Osv
Reporter (Staff)
Tutti i contenuti di Osv
  1. nella discussione ha aggiunto Osv in Presentazioni Nuovi Modelli
    Peaq Sportline Infografiche Comunicato stampa Klaus Zellmer, CEO of Škoda Auto Martin Jahn, Škoda Auto Board Member for Sales and Marketing Johannes Neft, Škoda Auto Board Member for Technical Development Exterior: Škoda’s largest SUV in Modern Solid design› Distinctive, timeless design defined by minimalism and clean lines › Largest panoramic roof of any Škoda model, with Dynamic Shade Control › First Škoda model with flush door handles › Aerodynamically optimised design with an excellent drag coefficient of 0.249 Mladá Boleslav, 23 June 2026 – The design of the largest and most spacious SUV in Škoda’s model line-up fully embraces the minimalist principles of Modern Solid design, defined by clean lines and surfaces. The new flagship introduces several firsts for the brand, including a new panoramic roof – the largest ever fitted to a Škoda – with Dynamic Shade Control. The Peaq is also the first Škoda model with flush door handles, which integrate seamlessly into the bodywork. Together with further aerodynamically optimised elements, these contribute to an excellent drag coefficient of 0.249. Oliver Stefani, Head of Škoda Design Modern Solid takes centre stage The all-new Peaq draws inspiration from the Vision 7S concept, featuring sleek, minimalist styling across its entire exterior. At the front, slender T-shaped lights and the glossy black Tech-Deck Face form key Modern Solid design elements. A distinctive loop motif is formed by the lights, the Tech-Deck Face and a new glossy black strip connecting the lower sections of the lights. Counterbalancing this loop is the Volcano line bumper, with both elements combining to create a coherent visual appearance. The bonnet retains the distinctive profiling characteristic of Škoda SUVs. The profile is defined by a high-set shoulder line, giving the Peaq a commanding presence, reinforced by the wide D-pillars bearing the Škoda lettering. The rear of the car echoes the front in both design and detail, with slender T-shaped lights and a loop motif formed by the lights, the Škoda lettering connecting their upper edges, and a glossy black strip linking their lower edges. The largest and most spacious Škoda SUV As the first Škoda model in the large SUV segment, the Peaq is also the biggest and most spacious SUV the brand has ever produced. With an overall length of 4,874 mm, the new flagship is 116 mm longer than its combustion-engined counterpart, the Kodiaq. Its wheelbase of 2,965 mm is 174 mm longer, even surpassing the Superb by 124 mm. The Peaq also uses the highest proportion of recycled materials of any Škoda, with more than 50 kg of recycled materials across the exterior and interior. The Peaq is offered in ten colours and with wheels ranging from 19 to 21 inches. T-shaped light signature The distinctive T-shaped light signature, first introduced with the Epiq, is now used on the Peaq at both the front and rear. The headlights are available in two configurations, with all lighting functions using exclusively LED technology. The top specification includes LED Matrix headlights, which use 18 segments to automatically prevent glare for oncoming drivers when the full beam is active. At the rear, Top LED rear lights with animated turn indicators are fitted as standard. The first Škoda with flush door handles The Peaq is the first Škoda model to feature flush door handles, which refine the car’s aesthetics, improve its aerodynamic efficiency, and maintain the highest possible standards of occupant safety. When the vehicle is locked or in motion, the handles retract fully and blend into the surrounding bodywork, allowing air to flow smoothly around the car. As the user approaches with the key, the handles extend electrically. They can also be deployed manually by pressing the marked front section of the handle. The largest panoramic roof in any Škoda Another first for Škoda is the panoramic roof with Dynamic Shade Control¹. With a glass area of more than 2.1 m², it is the largest panoramic roof ever fitted to a Škoda model. This electrochromic roof uses electrical voltage to alter transparency and light transmission. The panoramic roof is divided into nine individually controllable segments, with the settings adjusted via the vehicle’s infotainment system. The roof can also be operated via a touch panel on the overhead console next to the interior rear-view mirror. Excellent drag coefficient of 0.249 Despite its size, the Peaq achieves a drag coefficient of 0.249 through a combination of active and passive aerodynamic measures. These include an active shutter behind the front bumper, which reduces drag by opening when