| Registrazione | FAQ | REGOLAMENTO | Tu su Googlemaps | Lista utenti | Calendario | Arcade | Cerca | I messaggi di oggi | Segna i forum come già letti |
| Avvisi |
| Sport motoristici Formula 1, rallye... |
| | LinkBack | Strumenti discussione | Modalità visualizzazione |
| | #2 (permalink) |
| HALL OF FAME Moderatore Data registrazione: 01/03/04 Località: bari
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | Technical Specifications BMW 320si WTCC. ![]() ![]() FACTBOX Length 4,539 mm Width 1,858 mm Height approx. 1,350 mm Wheelbase 2,760 mm Vehicle weight 1,140 kg (with driver) Tank capacity approx. 45 litres In 2007, the BMW 320si WTCC entered the Touring Car World Championship as the defending champion. Like in the year before, the dynamic racing car provided Andy Priaulx of BMW Team UK with a further drivers’ championship title while BMW was once more able to defend the manufacturers championship.The BMW 320si WTCC was developed by BMW Motorsport in Munich using the same template as the series model of the same name. It took just nine months to create a new car that was competitive right from the start. In the very first WTCC event of the 2006 season in Monza, Andy Priaulx clinched pole position and victory in round one. Ten more triumphs followed over the course of the year. This car is the youngest offspring of the successful BMW 3 Series that has been celebrating title glory in international touring car racing for several decades. BMW has now won 24 European titles. Every World Championship title to date has gone to Munich. The 280 bhp BMW 320si WTCC is the racing version of the special model BMW 320si. The motorsport version of the BMW 320si is driven by a powerful 2-litre four-cylinder in-line engine. A race kit can be purchased by BMW customer teams aroudn the globe. The 320si not only competes in the FIA WTCC, but in numerous national championships as well. BMW Motorsport Director Mario Theissen says, “Touring cars without BMW is unthinkable – and BMW is equally unthinkable without touring cars. This is what made the brand grow, and we will stick to this tradition. Apart from works support we have always been keen to keep racing affordable for our customers and at the same time offer a high-performance package. This tradition is now continued by the racing version of the new BMW 3 Series. I am sure that this model will write further chapters of BMW’s successful history.“ ![]() ![]() ![]() ![]() ![]() ![]()
__________________ "Ci farò un salvadanaio con la tua testa" disse l'UOMOMAZZA a chuck norris |
| | #3 (permalink) |
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | HONDA ACCORD EURO R SUPER 2000Technical information Engine: Front transversal, 4 cylinders in line Capacity: 1.998cc Compression ratio / Valve lift: 11 : 1 – 11 mm Fuel: Electronic fuel injection Intake:Single throttle (diam. 64mm)Data acquisition:Magneti MarelliTraction: Front wheel drive Clutch: Sachs Racing carbon single discs Gearbox:XTRAC 6 speed + reverse, sequential Differential: XTRAC adjustable mechanical limited slip differentialBrakes:Front: Brembo discs, Alcon callipers Rear : Brembo discs and callipersSuspensions: 3-way adjustable shocks absorbers Front: double wishbone arms Rear: multilink Wheels: Aluminium alloy wheels 9 x 17 inches Aerodynamics:Front splitter (80mm from the ground) Adjustable rear spoilerDimensions Lenght / width / wheelbase (mm): 4665 / 1831 / 2677 Weight (kg): 1.140 (driver included)
| | #4 (permalink) |
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | ALFA ROMEO 156 SUPER 2000 Technical information Engine: Front transverse, 4 cylinders in line Capacity: 1.998cc Power: 275cv at 8.450rpm Fuel: Electronic fuel injection Intake: Single throttle (diam. 64mm) Traction: Front wheel drive Clutch: Carbon double discs (diam. 184mm) Gearbox: 6 gear + reverse, sequential, front wheel drive Differential: N.Technology mechanical limited slip differential Brakes: Front: 330mm ventilated discs, 4-pot calipers Rear: 278mm discs, 2-pot calipers Brake bias adjustable on pedal box Rear brake bias adjustable by driver Steering: Rack and pinion, with electric pump servo assistance Suspensions: 3-way adjustable shocks absorbers Front: Double wishbone arms Rear: MacPherson strut Wheels: Aluminium alloy wheels 9 x 17ins Aerodynamics: Front splitter (80mm from the ground) Adjustable rear spoiler Weight:1.140kg (driver included)
| | #6 (permalink) |
| Pilota Ufficiale Data registrazione: 05/06/07 Località: Brescia
Nominated 0 Times in 0 Posts TOTW/F/M Award(s): 0 | Aggiungo le specifiche della Seat Leon turbodiesel SEAT Leon TDI WTCC Specs Engine Type Turbocharged; 4-cylinder in line, transversally installed; distribution: two overhead Distribution Two overhead camshafts, 16 valves. Displacement 2.000 cc Bore x stroke 81x95,5 mm Maximum power 280 CV a 4000 rpm Maximum torque 450 Nm a 2500 rpm Lubrication Wet sump Particle filter Dow Automotive Transmission Traction Front-wheel drive Gearbox Hewland 6-speed, sequential shift Clutch Twin-plate Differential Mechanical limited slip differential Chassis Front suspension McPherson strut, coil springs, gas-filled dampers, anti-roll bar Rear suspension multi-link axel, coil springs, gas-filled dampers, anti-roll bar Steering Power assisted rack and pinion Brakes Type Not-assisted dual circuit system Front brakes 4-piston calipers, 332 mm steel ventilated discs Rear brakes 2-piston calipers, 280 mm steel discs Dimensions Length 4330 mm Width 1849 mm Wheelbase 2600 mm Minimum weight 1170kg (including driver) Rims / Tyres Rims / Tyres 9x17 / Yokohama 240/610 R17 ![]() |
| Segnalibri |
| Strumenti discussione | |
