+ Rispondi alla Discussione
Risultati da 1 a 7 di 7
Discussione: Jeep Grand Cherokee 2011
    Pilota Ufficiale
    Dec 2007
    713
    Predefinito Jeep Grand Cherokee 2011
    By autoblog.com:
    First Drive: 2011 Jeep Grand Cherokee redefines the Tipping Point
    In the span of three years, Chrysler has been bought and sold more times than Duke Cunningham. Its warped "merger of equals" with Daimler ended in 2007 and the disastrous reign of incompetence extended into its relationship with Cerberus Capital Management – now a "bad word" within the hallowed halls of Chrysler, according to one exec.
    After filing for bankruptcy in April of 2009, the reformed Chrysler Group partnered with the Italian automaking juggernauts at Fiat and have since rolled out a five-year business plan that's nothing if not ambitious.
    But you didn't come here for an abbreviated history lesson on Chrysler and its failed suitors. You want to find out how your $6.6 billion in federal funding is being spent and if the company's products are finally up to snuff. Well, here's the short version: The 2011 Jeep Grand Cherokee is the first Chrysler product since the 300 that deserves your attention. Follow the jump to find out why.
    La prova completa qui:
    First Drive: 2011 Jeep Grand Cherokee redefines the Tipping Point — Autoblog
    Evidenzio un passaggio in cui si parla del Pentastar (questa è la sua prima applicazione):
    [dopo aver parlato del 5.7 V8]
    So instead, the real focus is the first application of Chrysler's new "Phoenix" V6 – an engine that's set to proliferate through the automaker's lineup over the course of the next year. With 3.6-liters of displacement, an aluminum block, dual-overhead cams and variable valve timing, it makes the old 3.7-liter mill look positively archaic, particularly when scanning the stats. The laughably low 210 horsepower and 235 pound-feet of torque of the outgoing engine has been increased to 290 hp and 260 lb-ft, with peak twist arriving at 4,800 rpm. Fuel economy has improved as well, with a maximum of 23 mpg when cruising on the highway, 16 in the city and a claimed 500 miles of range on a single (24.6-gallon) tank. Naturally, you sacrifice a bit of towing capacity in the process – 5,000 pounds with the V6 or 7,400 pounds with the big boy V8.
    But does it matter on the road? The new six is certainly more refined, spinning smoothly towards the far side of the tach, but failing to provide sufficient passing power on occasion. Blame the GC's nearly 5,000-pound curb weight if you must, but despite the V6's "all-new" designation, it still feels about a half-generation behind the competition. Thankfully, that's where Fiat's tech-infusion will come into play. The Italian automaker's much-hyped MultiAir valve-actuation system is netting significant increases when fitted to existing engines. A Chrysler engineer we spoke with expects a 10-to-15 percent boost in output when it's fitted to the Phoenix, so power is set to increase to compete with the newest sixes from Ford, GM and others. When it's finally going to arrive, though, remains to be seen.
    Complessivamente la valutazione è più che buona.
    E IMHO esteticamente è il miglior SUV/fuoristrada finora, con tutto che questo genere di auto non mi piacciono proprio...
    Solo il posteriore forse è un po' anonimo (koreano? Mi viene in mente Ssanggyong)
    La mia auto: Fiat Punto mk2b (restyling) 1.3 Multijet Dynamic 5p
    Team Manager L'avatar di Dannatio
    Apr 2009
    Bologna
    3.625
    Predefinito Re: Jeep Grand Cherokee 2011 - Prova su strada
    Quanto, quanto mi piace quest'auto!!!!!!!!
    Leader del campionato
    Aug 2008
    1.379
    Predefinito Re: [TEST STAMPA] Jeep Grand Cherokee 2011
    Altra prova su strada
    2011 Jeep Grand Cherokee Overland 4x4 V6 Full Test
    The Long, Slow Trail Back
    By Daniel Pund, Grand Senior Editor, Detroit | Published Aug 2, 2010
    For all our expansive coverage of the 2011 Jeep Grand Cherokee, we have failed to answer the question central to the meaning of the model's existence:
    If no Cherokee currently exists, how could a Grand Cherokee exist? How does one modify something that does not exist?
    Doesn't logic dictate that the model be called the Grand Liberty, or the Grand Grand Patriot?
    We have found the answer and we shall reveal it to you later. First, however, we will try to stitch together what we have already written about the most important and also grandest Jeep in many a year.
    You see, we took loan of a generously named Jeep Grand Cherokee Overland 4x4 V6, slathered in lovely Blackberry Pearlcoat. We tested it with our high-zoot, GPS-based data-gathering apparatus, we commuted in it, we photographed it and we broke down in it. And we are ready to pass judgment on it.