airflow to the battery cooling system is required and closing when it is not. Air Curtain channels guide airflow around the bumper and wheels, supported by spoilers ahead of the front and rear wheels, finlets on the rear wheel arch liners, and dedicated front wheel arch spoilers that reduce the gap to the tyres and keep airflow closer to the bodywork. The wheels are fitted with aerodynamic trims. Airflow along the flanks is smoothed by the aerodynamically optimised bodywork, streamlined wing mirrors, and flush door handles that sit seamlessly within the bodywork when the vehicle is in motion. A flat underbody ensures smooth airflow beneath the vehicle. The aerodynamically optimised roofline extends into a rear spoiler with finlets, promoting clean airflow separation from the bodywork to minimise turbulence behind the vehicle. The same effect is achieved by aerodynamic edges on the rear lights and a rear diffuser with an integrated spoiler at the lower rear of the car. Windscreen: wipers with integrated washers and a nod to Škoda’s cycling heritage The Peaq’s windscreen conceals two unexpected details. The first is a new Simply Clever feature: wipers with integrated washers. By reducing the distance between the washer jets and the windscreen, they reduce washer fluid consumption by approximately 50 per cent, while improving cleaning effectiveness. The second detail is more subtle. Three cyclists are positioned on the passenger side of the windscreen, referencing Škoda Auto’s origins and its first product: the Slavia bicycle. Even today, cycling remains a core part of the brand’s identity, as underlined by partnerships, most notably its sponsorship of the Tour de France. ¹ From the start of production, the panoramic roof with Dynamic Shade Control will be available exclusively for the Sportline variant, with availability for other variants to follow at a later date. Interior: a relaxing lounge with seven seats and the biggest boot› Generous cabin comfortably accommodating up to seven adults › 935-litre boot – the largest of any Škoda model › Lounge on wheels: Relax Package with ergonomic seats, legrests, and a wellbeing app › New controls improve ergonomics and make operation even more intuitive › 37-litre frunk further enhancing everyday practicality › Extensive equipment packages allow customers to tailor the new Peaq precisely to their needs › A new Sonos premium sound system with 16 speakers and a total output of 755 W delivers an exceptional listening experience Mladá Boleslav, 23 June 2026 – The all-new Peaq comfortably accommodates up to seven adults, offering the most generous interior space of any Škoda model in most key dimensions thanks to its near-three-metre wheelbase. In the five-seat configuration, it provides the largest boot of any Škoda model at 935 litres, complemented by a 37-litre frunk. The optional Relax Package, with relaxation seats including ventilation and a massage function, ergonomic legrests, two pillows, a folding table in the centre console, and a wellbeing app, transforms the Peaq into a lounge on wheels. The Relax Package also includes a Sonos premium sound system, developed specifically for the Peaq, featuring 16 speakers and an output of 755 W. A large electric SUV designed for up to seven people With a wheelbase of 2,965 mm, even passengers in the second and third rows enjoy comfort and generous legroom. The third row also provides ample headroom, while still leaving a usable 299 litres of boot space. In the five-seat configuration, the Peaq boasts a boot capacity of 935 litres – more than any other Škoda model. A 37-litre frunk provides storage space for charging cables and similar items, while additional storage compartments throughout the interior offer more than 33 litres of extra space for smaller items. Interior Design Selections: Suite Ceramique stands out in light grey The Peaq is available in five Interior Design Selections: Suite Black, Suite Ceramique, Lodge, Loft, and Sportline. The two top-of-the-range Suite variants use the high-quality leather alternative Techtona: in black for Suite Black, and in light grey for Suite Ceramique. The Lodge interior combines dark grey fabric upholstery with green Techtona accents. The standard Loft features black seat upholstery combined with light grey Techtona on the dashboard and door panels, and black Techtona on the centre armrest. The Sportline Lounge Design Selection comes with sports front seats upholstered in black Techtona and black Suedia, complemented by white stitching. All Interior Design Selections are fitted as standard with ambient lighting and a heated two-spoke multifunction steering wheel, while the Sportline variant features a three-spoke steering wheel. Relax Package: