUltima
Risultati da 1 a 10 di 11
Discussione: ZF - Arriva la sospensione in Fibra di Carbonio
    HALL OF FAME L'avatar di Beckervdo
    May 2009
    Salerno
    5.046
    Predefinito ZF - Arriva la sospensione in Fibra di Carbonio
    ZF Concept Study At The IAA 2009: Ultralight Dampers For Micro Cars
    •Saving weight - with fiber composite and functional integration
    •Half of the total weight compared to today's aluminum lightweight dampers
    Even after the scrappage incentive, smaller vehicle classes will still gain a larger share on the global market. Increasing vehicle weight due to better equipment and crash safety make the lightweight design approach a megatrend. At the IAA 2009, ZF presents an ultralight fiber composite damper. By using lighter materials and by integrating functions, it has been possible to halve the weight of today's aluminum lightweight dampers.
    Save fuel with innovations and thereby improve profitability - this is what all new ZF developments aim at. This is not only achieved by consistently optimizing the driveline. Another contribution can be made by reducing the vehicle weight with lightweight chassis construction. At the IAA 2009, ZF showcases a lightweight concept study from chassis technology: The ultralight fiber composite damper only weighs half of today's aluminum lightweight damper. Moreover, partially sprung and unsprung masses are reduced, leading to considerably enhanced comfort.
    High-quality damper
    The study by ZF Sachs, the Powertrain and Suspension Components division of the ZF Group, deals with an entire suspension strut with integrated wheel carrier. Weight savings are generated by using lighter materials instead of steel parts in the piston rod, internal parts, and module assemblies on the one hand, and with the integration of functions on the other: The newly designed plastic components make previous heavy steel components like the spring cap unnecessary. Despite their low weight, plastic dampers have all the features of a modern damper; this was proven by loading calculations based on Western European road surface conditions.
    "With our study on plastic suspension struts, we want to show above all how much potential there still is in terms of lightweight chassis", says Dr. Peter Ottenbruch, Head of the Powertrain and Suspension Components division. Despite the tremendous weight savings, the design is realistic and, as feasibility and cost analyses have shown, it could easily be transferred to volume production.
    Optimal for A-Segment cars
    The concept study takes the use in mini and microcars as a basis, with some vehicles featuring a curb weight of much less than a ton. Here, the ultralight damper supports the overall design approach in small cars: low total weight, reduced fuel consumption and CO? emissions, as well as enhanced comfort and noise insulation. In a next step, it is also thinkable to use this technology in larger vehicles.
    Via Zf.com
    La prima applicazione si avrà sulla BMW Megacity
    World Championship Winner L'avatar di defiant
    Mar 2003
    Brixia Fidelis
    1.936
    Predefinito Re: ZF: Arriva la sospensione in Fibra di Carbonio
    Vantaggi di questa soluzione?
    Facciamo un favore a questo mondo... Meno SUV, più 4C e Lotus...
    World Championship Winner L'avatar di MacGeek
    Nov 2003
    Torino
    2.261
    Ooooooooooooooooooh!
  4. #4
    Apr 2004
    Treviso
    28.587
    Citazione Originariamente Scritto da defiant Visualizza Messaggio
    Beh, sensibile riduzione delle masse non sospese (cosa non da poco per la dinamica), riduzione di peso in senso assoluto, maggior rigidezza e resistenza ad agenti corrosivi.
    Ovviamente se arrivi a romperla sono uccelli per diabetici... Non oso immaginare quanto possa costare...
  5. #5
    Team Manager L'avatar di Dannatio
    Apr 2009
    Bologna
    4.274
    Se si rompe si cambia, Punto.
    Il problema è vedere COME si rompe e che DANNI potrebbe causare all'auto rompendosi.
    Mi spiego.... un Ammo di metallo rompendosi, per quanto sia, credo mantenga la propria "sede" e la sua integrità pur perdendo la sua funzione ammortizzante, CREDO resti buona parte della funzione strutturale....
    in un AMMO di Carbonio minimo minimo diventa una Sbrisolona......
    Ma probabilmente ci avranno pensato.....o no?
  6. #6
    May 2004
    25.181
    riduzione masse non sospese e allleggeriemto cmq. più rigido e con meno microflessioni, guida migliore.
    per supercar IMHO.....
    "Driving pleasure is the philosophy behind the way we make cars, and this will never change." (Takashi Yamanouchi, Geneva 2011)
  7. #7
    Oct 2004
    26.044
    Predefinito Re: ZF - Arriva la sospensione in Fibra di Carbonio
    Raschiano il fondo del barile.......
    Già ora se tocchi un marciapiede ti rialesano lo sfintere per benino. Con una roba simile devi far prostituire tutte le donne di famiglia per pagare il conto.
    Trattandosi poi di una roba per "micro-car" siamo all'imbecillità pura
  8. #8
    Leader del campionato L'avatar di -jag-
    Dec 2005
    Bari
    1.293
    Una interessante soluzione, chiaro applicabile per le sole vetture sportive
    "If it isn't exiciting, it isn't Jaguar"
    [Ian Callum]
  9. #9
    Aug 2008
    Lecce
    3.532
    Per mia esperienza, a quell'altezza da terra meglio il caro vecchio acciaio, comunque più robusto. L'alluminio è un buon compromesso, il carbonchio, che io sappia, non è il massimo in compressione.
  10. #10
    World Championship Winner L'avatar di V6 Busso
    Jun 2009
    Provincia di Treviso
    1.838
    Citazione Originariamente Scritto da Ario_ Visualizza Messaggio
    Per le supercar può andare bene, per le auto normali credo che il gioco non valga la candela: è vero che un McPherson in carbonio sarebbe rigidissimo (forse più di un quadrilatero in acciaio), ma i costi sono proibitivi, sia in produzione, sia in caso di sostituzione . Meglio un buon McPherson in alluminio (es. Giulietta ) o un quadrilatero.
    "Se passi una vita noiosa e miserabile perché hai ascoltato tua madre, tuo padre, tua sorella, il tuo prete o qualche tizio in tv che ti diceva come farti gli affari tuoi, allora te lo meriti." Frank Zappa
  1. BMW - Si allarga l'uso della fibra di carbonio
    Di Beckervdo nel forum Meccanica ed Innovazioni Tecniche
    Risposte: 5
  2. BMW: Si allarga l'uso della fibra di carbonio
    Di Beckervdo nel forum Mercato, Finanza e Società
    Risposte: 5
  3. Motori in carbonio
    Di nissanGTR nel forum Meccanica ed Innovazioni Tecniche
    Risposte: 11
  4. Carbonio o Vtr?
    Di lapecoranera nel forum Personalizzazione Estetica
    Risposte: 0
  5. vi piace il carbonio in Maserati... ??!
    Di Blu Pitti nel forum Maserati
    Risposte: 1
sospensioni in carbonio
sospensioni fibra carboniosospensioni fibreinnovazioni tecniche sospensioni autovettureZF Suspensionsospensione auto in fibra di carboniozf sospensionisospensione carboniofriduzione masse non sospesecome si rompono gli ammortizzatori di un auto?sospensioni fibrasospensioni in fibra carboniosospensioni in compositofibra in carbonio provincia di bolognafibra carbonio autosospensione di un veicoloautovetture in fibra di carboniofibre composite nellautomobilismosospensioni microcarsospensioni in lamina carbonioaluminnio fibra di carbonio autopareri sospensione carbonio onozf compositosuv in fibra carbonio
