Pagina 1 di 3 123 UltimaUltima
Risultati da 1 a 10 di 22
Discussione: Nissan - 1.2 DIG-S
    HALL OF FAME L'avatar di Beckervdo
    May 2009
    Salerno
    5.046
    Predefinito Nissan - 1.2 Turbo Benzina 3 cilindri
    Newly developed HR12DDR, a 1.2 liter engine aims to achieve the lowest level of fuel consumption in the world for gasoline-powered cars, with an engine power output equivalent to that of a 1.5L engine(s) and CO2 emission of 95 grams per kilometer. The engine will be mounted on the new “Micra (also known as March in some markets)” in the European market in the first half of 2011.
    High engine performance and low fuel consumption levels have been achieved through the adoption of the Miller cycle, gasoline direct injection system (DIG), and a highly efficient supercharger, in combination with an Idling Stop system.
    More about the technology:
    By adopting the Miller cycle, in which the power stroke is enhanced by the compression stroke as a result of delaying the closing timing of the intake valve, the thermal energy of the fuel is converted to kinetic energy much more efficiently than it is with regular 4-stroke cycle engines, and pumping loss caused by intake manifold negative pressure has been reduced.
    Moreover, the highly compressed and high-temperature air-fuel mixture is cooled by the latent heat of the vaporization of fuel directly injected into the cylinder, and the temperature of the combustion chamber is lowered by adopting a piston-cooling channel and sodium-filled valves to control detonation. These technologies have enabled a compression ratio of 13*1 for improved combustion efficiency.
    The supercharger*2 is equipped with an automatic on/off clutch, which means that both high fuel efficiency and high engine performance can be achieved by automatically switching off supercharging while driving at low speeds, such as on city roads.
    Moreover, adoption of a hydrogen-free diamond-like carbon (DLC) coating for the piston rings and a variable displacement oil pump helps to reduce friction by up to 30%, compared with conventional 4-cylinder engines with similar performance levels.
    Via GlobalMotors.net
    Aug 2008
    Lecce
    3.532
    Predefinito Nissan - 1.2 DIG-S
    Riassumo un articolo di Autotecnica (di luglio) su questo nuovo motore già disponibile sulla Micra Pure Drive, caratterizzata da uno spoilerino posteriore maggiorato che riduce il Cx a 0,29.
    La tecnologia DIG-S (Direct Injection Gasoline - Supercharged) punta ad essere il top dell'offerta del marchio tra le piccole. Il motore disponibile su Micra è il 1,2 DIG-S:
    prodotto dalla Aichi Machine Industry di Nagoya
    ciclo Miller-Atkins, quindi con compressore volumetrico (Eaton a lobi)
    iniezione diretta con iniettore laterale
    fasatura variabile continua (sicuramente all'aspirazione, non so allo scarico)
    completamente in lega leggera
    n° cilindri: 3
    cilindrata totale: 1.198 cm3
    alesaggioxcorsa: 78x83,6
    rapporto di espansione 13:1
    dalle foto direi che il rapporto di compressione è 10:1
    potenza: 98Cv
    coppia: 142Nm
    Start&Stop
    alternatore a gestione intelligente
    consumi su ciclo CE: 4,1l/100km
    emissioni: 95g/km CO2
    per ridurre le vibrazioni niente contralbero, ma monoblocco rigido, supporti motore baricentrici e contrappeso sulla puleggia dell'albero motore.
    Si è posta particolare attenzione a ridurre gli attriti, quindi si adottato un rivestimento DLC (Diamond Like Carbon) per gli anelli di tenuta dei pistoni e per i biccherini delle punterie, il che dovrebbe ridurre le dissipazioni rispettivamente del 18 e del 50%. La distribuzione è stata affinata sotto altri aspetti: molle valvola sagomate a nido d'ape più sottili alle estremità e quindi più compatte e leggere e la superficie delle camme ha ricevuto una lucidatura di precisione. Il risultato è un rendimento organico molto superiore al vecchio 1,2 4L della vecchia Micra.
    Per migliorare l'affidabilità: pistoni dotati di getti olio di raffreddamento e valvole di scarico al sodio.
    A me pare una nuona realizzazione, spero di vedere presto delle prove.
    Pilota Ufficiale L'avatar di Cl@udio
    Mar 2009
    Ischia
    553
    Predefinito Re: Nissan- Nuovo motore DIG-S
    Visto, ma mi chiedo come mai Renault abbia abbandonato il tce per sviluppare un motore completamente nuovo che come prestazioni sembra piuttosto simile, pur (sulla carta) consumando meno. Non era sufficiente applicare l'iniezione diretta al tce (ammesso che l'operazione sia fattibile dato che non ne capisco nulla)? visto che il tce si è dimostrato affidabile...
    che ne pensate?
