Pagina 5 di 5 PrimaPrima 12345
Risultati da 41 a 44 di 44
Discussione: Piani Jaguar per il futuro
  1. #41
    Apr 2004
    Treviso
    28.588
    Predefinito Re: Piani Jaguar per il futuro
    Mi sembra una scusante per il semplice fatto che ancora non sono pronti...
  2. #42
    May 2004
    25.181
    cioè questi parlano di auto da presentare dal 2016 in avanti?
    "Driving pleasure is the philosophy behind the way we make cars, and this will never change." (Takashi Yamanouchi, Geneva 2011)
  3. #43
    May 2005
    MI+BG
    40.040
    Non volevo essere così esplicito, ma visto che l'hai scritto tu, non posso non quotare.
    o chi lo sa...
  4. #44
    Leader del campionato L'avatar di -jag-
    Dec 2005
    Bari
    1.293
    Update: questa è una bella intervista, dove si fa' chiarezza su molti punti. Di Pistonheads.co.uk
    As pictures have now been published of Jaguar's cut-and-shut XK prototype, the cat is well and truly out of the bag about the firm's plan to build a new 'entry level' sports car. So when PH bumped into JLR global brand director Adrian Hallmark and design chief Ian Callum at the launch of the new four cylinder diesel XF in Munich on Monday, we demanded they spill all the beans immediately about this exciting project. They declined, but we ploughed on regardless... In case you missed an edition of AutoEvoCarBlog, the word is that Jaguar plans to replace the current XK range with two front-engined roadster and coupe models sharing key underpinnings and architecture but different bodywork, powertrains and styling. One will be a new entry-level two-seater (possibly badged XE or XKE) with V6 and (possibly) V8 power that's likely to be revealed 18 months from now. It will be priced between the Porsche 911 and Boxster, we're told, while its sibling will be a more expensive and larger 2+2 that will replace the newly facelifted XK a year or so later.
    Adrian Hallmark - global brand director
    With the C-X75 'hypercar' also confirmed for production, it all means Jaguar is a few short years away from boasting what could be one of the most glamorous and desirable sports car line-ups in the business. While it's tempting to talk of the new two-seater as a spiritual successor to the E-type, there's resistance to that idea at Jaguar. Ian told us he doesn't hold with it due to both the weight of expectation and the baggage such a comparison brings. Anyway, the high performance, premium XK is probably closer to the E-type in spirit than a new, harder-edged small sports car.
    The last time a junior Jaguar sports car was close to the launch pad was a decade or so ago, when the F Type show concept was revealed to suitably lip-smacking responses at the Detroit Auto show.
    The F Type was created by a project team led by Keith Helfet under design boss Geoff Lawson. A heart attack ended Lawson's career tragically early, and the show concept was completed under his appointed successor Callum.
    While punters in their droves cried 'just make it', Ian now maintains that few people really appreciated how far from reality the F Type concept was. "We couldn't build it, because it had a really low windscreen and high bonnet," he says, "and by the time we normalised it for production it took all the character out." Reading between the lines it may not have helped the F Type's cause that Ian, in his role as vigorous new broom at Jaguar, was already pursuing his own design agenda.
    Ian Callum: It's not a new 'E Type'
    "We developed a mid-engined car in parallel and ran with it as the preferred F Type contender," he says, "but ultimately the board decided that we had to choose between powertrain or product developments, and all the logic pointed to getting the powertrains sorted instead." That stillborn mid-engined F Type has never been seen in public, but if you can visualise a roadster of Boxster proportions with an XJ220-esque nose and circular air intakes raised above the waistline ahead of the rear arches, you'd be close-ish. (Ian would probably take exception to this simplistic description but forgive us, we've only ever glimpsed this intriguing clay model as an iPhone thumbnail!)
    So what of the F Type's 'spiritual successor' today - and why now, if not then?
    We've known an entry-level roadster has been a Jaguar priority since 2009 because Ratan Tata said as much, and all subsequent reports suggest it's going to be based around a version of the platform architecture underpinning the new XJ.
    "There's always been a case for this car, we're just late getting there," says one of the men making it happen, brand supremo Adrian Hallmark.
    "Why did Porsche enter the SUV segment when everyone said it had peaked? It hadn't, that's why. Everyone talks about emerging markets like Brazil and China, but Jaguar's traditional markets are predicted to be bigger than BRICS for the next 20 years, and demand for premium products is set to increase. The only downside is ever increasing pressure on CO2 emissions, which will be addressed by downsizing, hybrids and other technologies - so the death of the sports car is greatly exaggerated."
