Risultati da 1 a 2 di 2
Discussione: Ufficiale: Hyundai Genesis PM580 Pikes Peak Climb
    HALL OF FAME L'avatar di Beckervdo
    May 2009
    Salerno
    5.054
    Predefinito Ufficiale: Hyundai Genesis PM580 Pikes Peak Climb
    Details and photos have emerged about RMR's Hyundai Genesis PM580 race car.
    Built by Rhys Millen Racing (RMR), the PM580 will compete in the Pikes Peak International Hill Climb on June 27th. Looking like a Le Mans prototype, it features a tubular frame chassis, a carbon fiber body, and a Brembo braking system.
    Power is provided by a turbocharged 4.1-liter V6 engine with up to 750 hp (559 kW / 760 PS). Connected to a Weismann semi-automatic AWD transmission, power is channeled to the ground via an active center differential. It allows for a "10-100 percent torque split to the front wheels" which is important "because the course changes from asphalt to dirt multiple times."
    If everything goes according to plan, Rhys Millen will complete the 12.42 mile (20 km) course in less than 10 minutes.
    Source: insideline.com
    Press Release
    •Hyundai unveiled its new RMR Genesis PM580 racecar.
    •Rhys Millen will campaign the car at Pikes Peak on June 27.
    •The RMR Genesis PM580 is capable of producing 750 horsepower.
    FOUNTAIN VALLEY, California - Hyundai on Monday took the wraps off the highly anticipated RMR Hyundai Genesis PM580, saying that the new racing car is "capable of producing 750 horsepower." The car, which was fabricated by Rhys Millen Racing, will compete in the Pikes Peak International Hill Climb on June 27.
    The Korean automaker had teased the RMR Hyundai Genesis PM580 late last week via a moody, black-and-white video that only showed bits and pieces of the vehicle.
    Monday's information laid out the vehicle's specifications - up to a point - and its inspiration.
    Rhys Millen Racing said the RMR Hyundai Genesis PM580 is patterned after "a modern Le Mans-style car." It has a target weight of 1,850 pounds and is powered by a 3.8-liter Hyundai Lambda turbocharged V6 stroked to 4.1 liters. Although Hyundai skirted the issue of precise engine specifications, the automaker said that "current engine testing shows the engine is capable of producing 750 horsepower, which is more than needed to tackle the mountain." It also noted that to have a competitive power-to-weight ratio, the team feels "the car will need to produce 675 horsepower."
    The Korean racer has a carbon-fiber aerodynamic body with an active rear wing and front and rear diffusers. It also will use an active center differential. "This differential will allow a 10-100 percent torque split to the front wheels," said Hyundai. "This is important because the course changes from asphalt to dirt multiple times and allows the Genesis PM580 to have more than one setup on the 12.42-mile course."
    Rhys Millen said he will attempt to set an under-10-minute new world record at the course. "This is the package I need to break the record," he said in a statement.
    Other details on the racing Genesis include a chromoly frame and roll cage, a Weismann semi-automatic AWD transmission, Tilton racing clutch, carbon-fiber Brembo brakes and pads and Toyo Proxy tires.
    Team Manager
    Oct 2003
    Zurigo
    3.732
    Predefinito Re: Ufficiale: Hyundai Genesis PM580 Pikes Peak Climb
    Non sapevo che si poteva fare questo tipo di macchina per correre a pikes peak.
    http://www.autopareri.com/forum/image.php?type=sigpic&userid=259&dateline=12788477  90 "The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt." -Bertrand Russell
  1. Risposte: 32
  2. Hyundai Genesis (Topic Ufficiale)
    Di Touareg 2.0 nel forum Hyundai
    Risposte: 31
  3. Hyundai Genesis (Spy)
    Di Touareg 2.0 nel forum Rumors & Spies
    Risposte: 84
  4. Pikes Peak
    Di Tommitel nel forum Off Topics
    Risposte: 0
  5. Audi Pikes Peak
    Di maxsona nel forum Rumors & Spies
    Risposte: 39
3
5
2
1
hyundai pm 580 pikes peak car chassis
10
hyundai prototypes pikes like
pm580
hyundai genesis suisse
frame chassis RMR Hyundai Genesis PM580
52
66
36
Hyundai RMR PM580 pikes peak italianoforum hyundai genesisautopareri hyundai genesishyundai pm 5807hyundai genesis pikes peakGenesis PM580pikes peak Chassishyundai pikes peakPM580 Weismann rhys millenpikes peak rhys
