Pagina 1 di 3 123 UltimaUltima
Risultati da 1 a 10 di 21
Discussione: Sistema di frenata automatica Volvo: nuova dimostrazione fallita
    May 2005
    MI+BG
    40.045
    Verrebbe da dire "Oops, I did it again!".
    Dopo la dimostrazione di frenata automatica di qualche mese fa in cui una Volvo S60, invece di frenare, era tranquillamente andata addosso al camion messo come ostacolo in una dimostrazione alla stampa, Volvo è di nuovo incappata in una figuraccia di fronte ai giornalisti.
    In una dimostrazione a giornalisti Australiani, una Volvo V60, col nuovo sistema di rilevamento pedoni e frenata automatica, ha fallino il 25% delle prove, investendo in maniera abbastanza violenta il manichino posto come ostacolo.
    Per la precisione in 2 dei test il sistema sembra aver rilevato tardi l'ostacolo e in un caso non sembra averlo rilevato affatto.
    da noticiasautomotivas
    Citazione Originariamente Scritto da caradvice.com.au
    A number of significant crashes took place during the botched demonstrations, which were conducted for ‘photo opportunity’ purposes at a press event held for the Australian media last week.
    In total, 25 per cent – or one in four – of the Australian media’s demonstration runs saw the new Volvo S60 violently clean up a simulated pedestrian with enough force to cause significant trauma in a live pedestrian.
    One Australian participant in the botched tests described the simulated pedestrian impacts as taking place with “sickening force” and in a manner that “would almost certainly have been a bone-breaking impact” if the pedestrian had been a real person.
    The demonstrations, held in Europe, used a mannequin (jovially named ‘Bob’) in place of a person – thankfully. In one run, a Volvo instructor was driving and in the others journalists were at the wheel, with a Volvo instructor carefully monitoring the approach speed. In two of the tests, apparently, the system recognized ‘Bob’ much too late to avoid impact despite approach speed being within the system’s impact-avoidance limits. In the third test, it’s claimed, the system failed to recognize ‘Bob’ at all.
    The pedestrian-braking system uses radar, a camera and advanced software to deal with – or not, as it happens – the serious problem of pedestrian impact, which comprises about one-eighth of Australia’s road toll. If the system reacts and the speed it too high, Volvo claims impact will be unavoidable – but at least speed and therefore trauma will be ameliorated.
    According to respected Australian motoring journalist Steve Colquhoun, after the first crash a Volvo spokesperson initially alleged that a tractor and trailer parked approximately 30 metres behind ‘Bob’ might have confused the system. Mr Colquhoun says that a further two impacts with ‘Bob’ took place after the tractor/trailer combination had been removed – including the run in which the automatic system did not react to ‘Bob’s’ presence at all.
    The event is certainly an embarrassing one for Volvo, which claims that in total around 650 media participated in the week-long demonstration – with a claimed 99.7 per cent success rate – the nature of the failed 0.3 per cent of runs appears to be undisclosed.
    While Volvo’s position remains that the fledgling technology is unable to prevent all pedestrian impacts, in part because the system’s effectiveness is compromised by low light and/or inclement weather, Mr Colquhoun has reported that the demonstration was conducted in, apparently, ideal conditions – and on a test track carefully selected by the company for this sole purpose.
    In a subsequent statement Jonas Pisell, who manages Volvo’s active safety systems claimed: “The failure of the test was due to the dummy not being set up properly.” He described the dummy as: “not relevant in this situation”. Video of one of the three demonstration crashes shows the dummy clearly in front of the evaluation vehicle.
    This is not the first time a Volvo automatic braking demonstration has gone horribly – and very publicly – wrong. Volvo has had an appalling run with demonstrations of its automatic braking technology in 2010. Earlier this year, in another international media demonstration held in Volvo’s homeland – Sweden – its rear-end collision prevention system dubbed City Safety failed to deploy, causing the demonstration vehicle to plow into the rear of a truck. It suffered significant damage. After that mishap the company claimed the malfunction was due to a low-voltage event in the vehicle’s electrical system, and has (it claims) fixed the flawed software that allowed the City Safety system’s un-commanded shutdown to occur.
    Ultima modifica di J-Gian; 06-10-2010 alle 02:22
    o chi lo sa...
    Oct 2006
    11.428
    Predefinito Re: Sistema di frenata automatica Volvo: nuova dimostrazione fallita
    Il problema di quei dispositivi è la rete di rilevazione: richiede una capacità di trasmissione dati tra i sensori e la centralina pari a quella di un lettore DVD (siamo nell'ordine del gigabyte/secondo) ed una robustezza ai disturbi che nessun dispositivo con una simile banda è capace di offrire.
    Purtroppo non sono ancora passati i fatidici dieci anni per capire quale tecnologia adottare per massimizzare la robustezza del sistema.
    World Championship Winner L'avatar di Felis
    Jan 2008
    Ducatus venetus
    1.666
    In che mondo viviamo? Se le Volvo non sono più l'emblema della sicurezza rimaniamo senza certezze.