    Grandiloquent Intro Complete
    It is the considered opinion of the Inside Line crew that this Grand Cherokee is the first of its namesakes to earn the modifier in some time.
    It is, first, grand in a physical sense. This Grand Cherokee rides on a wheelbase 5.3 inches longer than that of the model it replaces, and is a suitably luxurious vehicle. For example, a 2011 Jeep Grand Cherokee driver needn't keep one eye on the rear of the cabin out of fear that backseat passengers will mutiny. There is actually passenger room in back now. Longer rear doors, especially on the bottom, aid greatly in getting in and out of the vehicle, too.
    Why, we were able to ride behind a simulated version of ourselves and we are, at 6 feet 2 inches semi-grand ourselves. With the driver seat set at our preferred driving position, we could sit in the second row with only the slightest bit of knee-grazing. We love that the rear seats (manually) recline even if only by a few degrees, just enough to relieve back stress on long trips.
    In fancy-pants Overland form, the 2011 Grand Cherokee is genuinely, no-BS nice.
    Cargo space behind the second row grows from a frankly poor 29.5 to a slightly better 35.1 cubic feet. That still trails some of the Grand Cherokee's most frequently cross-shopped rivals, but it's at least enough to fit our mountain bike without removing the front wheel and with only part of the rear seat folded.
    And yes, we, which is to say I, live in Detroit and still call it a "mountain bike," instead of the more accurate "ride-up-to-the-ice-cream-stand-at-the-corner bike." It's an aspirational thing, sort of like the existence of all this off-roading gear that weighs down our Grand Cherokee test vehicle to the tune of 5,048 pounds.
    When the IRS Came Calling
    It wasn't long ago that the Grand Cherokee seemed like a throwback with its live rear and front (!) axles. Even the origami-inspired 2005-'10 model stuck with the stick axle in the rear after other major competitors in the luxurious SUV segment had switched to independent rear suspension.
    Well, the 2011 Jeep Grand Cherokee proves that at least one thing went right for the Jeep brand in the dark days of German-led product planning that resulted in hits such as the Commander and that double-barrel blunder Compass/Patriot.
    Borrowing the independent rear suspension of the Mercedes-Benz M-Class ute and offering for the first time an adjustable air suspension, the grandest Jeep finally is fully modern. The improvement to its on-road ride quality, particularly wearing the 18-inch wheels with their ample sidewalls, is stunning. Like the Mercedes ML vehicles with which it shares much of its suspension design, the Grand Cherokee prioritizes cushiness over control.
    Our flat-out loaded Overland includes Jeep's Land Rover-like Selec-Terrain system. Controlled by a console-mounted rotary knob, this system tailors the settings for a number of systems including the adjustable air suspension for the driving condition the driver tells it he's experiencing (Snow, Sand/Mud, Rock, Montessori school parking lot, et cetera). It was a great idea when it appeared on Land Rovers years ago and it remains so on the Grand Cherokee.
    It might not have been Jeep's idea, but Selec-Terrain does at least carry on Jeep tradition of dropping the "t" from the tail-end of "select." The system also has a Sport setting, which drops the body to a level usually reserved for high-speed travel. Every time we got into the vehicle, we dialed up Sport and wondered why we couldn't just leave it there. There's little ride degradation and there's both a subjective and measurable improvement in the vehicle's handling prowess.
    The 2011 Jeep Grand Cherokee, as optioned, ran the slalom at 59.4 mph while what our tester described as feeling "stable, safe and highly managed" was thanks in part to the nondefeatable stability control system. That speed puts the JGC in a slalom dead heat with the Ford Flex, Honda Pilot and Toyota Highlander. Not bad.
    For those that would like to control their own low-range gearing and keep electronics out of their trail ride, there's always the electro-phobic Wrangler.
    That's Racing for Ya
    When we published the test-track numbers we gathered for this Grand Cherokee, the truck took a merciless beating. The refrain went something like, "9.0 seconds to 60 mph? What a pile!"
    Perhaps it would help put the Jeep's performance in perspective if we pointed out that according to Jeep, a 2010 Grand Cherokee with the old 3.7-liter V6 strained to make 60 mph in 10.5 seconds. Or that 9.0 seconds (or 8.7 seconds with 1 foot of rollout as on a drag strip) makes this Jeep Grand Cherokee the better part of a second quicker than a Honda Pilot or dead even with a Ford Flex. Still, it's almost a second slower than a Toyota 4Runner.