    Seat Leon 1.9 tdi Stella My01 Blu indigo
    Renault Clio tce Dynamique 5p Bianco Ghiaccio Vetri elettrici posteriori.
  4. #4
    Team Manager
    Jan 2008
    4.798
    Citazione Originariamente Scritto da Cl@udio Visualizza Messaggio
    che ne pensate?
    mica l'ha abbandonato ...questo è un motore Nissan utilizzato per auto Nissan...il TCE è un motore Renault utilizzato per auto Renault. sui benzina imho, da buona giapponese, Nissan è parecchio più avanti di Renault, al contrario nei diesel i francesi hanno la meglio...
  5. #5
    Feb 2004
    lucca. italia
    8.114
    magari in quelli di piccola cilindrata. I benzina medi aspirati , in versione sportiva, da 1600 e 2000 cc sono ottimi motori, anzi il due litri aspirato ( oltre 200 cv ) è forse superiore alla sua più potente versione turbo
  6. #6
    Team Manager
    Jan 2008
    4.798
    Citazione Originariamente Scritto da simonepietro Visualizza Messaggio
    imho anche il 1.6 turbo della Nissan da 190 cv montato sulla Juke sa il fatto suo ...comunque sì, riconosco che per i motori sportivi anche Renault sa il fatto suo
  7. #7
    Apr 2004
    Treviso
    28.587
    Predefinito Re: Nissan - 1.2 DIG-S
    Citazione Originariamente Scritto da Ario_ Visualizza Messaggio
    La cosa curiosa è che quando non serve potenza, per evitare inutili sprechi di potenza il compressore viene svincolato dalla puleggia.
  8. #8
    Aug 2008
    Lecce
    3.532
    Questo non lo sapevo. Ed effettivamente non sapevo neanche che Beckervdo, cui chiedo scusa, avesse già aperto una discussione in merito.
    Ho fantasticato un po' sul confronto DIG-S vs TwinAir e francamente mi pare una bella sfida. Compressore volumetrico, bassi attriti, basamento leggero ed assenza di contralbero darebbero una risposta più immediata al Nissan; d'altra parte immagino che un buon lavoro sugli attriti l'abbia fatto anche FPT, che dalla sua ha l'assenza del compressore, un cilindro in meno ed una cilindrata più contenuta.
    Al momento se la giocano alla pari.
  9. #9
    Oct 2004
    26.044
    Concettualmente il volumetrico è inferiore al turbo-compressore. Quando è attaccato il rendimento complessivo cala notevolmente.
    Ha di vantaggioso che può essere aggiunto facilmente a un motore già esistente.
  10. #10
    May 2004
    25.181
    qui c'è il volumetrico perchè è un motore ciclo Miller, che necessita del "supercharging" anche a basso numero di giri*. non si può fare un motore a ciclo miller col turbo (anche se forse gli esperimenti di tri-turbo vanno in questa direzione)
    *cito da wikipedia
    The supercharger typically will need to be of the positive displacement (Roots or Screw) type due to its ability to produce boost at relatively low engine speeds. Otherwise, low-rpm torque will suffer.
    "Driving pleasure is the philosophy behind the way we make cars, and this will never change." (Takashi Yamanouchi, Geneva 2011)
  1. Nissan GT-R Facelift (Spy)
    Di Beckervdo nel forum Rumors & Spies
    Risposte: 7
  2. Nissan - 2.0 dCi
    Di simonepietro nel forum Meccanica ed Innovazioni Tecniche
    Risposte: 4
  3. Nissan in F1???
    Di j nel forum Sport Motoristici
    Risposte: 2
  4. nissan rogue= nissan Qashqai ?
    Di simonepietro nel forum Rumors & Spies
    Risposte: 6
  5. NIssan GT-R
    Di ACS nel forum Rumors & Spies
    Risposte: 22
motore dig-s
curva di coppia clio 1.2 tce
motore dig s
nissan micra dig-s
micra 1.2 dig-s
renault 1.2 tce sodium
renault clio motore dig s
forum micra dig-s
motore dig 12 micra
micra dig-s forum
nissan motore miller
1.2 turbo nissan o 1.2 turbo renault
micra dig-s consumi
è affidabile il compressore volumetrico dig-s
rivestimenti dlc albero motore
micra dig-s
PREST MICRA 1.2 DIG-S
forum nissan micra 12 dig-s
motore dig-s nissan
nissan dig-s
nissan nuovo motore
prove micra 1.2 dig-s
micra dig-s consumi e opinionipareri nissan micra dig-s autopareri.com micra nissan dig-s commenti
Tag per Questa Discussione