    2002-2008: 147 | 2008* 120d
    «La 500 in America? Cavolata enorme»
    «Abbiamo valutato male le difficoltà che c'erano e ci siamo dati volumi troppo alti. Inoltre abbiamo avuto problemi nel creare una rete di distribuzione. Ora saremo più cauti nel lanciare nuovi brand italiani negli Usa».
    Fiat CEO dixit
  4. #4
    HALL OF FAME L'avatar di Jack.Torrance
    Jan 2006
    Perugia
    5.055
    Boh...
    Io l'ho provata domenica è si è fermata senza problemi.
    Domani torno al conce e chiedo se mi fanno fare un ciclo di 100 prove.
    P.s.
    L'auto è ottima, imho.
    Bello il Kinetic Design....
  5. #5
    HALL OF FAME L'avatar di Beckervdo
    May 2009
    Salerno
    5.054
    Provato il Pedestrian per due volte e si è bloccata senza problemi
    Comunque si deve comprendere che è una telecamera che simula l'occhio umano: se è sporco il sensore, se c'è pioggia forte, se c'è nebbia, non vede una fava!
  6. #6
    May 2005
    MI+BG
    40.045
    Citazione Originariamente Scritto da Beckervdo Visualizza Messaggio
    I test falliti sono stati fatti su pista apposita scelta da Volvo, in condizioni ottimali e controllate. Quello è confermato.
    E le auto stesse non erano guidate dai giornalisti, a quanto pare, ma da collaudatori Volvo.
    o chi lo sa...
  7. #7
    Jan 2008
    Ducatus venetus
    1.666
    Forse non funziona con i manichini ma solo con persone in carne ed ossa?! Brividi.
    Fiat CEO dixit
  8. #8
    Oct 2006
    11.428
    No, il problema è un altro: nell'ambito dell'elettronica esiste una precisa trafila di collaudo che, per questo sistema non può essere rispettata.
    Prima una nuova tecnologia debutta nell'elettronica di consumo. Poi, quando dopo una decina d'anni circa ha dimostrato d'essere affidabile oltre ogni ragionevole dubbio, viene impiegata, con le dovute modifiche, sui sistemi un po' più critici dal punto di vista della sicurezza; quali i mezzi di trasporto terresti. Dopo altri dieci anni circa viene ulteriormente modificata per poter essere impiegata sui sistemi ancor più critici; i velivoli, che infatti oggi utilizzano i processori impiegati nei calcolatori trent'anni fa.
    Purtroppo però la tecnologia sviluppata dalla Volvo è costretta ad impiegare i sistemi dei comunicazione a banda larga che sono stati sviluppati solo di recente e quindi, avendo pochissimi anni di collaudo alle spalle, sono molto meno robusti ai disturbi; da qui il succitato 25% di fallimenti.
    Ciò non deve essere ritenuto un male poiché, se tale dispositivo fosse impiegato su tutte le auto, ridurrebbe del 75% gli investimenti fatti contro i pedoni e soprattutto non deve essere ritenuto come una scusa per guidare con meno attenzione; anche se, conoscendo l'umana idiozia, avverrà proprio l'opposto.
  9. #9
    May 2005
    MI+BG
    40.045
    Citazione Originariamente Scritto da Felis Visualizza Messaggio
    Se vuoi offrirti volontario, in Volvo ti aspettano...
    Tral'altro, se non ho letto male, la dimostrazione in questione è stata fatta in Italia.
    o chi lo sa...
  10. #10
    Mar 2003
    genova
    18.675
    Solo come nota: ancora piu' restrittivo e' l'uso aerospaziale, dove come esempio solo con l'ultimo volo della Sojuz e' andato in pensione questo
    Argon-16 Computer. Argon Family of Computers. Russian Virtual Computer Museum. English version. Articles.
    Che era il sistema di guida e posizionamento automatico analogico/digitale.
    Leggetevi con attenzione le caratteristiche, soprattutto il peso..
  1. Sicurezza Attiva [Sicurezza Attiva] AEBS - Advanced Emergency Braking Systems - La frenata Automatica
    Di J-Gian nel forum Tecnologie per la Sicurezza ed Elettronica
    Risposte: 7
  2. La BBS è fallita
    Di mmaaxx nel forum Mercato, Finanza e Società
    Risposte: 7
  3. Dimostrazione moto polizia anni 50
    Di fulvio nel forum Moto
    Risposte: 4
  4. Sony, nuova falla in altro sistema anticopia
    Di DESMO16 nel forum Scienze & Tecnologie
    Risposte: 0
  5. Risposte: 9
freno automatico
sistema di frenata automatica
sistema frenante automatico
sistema automatico di frenata
nuova volvo s 60 il sistema automatico di fremata
frenata automatica
frenata automatica volvo
test volvo frenata
2
volvo sistema di frenata automatica
sistema di frenatura automatico
volvo sistema frenante automatico
test freni volvo
dimostrazione di una centralina
le volvo sono buone macchine
abs dimostrazione
sistema freni volvo
10
impianto sony volvo v60
sistema frenata automatica
city safety volvo test 2010
volvo ostacolo
sistema automatico frenata
dimostrazione auyo con a b s
Volvo city safety system
Tag per Questa Discussione