    F Type was a hit, but couldn't be built...
    According to Adrian, the premium sportscar sector is 'inelastic' which, in schoolboy economic terms means supply and demand are not inextricably bound together. "The space beneath the XK is there, but it's not like bringing XF under XJ where you do three times the volume. For example the Porsche Boxster peaked at 90% of 911 sales, and has been flat for 10 years - if you're going to do this it's not just about a car, you've got to have a whole lifecycle plan." You've also got to have a few quid in the bank for development, and JLR is sitting on a pretty pile of cash. As well as a hefty £1.126 billion profit last year (which takes into account existing R&D spend), a whole extra billion cleared into the company's bank account last month as the result of a 10 year bond issue.
    "The commitment to invest in the Jaguar brand - well, I've never seen anything like it," says Adrian, a high-flyer who's CV includes stints at Porsche and Bentley amongst others. So what could possibly go wrong?
    ...and a mid-engined rival got further
    A sudden worsening of the global economic outlook could be a fly in the ointment he reckons, otherwise "the devil is in the detail". "Only we can do a Jaguar, but we need to compete where other companies are excelling. The biggest strategic mistake we've made before is doing neo-Jaguar design instead of designing for the future. Not every car needs to look the same, and I think some of our competitors are reaching a level of 'sameness' that's dangerous," he says, adding the Jaguar brand can definitely support the broad 'bandwidth' that has allowed the hard-core - and widely acclaimed - XKR-S to emerge. "The XK is very much a GT, but the R-S has been invaluable to see just how sporty people imagine Jaguar can be."
    Ian agrees that a new entry level sports car should have a harder performance edge to it.
    "If you define a sports car for two people, it has to be delivering driving focus. If you define a 2+2 it's a GT car for touring," he tells us.
    "My design approach won't change from what we're already doing," he says. "Fantastic proportions and great lines, and always pushing boundaries to get proportions as good as I can."
    Will C-X75 herald a 'volume' supercar?
    "The front graphic of the C-X75 is something you'll see in the future - I've learned the Jaguar oval is not assertive enough - and sports cars are interesting because you always feel the need to put in a certain amount of 'curvaceousness'; that classic coke bottle styling if you will, and I don't mind that at all." As for the rest? "You'll have wait and see!" Having touched briefly on the limited volume, extraordinarily high-tech and fabulously expensive hypercar in development with partner the Williams F1 team, we were intrigued to know where Ian thought the project might lead. And he acknowledges that while there's no current strategic or business plan for Jaguar to develop a presence in the 'mainstream' supercar sector, it could open doors in future.
    "The reason we're doing CX75 is that we want to demonstrate our amazing innovation and technical prowess," he says. But could it lead to a less esoteric supercar project in future? "Well it's nice to think that might be possible, and it's a direction I'd personally like to go in," he says. (Hold the front page - that makes it 'official'! Ed.)
    The £700k bolide's final specification is still being refined, and while it was expected that a version of the proposed 'new for 2014' 1.6 litre four cylinder F1 engine would be used in the Jaguar, the news that the engine planned for F1 has been now been officially re-spec'ed as a V6 means Jaguar and Williams will surely have to react.
    So if they've got to make the engine bay bigger anyway, let's hope they remember to leave room for a supercharged V8...
    "If it isn't exiciting, it isn't Jaguar"
    [Ian Callum]
  1. [Suzuki] I Piani Futuri
    Di Touareg 2.0 nel forum Mercato, Finanza e Società
    Risposte: 2
  2. Fiat-Chrysler - INDISCREZIONI SUI PIANI STRATEGICI
    Di <<Scarface>> nel forum Mercato, Finanza e Società
    Risposte: 61
  3. Gli 80 anni dei bus a due piani di Londra
    Di picpus nel forum Veicoli Commerciali-Industriali e Ricreazionali
    Risposte: 2
  4. Piani x Lancia
    Di schtrunz nel forum Mercato, Finanza e Società
    Risposte: 2
2
bettie page
3
bettie page blog
4
1
5jaguar coupe 2 posti modello 2013futuri modelli jaguarjaguar xe berlina 2013futura range rover sport 2014jaguar 2 posti coupe mod.2o13jaguar modelli 2013novita jaguar per modello che sostituira la x typexf seconda generazione conceptbettie page fotorestilyng jaguar xj 2013jaguar progetti futuriNOVITà JAGUAR XJ 2015betty pageNuova Range Rover Sport 2014jaguar xj 2015cayman nuovo modello 2013 forumfutura jaguar xf coupe 2013piani Jaguar
