Risultati da 1 a 6 di 6
Discussione: Volvo Pulls a Concept Out of Thin Air - Prototipo ad aria compressa di Volvo
    ACS
    ACS non è collegato
    BANNED L'avatar di ACS
    Oct 2004
    Bannockburn
    17.634
    Predefinito Volvo Pulls a Concept Out of Thin Air - Prototipo ad aria compressa di Volvo
    Volvo Pulls a Concept Out of Thin Air | Autopia | Wired.com
    Among the reasons we love the L.A. Auto Show is the yearly display of outlandish concepts that is the Design Challenge. Compared to a Maybach rickshaw and a robot-knit Benz, Volvo’s entry is a breath of fresh air.
    The Air Motion Concept is a sub-1,000-pound four-seater that’s enclosed in a carbon-fiber clamshell. Instead of an internal combustion engine or an electric motor, the Air Motion is powered by a tank full of compressed air. To tackle overall emissions, Volvo envisions wind-powered refueling stations so that power for the car comes entirely out of thin air.
    According to Volvo, the design study is based on the philosophy of “minimizing weight and complexity while maximizing driver enjoyment.”
    They’re serious about minimizing complexity. Because a pneumatic engine doesn’t heat up like an internal combustion engine would, Volvo says all that plumbing for a radiator isn’t necessary. Of course, they don’t mention a heat exchanger or the limited range possible from a fuel with such a low energy density.
    Volvo isn’t offering performance stats, but we imagine that a car that weighs so little would be fun to drive even if you had to wind it up first.
    A scale model of the car will be on display during the entire auto show, though the Design Challenge Competition winner is due to be announced tonight at 7 p.m. local time.
    Fonte: wired.com
    Mar 2003
    genova
    18.675
    Predefinito Re: Volvo Pulls a Concept Out of Thin Air - Prototipo ad aria compressa di Volvo
    ho paura che finirà come tutti i prototipi ad aria compressa..con il polmoncino d'espansione congelato ( pv = NRT )
    Se però riescono a risolvere il problema del raffreddamento dovuto all'espansione del gas, tutto è possibile.
    Nov 2003
    Piasëinsa
    26.651
    Citazione Originariamente Scritto da stev66 Visualizza Messaggio
    Quoto ho capito in 3° superiore che le auto ad aria compressa sono belle sulla carta ma ben lontano dall'essere progettabili in tempi brevi
    Tutto può essere,certo in 200 anni di Fisica Tecnica ci siamo sempre ingegnati su come dissipare alte temperature (o sfruttare il calore dissipato) e non basse temperature
    Il mio timore però è che per aggirare questo piccolo ostacolo della fisica si vada a complicamere enormemente il propulsore, svilendo un pò il suo scopo originale
    花は桜木人は武士
  4. #4
    May 2005
    MI+BG
    40.045
    Non riesco a pensare ad un sistema meno efficiente di stoccare energia.
    Per non parlare del problema atavico delle vetture ad aria compressa: il gas espandendosi si assorbe una mole notevole di calore e se non usi resistenze o riscaldatori ausiliari si ghiaccia tutto. Ovviamente aggiungendo batterie e/o carburante al giochino, che non diventa più tanto "verde".
    o chi lo sa...
  5. #5
    Apr 2004
    Treviso
    28.603
    D'interessante in questo prototipo c'è il peso: 454 kg. Ovvio che il modo in cui viene ottenuto è poco praticabile, e con una configurazione del genere è anche poco utilizzabile l'auto: aperta, no clima... Insomma, un interessante prototipo da gara e nulla più
    Curioso di sapere come hanno realizzato il propulsore, perché funzioni l'espansione dovrebbe essere molto lenta, il che si traduce in poca potenza: se lo scopo è gareggiare tra le auto ZEV ci sta, per altri utilizzi è improponibile
  6. #6
    HALL OF FAME L'avatar di Beckervdo
    May 2009
    Salerno
    5.054
    Fa parte del concept Design Challenge di L.A. (vedasi Mercedes-Benz BIOME Concept)
    Il modello non è marciante ed è in scala 1:5
    Imagine a vehicle lighter than a Formula 1 racing car... Experiencing the adrenaline rush of carving through the canyons with up to 3 friends... Not using a drop of gasoline... Now just imagine if these dreams could be brought together in a single vehicle. During 2010 Los Angeles Auto Show a scale model of this car - Volvo Air Motion Concept - will be on display and participates in the Design Challenge Competition.
    Tipping the scales at under 1,000lbs the Volvo Air Motion Concept makes these dreams a reality and delivers this in a beautiful Scandinavian body. Designed like a clam shell and sculptured from ultra light carbon fiber.
    Minimizing weight and complexity, while maximizing driving enjoyment, is the philosophy behind this vehicle. Thousands fewer components are employed than in a traditional car thanks to the powerful yet simple compressed air motors that replace a heavy internal combustion engine. The motors cool down under load rather than heat up, thus removing the need for heavy cooling systems. An integrated approach to designing the chassis, interior and suspension also contribute significantly.
    To compress the air needed for the centrally mounted air tank, Air Replenishment Sites are used. Powered by air turbines floating 1,000ft in the air they harness the power of the wind and convert it to electricity to provide the compression.
    Aimed at the driving enthusiast, by a company synonymous with safety and environmental care, the Volvo Air Motion Concept demonstrates the beauty and purity of Scandinavian design and delivers a guilt free, raw driving experience.
    Via NetCarShow.com
    Gallery Completa Volvo Air Motion Concept
  1. prototipo Volvo 3CC
    Di carrera4 nel forum Rumors & Spies
    Risposte: 12
Volvo ad aria compressa
prototipi auto ad aria
volvo aria compressa
Air Replenishment Sites français
prototico ad aria compressa
prototipi motore aria
prototipo auto ad aria compressa
prototipo automobile ad aria
prototipi volvo
volvo prototipi
prototipo aria compressa salerno
prototipi ad aria
prototipo motore aria
prototipo a aria compressa
concept car volvo air
auto prototipo ad aria compressa
volvo concept car aria compressa
volvo concept
macchina ad aria compressa volvo
motore volvo aria compressa
prototipi aria compr
prototipo motore aria compressa
espansione del aria compressa
power wind concepts GmbH pesi
Tag per Questa Discussione
