Pagina 1 di 2 12 UltimaUltima
Risultati da 1 a 10 di 12
Discussione: TÜV-Report 2012 le auto più affidabili in Germania (Prius e 911)
    Leader del campionato L'avatar di crabble
    Aug 2010
    1.120
    Predefinito TÜV-Report 2012 le auto più affidabili in Germania (Prius e 911)
    Su quasi 8 milioni di auto (7.779.312= esaminate, le più affidabili sono la Toyota Prius (dopo 3 anni) e la Porsche 911 (dopo 10 anni):
    It’s Official: Toyota Prius And Porsche 911 Are Germany’s Most Reliable Cars
    By Bertel Schmitt on December 8, 2011
    One of the most closely watched quality indicators in Europe and especially in Germany is the annual TÜV-Report. With German thoroughness, the report tells exactly which cars were naughty or nice. It’s the law: Three years after you buy a new car in Germany, it must be inspected by the Technischer Überwachungsverein. Thereafter, every two years. This is not your run-of-the-mill drive-to-the-gas-station-get-a-sticker exercise. At the TÜV, each car undergoes a thorough and invasive physical. Fail the physical, and it’s back to the shop. Fail again: No inspection sticker, get that POS off the road. No wonder that a date with the TÜV is considered as even less attractive than a meeting with the proctologist. One out of 5 cars fail the test on the first attempt.
    Once a year, the TÜV compiles its TÜV-Report, using the actual results of the check. This is no J.D.Power CSI. This is the real world, a report compiled with screwdrivers, flashlights, emission probes, brake testers. Executives at automakers await the report with high anxiety. Bad positions on the list can be career-ending.
    The TÜV-Report 2012 will be published on December 16. Some results are already dribbling out, but the list itself remains under wraps. We twisted some arms and finagled an advance copy (your Teutonic old boys network at work.) Let’s see who will be promoted and who should polish his resume.
    7,779,312 million cars were inspected between July 2010 and June 2011. We focus on two groups of cars: New cars, which are checked after 3 years. And, as the super long term testers, 10-11 year old cars. We will only show you the nicest and the naughtiest to avoid data overload. The percentage number means how many of the cars tested failed and were sent back to the shop. Lower is better.
    If you own a newish Toyota Prius, the TÜV test won’t scare you. For the second time in a row, the Prius takes the top spot. Says Auto Bild:
    “Especially impressive: The complex hybrid technology of the Toyota Prius works perfectly. In second place, also a Toyota: The Auris usually masters the first TÜV check without fail.”
    Interesting: The Top 10 look like a remake of the axis, with the Italians AWOL: Six out of the ten best are Japanese, the remaining four are German. If you are looking for the axis partner gone AWOL, check the bottom of the list.
    Now for the oldies. Which ones don’t show their age? The Porsche 911 leads the Top 10 of the seniors (with the usual Japanese/German mix).
    The Porsche 911 also takes top billing in 6-7 years and 8-9 years. No wonder, it is usually babied and serviced by mechanics with white gloves. Don’t just assume it will hold up forever. Spoil the car like an elegant lady, and she will win the biannual beauty contest.
    And which car is the worst you ask? Let’s quote Auto-Bild on that contentious topic:
    “The loser in all classes is the Ford Ka. No car has a higher number of serious faults. 38,9 percent of Ka cars between 10 and 11 years leave the TÜV without the sticker. For the third time in a row, the catastrophe-Ford is last on the list.”
    For data nerds: Look at the godawful showing of the Volkswagen Sharan, the Seat Alhambra, and the Ford Galaxy. Same car. The first generation (tested here) were all made in the Ford/VW joint venture plant in Palmela.
    thetruthaboutcars http://www.thetruthaboutcars.com/201...s/#more-421764
    May 2004
    25.181
    Predefinito Re: TÜV-Report 2012 le auto più affidabili in Germania (Prius e 911)
    cito: The Porsche 911 also takes top billing in 6-7 years and 8-9 years. No wonder, it is usually babied and serviced by mechanics with white gloves. Don’t just assume it will hold up forever.
    mi sembra una buona spiegazione, posto che le 911 sono auto di proverbiale affidabilità.