    Yes, we're well aware that the family-oriented, three-row Flex is not a competitor for the luxury off-roader Jeep. That the (non-EcoBoost) Flex and JGC V6 post essentially identical number in acceleration, braking and handling tests illustrates a point worth remembering. Porsche recently decided that having the weight penalty of off-road capability was wrong for the Cayenne (duh!). It makes a whole lot more sense on a Jeep, particularly when it's optional.
    There remains no free lunch. Whether a vehicle carries the size to package a third row of seats or the gear (and weight) brought by easy off-road capability, there's a performance price to be paid. In this case (JGC vs. Flex), one pays an essentially identical price, literally and figuratively.
    Solid Engine, Tall Gearing
    Clearly, the Jeep's super-tall rear gear (3.06:1) does the Grand Cherokee, and its new 290-horsepower 3.6-liter DOHC V6, no favors at the drag strip. But it does help return EPA estimates of 16 city/22 highway mpg. Jeep used to put a more aggressive gear on 4x4 V6 Grand Cherokees than it did on the rear-drive version. With the new Pentastar V6, the company feels it can pull the efficiency-minded gearing.
    We've got no issue with the numbers, this being a truck with better-than-adequate acceleration. We note, however, that despite its decent 260 pound-feet of torque, the 3.6-liter feels a bit thin on shove at low revs. This should be less of a consideration as this and variations of this engine make their way into Chrysler Corp. vehicles that don't weigh 2.5 tons.
    You could always get the Hemi, we suppose. But increasing the V6 Grand Cherokee's tow rating (with an optional towing package) to 5,000 pounds — up 1,500 pounds from last year — should increase the V6's share of JGC sales.
    Yeah, America!
    The Italian-American Chrysler Corporation has played the patriotism card aggressively in advertising this vehicle, the origins for which are at least partly German. It's about American quality and craftsmanship and so forth and so on.
    This would be criminally disingenuous if the company said this about the terrible interior of the previous Grand Cherokee. In fancy-pants Overland form, the 2011 Jeep Grand Cherokee is genuinely, no-BS nice. The stitched dash cover, the positive and consistent switchgear operation and the excellent panel fit back up the company's grandiose claims. Our only complaint about the interior is the wood-and-leather-covered steering wheel rim that is thick as a full-grown man's wrist. Why, Jeep? Why?
    Our test vehicle came loaded with $1,295 worth of electronic doodads that aim to do a bit of driving for you. Bundled in a package are adaptive cruise control, blind spot monitoring and forward collision warning. All of these things work and we commend Jeep for offering them on this luxury vehicle, but we still find them largely annoying and unnecessary.
    There's one potential fly in the apparent-quality ointment, though. You see the photographs above of the vehicle on the dusty roads? Yeah well, our test vehicle and at least one tow-truck driver became all too familiar with those remote roads after the Jeep's power-steering pump took a dump. Fine, we figured, we'll get it back to civilization without power steering. We are hearty like that.
    This worked until the Jeep threw its serpentine belt. Game over. This, we discovered, was due to a power-steering pump that had been loose for "some time." We were told this was an early-build vehicle. Maybe so, but subsequent Grand Cherokees better get built right or Jeep is going to have a problem.
    The Grand Finale
    Much delayed and clearly not faultless, the 2011 Jeep Grand Cherokee is nonetheless an attractive, capable and genuinely grand thing. It is finally the budget Land Rover that the nameplate long promised. At a fully optioned price of $43,695, about the only thing this top-shelf example doesn't include is the Hemi V8. And we're not convinced you really need that. Or at least you're less likely to need that than you did with last year's model.
    Given that the Grand Cherokee's development began two corporate administrations ago, we're not sure what the new GC indicates about future vehicles from the current company. We know that if buyers give the new one a fair shake and if Jeep can manage to build them with the quality that the new interior hints at, then the short-term future for Jeep looks considerably brighter.
    Oh right, we promised you an answer to the grand modifier conundrum, didn't we? Right. Well, by the statute commonly referred to as the "Grand Central Station rule," a thing of sufficient grandeur may, under certain circumstances, be referred to in casual company and/or for commercial purposes as "grand" without a comparatively un-grand relative. Void where prohibited.
