Quando dovrebbe uscire questo motore?Con la nuova Spyder?
Per chi volesse approfondire la questione B5, M5, Quattroporte senza che riscrivo tutto vi rimando alla discussione Brera vs Gtv da pagina 21 in poi dal mio primo post di quella pagina per rispondere proprio a Taurus. Confermo l'analisi fatta da Sakis, sicuramente più puntuale. Disponibile su eventuali delucidazioni se non sono stato chiaro in qualcosa...
come gia' detto nell'altro post reputo i tuoi dati molto interessanti e assai logici...danno un po' una ridimensionata a questo test e ai suoi risultati...
Auto:ex bmw 320d touring 150cv,Gpunto 1.3mj 90cv
La tua prossima auto:a trazione posteriore
moto:Venduta
una vita di traverso
Originariamente Scritto da sakis
You confuse my words, i said already that alpina b5 is offered with more than one set ups, and probably the car in the EVO test had the sportier set up than the car used by sport auto magazine, M5 is offered with a single set up, is truth that B5 lacks of lsd but B5 Torque is much superior than M5 and torque is a main factor in a curcuit, so i think is credible the difference of 1 tenth in EVO rather than the german magazine test in which the B5 used had the comfort set up.
But all that is secondary, the fact is that maserati quattroporte is the best handling sedan in the world, and that M5 doesn't keep it's promise, is really ridiculous for the ultimate driving machine brand, be outpaced by 1,6sec by a limousine 200kgr heavier, 107hp less powerful, and 22cm longer, that is a proof that if you want to have a real sport sedan is more important have ane excellent chassis first, cause less weight,agility, more powerful engines are important factors, but come way after the chassis as importance, and the M5 chassis could be good for an executive car, but is really poor compared with maserati quattroporte so poor that all the advantages in power,agility,weight are meaningless.
Ultima modifica di T a u r u s; 24-11-2005 alle 11:39
Probably? Quindi ancora una volta non sei sicuro dei dati che posti.. capito... Comunque da che mondo è mondo le alpina sono sempre state più lente in pista delle \\\M, altrimenti le sportive bmw le avrebbero fatte fare a Alpina e no a Motorsport.. Ah già dimenticavo che in Formula 1 ci corre la Alpina... che stupido che sono.. La b5 che ha fatto la sfida diretta con l'M5 giustamente l'hanno scelta fra tante che ce ne sono, la più morbida soffice e confortevole che c'è, un bel piumone in inverno... Tra un po' dirai che la B5 del test diretto contro l'M5 era un 1600cc della fiesta xr2...Originariamente Scritto da T a u r u s
ma scherziamo, alpina offre sempre piu' di un assetto, motorsport invece uno...e' un dato di fatto...
Ultima modifica di T a u r u s; 24-11-2005 alle 12:25
no, io non scherzo mai quando si parla di auto... Le alpina sono improntate più al lusso che alla prestazione pura, è un dato di fatto...
Ultima modifica di PaTaTO306; 24-11-2005 alle 13:09
mi sembra che diciate allo stesso tempo 2 cose diverse dallo stesso punto di vista, e può benissimo essere che abbiate ragione entrambi... come ne ha Sakis ragione da vendere!!
...peraltro scannarsi x 1/2 decimi di secondo... taurus lo conosciamo, ma anche tu patato nn ne vieni proprio fuori da quell'aria di "ho sempre ragione io": quando i dati ti fanno comodo li usi, altrimenti sono sbugiardati da altre cose. Sei pronto x essere arruolato nella squadra di fabvio, o se preferisci in quella di taurus. Avete lo stesso approccio alle cose. :b26
...rimane cmq il fatto che 4P va + forte di entrambe!!
Ascolta ax.. qua si parla di 2 secondi e tre decimi! E' per quello che sto discutendo perchè i dati sono molto distanti tra loro! Tutto qui.. Io non faccio ne il tifo per maserati ne per M5, mica mi paga nessuno, è che mi piace l'obbiettività e stop.. Come può essere che sulla prova che posta Taurus ci sta solo un decimo tra M5 e B5 e su quella che posto io e Sakis ci sono 2 secondi e tre. E se permetti sono più veritieri i 2 secondi e tre di scarto fra due macchine testate lo stesso giorno che 1decimo in giorni differenti! E ti ricordo che Quattroporte da solo 1.6 secondi a B5. Se gli dava 5 secondi su un giro le chiacchiere stavano a zero, ma per quanto mi riguarda la differenza testata tra B5 e M5 la può anche portare davanti a Quattroporte! E' chiaro ora perchè questa prova crea dibattito? Poi tutto può essere, ma non sono certo i dati di Taurus a fare grande quattroporte, proprio perchè M5 è stata testata in giorni differenti.. Poi mi venisse a dire che quella del test diretto contro M5 era una gondola perchè io a ste cazzate di comodo non ci credo..Originariamente Scritto da ax
le bmw Alpina sono curate nel lusso quanto le motosport per sportivita'!!!esteticamente sono curate nei dettagli per attirare l'attenzione con cerchi smisurati,eventuali appendici areodinamiche e tutto quanto fa' scena ma motoristicamente e nella sostanza sono ben lontane dalle prestazioni di un M.motoristicamente vengono sempre modificate con almeno un turbo(tanto per far scena appunto),quindi meno fruibili in una guida sportiva come puo' essere la M.
due auto paragonate in giorni diversi danno adito a discussioni ovviamente...il ragionamento di Patato,che tu reputi arrogante in pratica,è estremamente corretto secondo il mio modesto parere.
moto:Venduta