    P.S. Non vedo BMW e Audi
    "Driving pleasure is the philosophy behind the way we make cars, and this will never change." (Takashi Yamanouchi, Geneva 2011)
    Team Manager L'avatar di RiRino
    Sep 2008
    Barletta
    3.190
    Ma davvero le 911 sono cosi' affidabili??
  4. #4
    Team Manager L'avatar di Dannatio
    Apr 2009
    Bologna
    4.274
    Citazione Originariamente Scritto da RiRino Visualizza Messaggio
    No.....
    Le 996 in particolare rompevano i motori a tutto andare....
  5. #5
    May 2004
    25.181
    Citazione Originariamente Scritto da Dannatio Visualizza Messaggio
    No.....
    vero, però sono intervenuti con decisione con sostituzioni motore ecc... sono "un lotto" che dopo tot "si sfondano", e comunque hanno ragionissima a dire che hanno una manutenzione "in guanti bianchi".
  6. #6
    Mar 2003
    genova
    18.675
    Tra parentesi la "premmiummissima" VW Passat è migliore , nella classifica decennale, solo di un decimo dell'uno per cento della proletarissima ed inaffidabile Fiat Punto...
  7. #7
    Guidatore esperto L'avatar di TNTS2K
    Jan 2011
    59
    Citazione Originariamente Scritto da Matteo B. Visualizza Messaggio
    Infatti......
    A3 2.0 TDI 140CV SPORTBACK 2005' (minor consumo 19,2 KML pieno pieno; CDB 19,5)
    TANTA VOGLIA DEL MIO VECCHIO VTEC........
  8. #8
    Apr 2009
    Bologna
    4.274
    Per la serie "Lupus in fabula"....... stamattina..... Carro attrezzi con 996 sopra.....
  9. #9
    World Championship Winner
    Oct 2011
    1.562
    Divulgate queste classifiche...giusto per illustrare agli italioti che i crucchi non costruiscono carri armati...
    TonyH
    La fessura è SEMPRE vincente. Ricordatelo. E' la fessura che fa girare il mondo.
  10. #10
    May 2004
    25.181
    galaxy/sharan/alahambra peggio di 156?
    Ametrano batte "Fussball Mutti" tedesca?
  1. ADAC: le auto più affidabili in Germania nel 2011
    Di Pawel72 nel forum Mercato, Finanza e Società
    Risposte: 11
  2. Le auto più affidabili secondo Tuv
    Di Ario_ nel forum Sicurezza Stradale e Legislazione
    Risposte: 6
  3. JD Power Asia - le auto piu affidabili x segmento
    Di Lanciaboxer nel forum Mercato, Finanza e Società
    Risposte: 1
  4. LE vostre auto più affidabili
    Di Giulio nel forum Consigli per l'Acquisto dell'Auto
    Risposte: 7
  5. ecco le auto + affidabili...
    Di 126/131 nel forum Manutenzione e Assistenza - Ricambi e Accessori
    Risposte: 0
affidabilità auto 2012
tuv report 2012
classifica affidabilità auto 2012
auto più affidabile 2011
tüv report 2012
affidabilità auto 2011
auto piu affidabile 2012
TUV 2012
classifica auto affidabili 2012
auto più affidabili
classifica tuv affidabilità auto
classifica affidabilità auto 2011
tuv report
TÜV Report 2012
auto piu affidabili
affidabilità auto
technischer überwachungsvereine autopareriTUV 2012 affidabilitàtuv affidabilità 2012classifica affidabilita auto 2011auto piu affidabili 2011tuv 2012 reporttuv affidabilità autole auto più affidabili 2011
Tag per Questa Discussione
