Indietro   Autopareri > Il mondo auto > Mondo Motori > Veicoli commerciali e industriali
Annuncio
Veicoli commerciali e industriali Veicoli commerciali, veicoli industriali, bus, camion....
Rispondi
Vecchio 22/01/07, 19.31   #1 (permalink)
j
HALL OF FAME
L'avatar di j
Iscritto dal: 25/03/04
Predefinito New Lamborghini R6 (Foto Ufficiali)
http://pistonheads.com/news/default.asp?storyId=15746
Cita:
NEW LAMBORGHINI HITS THE DIRT
40 gears in both directions...
Lamborghini has just launched a new vehicle -- and it costs under £60,000. The new Lamborghini R6, said to offer operators an ideal combination of reliability, power and comfort, is powered by a 7.1-litre six-cylinder engine, with max power reached at just 1,800rpm.
At 1,000 rpm, the torque rise is significantly higher than the torque at the rated speed, ensuring that the tractor has no difficulty moving off even in toughest conditions. The performance of the R6 engines is further enhanced by the “overpower” provided for demanding PTO work and fast road transport.
The R6 has an efficient cooling system, comprised of the engine coolant radiator, transmission oil cooler and fuel cooler and intercooler, all of which are positioned parallel to each other in order to increase the surface area exposed to the cooling air flow. This system allows the overall dimensions of the cooling system to be reduced, thus allowing improved forward visibility from the driving seat and more space under the hood.
The transmission is also new, allowing smooth and jerk-free shifting under load. This is a four-speed Powershift unit with six synchronised ranges, creeper and change-on-the-go hydraulic shuttle, giving a total of 40 forward and 40 reverse gears.
Available speeds range from 0.45 km/h to 50 km/h, the steering angle is 52 degrees, with differential locks on both axles -- handy for tight turns such as Druid's.
Modern and attractive, the R6 bodywork styling is also brand new, with its galvanised steel hood, Telene side panels and distinctive front grille.
Yours for just £58,500 -- a brand new Lamborghini tractor.
da pistonheads.com
__________________
www.20thboys.com
Ultima modifica di j : 23/01/07 alle 18.22.
j non č collegato   Rispondi citando
Vecchio 22/01/07, 19.45   #2 (permalink)
HALL OF FAME
Team Member
L'avatar di Touareg
Iscritto dal: 01/12/03
Localitą: Palermo
Predefinito Re: New Lamborghini R6 (Foto Ufficiali)
Ma 'bba caca
__________________
Touareg č collegato   Rispondi citando
Vecchio 22/01/07, 23.21   #3 (permalink)
HALL OF SETE
Moderatore
L'avatar di J-Gian
Iscritto dal: 01/04/04
Localitą: Treviso
Nun se vede, che č un trattore?
J-Gian non č collegato   Rispondi citando
Vecchio 23/01/07, 14.10   #4 (permalink)
World Championship Winner
L'avatar di Alfred
Iscritto dal: 22/04/04
Localitą: Costa Volpino (BG)
Io pensavo che il settore agricolo avesse chiuso, ma dipende anche questo dal gruppo Audi-VW, oppure č indipendente come Volvo Trucks rispetto a Volvo Cars?
Non avete delle foto?
__________________
Alfred non č collegato   Rispondi citando
Vecchio 23/01/07, 14.33   #5 (permalink)
Team Manager
L'avatar di SaiKiSono
Tournaments Won: 1
Iscritto dal: 03/09/06
ma 'ndo stanno le foto!!!cmq c sta un bel vaff..... ieri quando ho visto il topic i soop & anteprime avevo pensatoa d altro....
__________________
C:\Documents and Settings\Pippo\Documenti\Luka\auto\F1\firma1.jpg
SaiKiSono non č collegato   Rispondi citando
Vecchio 23/01/07, 18.30   #6 (permalink)
j
HALL OF FAME
L'avatar di j
Ho messo il link cosi si dovrebbe vedere la foto
cmq Lamborghini Trattori appartiene al gruppo SAME DEUTZ-FAHR
__________________
www.20thboys.com
Vecchio 27/01/07, 16.59   #7 (permalink)
Giovane Promessa
L'avatar di albiz94
Iscritto dal: 26/01/07
Localitą: Verona
Talking Re: New Lamborghini R6 (Foto Ufficiali)
interessante k la lambo si rimetta a fare quello k faceva in origine, cmq quetso č un forum di auto , nn di mezzi agricoli!
albiz94 non č collegato   Rispondi citando
Vecchio 27/01/07, 18.35   #8 (permalink)
j
HALL OF FAME
L'avatar di j
beh..li ha sempre fatti i trattori...
e cmq questo č anche un forum di mezzi agricoli
__________________
www.20thboys.com
Vecchio 27/01/07, 20.08   #9 (permalink)
HALL OF FAME
Amministratore
Iscritto dal: 04/03/03
Localitą: Torino
Cita:
Scritto in origine da albiz94
Spiacente, questa č la sezione veicoli commerciali/industriali, quindi l'argomento č perfettamente in tema
Ma la Lamborghini trattori aveva interrotto la produzione, in passato?
__________________
"Diplomatic Immunity!" - "It's just been revoked!".... Lethal Weapon 2, 1989.
Abarth03 non č collegato   Rispondi citando
Vecchio 27/01/07, 23.15   #10 (permalink)
HALL OF FAME
Moderatore
L'avatar di Regazzoni
Iscritto dal: 27/05/05
Localitą: Bergamo (ma ora Brescia)
Cita:
Scritto in origine da Abarth03
Che io sappia č normalmente sul mercato. Almeno da un po' di anni.
Ed č assolutamente indipendente dalla Lamborghini Auto.
__________________
_____________work_in_progress___
Regazzoni non č collegato   Rispondi citando
Rispondi
Bookmarks
Regole di scrittura
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Le faccine sono On
Il codice [IMG] é On
Il codice HTML č Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
Tutti gli orari sono GMT +2. Ora sono le 11.35.
Powered by vBulletin Version 3.7.3
SEO by vBSEO 3.2.0
