Mostra i risultati del/dei TAG ''yangwang u7 2025'' .
BYD demonstrates 1,300 hp Yangwang U7’s stability with Kung Fu stunt ahead of March 27 launch BYD teased the Yangwang U7 sedan ahead of the March 27 launch. In the video released on Weibo today, the 1,300 hp EV drives over various speedbumps with Wing Chun master on its roof, demonstrating the stability of the car’s suspension system. The Yangwang is a high-end brand under BYD. Yangwang U7 will be its third car after the off-roader “water-floating” U8 SUV and “dancing supercar” U9. Yangwang U7 sedan will be a 4-door 5-seater nearly 5.3 meters long. It feature quad motors with a combined power of 956 kW (1,282 hp) and 1,584 Nm torque. The battery capacity is 135.5 kWh, good for a 720 km CLTC range. The price will be revealed on March 27, but BYD calls it a “million-yuan” class car, which translates to 138,000 USD. The launch price will most likely be lower than that. U7 is equipped with a Disus-Z suspension system, which capabilities BYD demonstrated in the new video. The test was taken at Zhangjiakou Ningyuan Airport in Hebei. The U7 drives on asphalt roads randomly covered with speed bumps of different shapes and heights (30 mm, 40 mm, 50 mm). A Wing Chun master performing the stunt is on top of the car. Wing Chun is a self-defence martial art, a form of Southern Chinese Kung Fu. He maintains his position on one leg only while U7 hits the speedbumps at 15 km/h, and Disus-Z is trying to keep the car steady. The test was taken at Zhangjiakou Ningyuan Airport in Hebei. The U7 drives on asphalt roads randomly covered with speed bumps of different shapes and heights (30 mm, 40 mm, 50 mm). A Wing Chun master performing the stunt is on top of the car. Wing Chun is a self-defence martial art, a form of Southern Chinese Kung Fu. He maintains his position on one leg only while U7 hits the speedbumps at 15 km/h, and Disus-Z is trying to keep the car steady. https://youtu.be/LuSinzq1PfQ (CNC)
- 5 risposte
- 3
- yangwang u7
- yangwang u7 2025
(e 3 altri in più)