    Track Test Results
    Acceleration, 0-30 mph (sec.) 3.5
    0-45 mph (sec.) 5.8
    0-60 mph (sec.) 9.0
    0-75 mph (sec.) 13.1
    1/4-mile (sec. @ mph) 16.6 @ 85.6
    0-60 with 1 foot of rollout (sec.) 8.7
    0-30 mph, trac ON (sec.) 3.7
    0-45 mph, trac ON (sec.) 5.9
    0-60 mph, trac ON (sec.) 9.1
    0-75 mph, trac ON (sec.) 13.2
    1/4-mile, trac ON (sec. @ mph) 16.6 @ 85.6
    0-60, trac ON with 1 foot of rollout (sec.) 8.8
    Braking, 30-0 mph (ft.) 31
    60-0 mph (ft.) 125
    Slalom, 6 x 100 ft. (mph) ESC ON 59.4
    Skid pad, 200-ft. diameter (lateral g) ESC ON 0.72
    Sound level @ idle (dB) 40.5
    @ Full throttle (dB) 77.2
    @ 70 mph cruise (dB) 66.2
    Engine speed @ 70 mph (rpm) 1,900
    Test Driver Ratings & Comments
    Acceleration: Weak. Long, tall gearing is painfully obvious when accelerating quickly. Fortunately, the engine is willing to rev, but should it have to in this midsize SUV application?
    Braking: Relatively long-travel, soft pedal, but consistent distances and stable performance. It stays straight, too, with no wandering.
    Handling => Skid pad: Highly managed. Even with stability "off" (it's not fully off) in Sport mode, this is a stomp-and-steer procedure. Just hold your foot at a constant throttle opening and steer. "Driving" doesn't actually help much. Slalom: Feels stable, safe and highly managed here as well. Sport mode does expand the handling limits over Auto mode, but expect this Jeep to simply go where it's pointed within the threshold of physics.
    http://www.insideline.com/jeep/grand...and-video.html
  4. #4
    Pilota Ufficiale
    Dec 2007
    713
    Citazione Originariamente Scritto da wilderness Visualizza Messaggio
    Sono curioso di sapere cos'è "1 foot rollout"... Chi lo sa?
  5. #5
    May 2005
    MI+BG
    38.795
    Citazione Originariamente Scritto da andrea.ippo Visualizza Messaggio
    In pratica fanno partire la misurazione del tempo di accelerazione dopo che la ruota ha percorso 1 piede (30 centimetri) dalla posizione di partenza, con una procedura simile a quella usata nelle gare dei dragster. Nel caso dei dragster dovrebbe essere uno stratagemma per non considerare i tempi di reazione nel computo del tempo di accelerazione. Nel caso della prova dello 0-100 immagino serva un po' per quello e un po' per ripulire il dato dello 0-100 da errori vari dovuti a movimenti della vettura, piccoli pattinamenti, ecc.
  6. #6
    Pilota Ufficiale
    Dec 2007
    713
    Grazie
  7. #7
    Giovane Promessa L'avatar di Drillerman
    Jul 2009
    Riva destra del Po
    312
    Amme me piace!
    Trovo che sia un veicolo troppo grosso per le nostre città ma tutti i possessori di sti bestioni non la pensano così
    Se da questo ne tirassero fuori una versione identica ma ridotta, tipo l'evoq (mamma mia quanto è bello) imho riscuoterebbe non poco successo
  1. Jeep Grand Cherokee SRT-8 (Spy)
    Di Beckervdo nel forum Rumors & Spies
    Risposte: 3
  2. Jeep Grand Cherokee 2011
    Di andrea.ippo nel forum Jeep
    Risposte: 6
  3. Jeep Grand Cherokee SRT-8 (Photoshop)
    Di Touareg 2.0 nel forum Rumors & Spies
    Risposte: 14
  4. Jeep Grand Cherokee (Spy)
    Di JOKEJOE nel forum Rumors & Spies
    Risposte: 19
  5. Jeep Grand Cherokee...
    Di Touareg nel forum Rumors & Spies
    Risposte: 25
grand cherokee 2011
prova jeep cherokee 2011
PROVA GRAND CHEROKEE 2011
jeep grand cherokee 2011
jeep compass prova su strada
forum grand cherokee 2011
grand cherokee 2011 prova
jeep grand cherokee forum
prova su strada jeep grand cherokee
jeep grand cherokee overland prove su strda
jeep vrangler
jeep grand cherokee 2011 0-100
Grand Cherokee
grand cherokee 2011 test
2011 Jeep Grand Cherokee 0-100nuova grand cherokee 2011grand cherokee 2011 prova su stradagrand cherokee 2011 beschleunigungautopareri.com forum gran cherokeetutti le nuove auto chreysler - fiat 2011 parisjeep grand cherokee provajeep grand cherokee 3.6 0-100prova jeep grand cherokeejeep grand cherokee 2011 opinionigrand cherokee 3.6 de 0-60 mph
Tag per Questa Discussione