the ultimate way to create a lounge-like travel experience The Relax Package, offered as an option with all Interior Design Selections, makes its Škoda debut and transforms the Peaq into a lounge on wheels. It includes electrically adjustable heated seats officially certified as ergonomic by the registered institution AGR. Ventilation, a massage function, and electrically adjustable ergonomic legrests are also included. Additional equipment includes a custom, Sonos-tuned premium sound system, and a dedicated wellbeing app offering six modes, including relaxation, stretching, and energy boost settings. The app creates the intended effect by adjusting functions such as climate control, ambient lighting, and seat massage. The package also includes two cushions for the front seat head restraints and a folding table integrated into the centre console. Other equipment packages The Peaq’s standard specification can be extended with optional equipment packages and options, including the panoramic roof with Dynamic Shade Control, a third row of seats, a heat pump, Dynamic Chassis Control, and a tow bar. Besides the Relax Package, five additional packages are available: Convenience, Tech, Assist, Winter, and Simply Clever. The Convenience Package includes electrically adjustable front seats with memory and lumbar support, illuminated Qi2 wireless charging for two phones, a USB-C port by the rear-view mirror, two cargo elements, a 230 V socket in the boot. In the seven-seat configuration, additional USB-C ports are provided on both sides of the third row. The Tech Package adds LED Matrix headlights, the illuminated front Light Band, and the Top Area View 360° system. The Assist Package includes Travel Assist 3.0, an augmented-reality head-up display, and Intelligent Park Assist, while the Winter Package adds heated rear seats and a heated windscreen. The Simply Clever Package adds practical features such as a charging cable cleaner, a tablet holder, an umbrella in the front passenger door, and a waste bin. New controls for even more intuitive operation The Peaq also introduces a new approach to selected controls. The redesigned interior door handle is now integrated into the door armrest and has a silicone surface for a more tactile feel. The new control panel on the centre console is divided into two sections. The upper section houses locking and unlocking buttons, the hazard warning switch, and a scroll wheel for volume control. The lower section contains three toggles: the outer two adjust the driver’s and front passenger’s temperature settings, while the central toggle switches between five fan speed settings in automatic climate control mode. A wide range of Simply Clever features A key Simply Clever feature of the all-new Peaq is the 37-litre frunk, designed to store the charging cable alongside items such as the electric roller cover for the boot or a charging cable cleaner. As the first Škoda model to boast wiper blades with integrated washers, the Peaq uses screenwash fluid more efficiently and delivers more effective windscreen cleaning. Another all-new Simply Clever feature is the folding table stowed inside the Jumbo Box between the front seats. The table is available as part of the Relax Package and creates a practical surface between the driver and front passenger when unfolded. Further Simply Clever items include the storage compartment located at the rear of the centre console in front of the second row of seats, a display cleaner, and a snow broom. Battery and powertrain variants: the longest range of any Škoda electric model› The Peaq 90 offers over 640 kilometres of electric range, with fast charging from 10 to 80 per cent in 28 minutes; the Peaq 60 reaches 80 per cent in just 27 minutes › Built on the proven Modular Electrification Toolkit (MEB+), the Peaq offers a choice of two battery capacities and three powertrain variants › The larger 91 kWh battery is the largest-capacity unit of any Škoda electric vehicle › With a towing capacity of up to 2,000 kg, the Peaq is a versatile partner for everyday use and beyond › One-pedal driving makes electric driving effortless in everyday traffic › Bidirectional charging makes the Peaq a practical power source on the go › The next-generation heat pump increases efficiency and range Mladá Boleslav, 23 June 2026 – The Peaq is available with two battery capacities, including a 91 kWh unit, the largest‑capacity battery ever fitted in a Škoda vehicle. With the largest battery capacity in the line‑up, the Peaq also offers the longest range of any all‑electric Škoda model, at over 640 kilometres. Three powertrain variants are offered, with outputs from 150 kW to 220 kW, and a choice of rear‑wheel or all‑wheel drive. A towing capacity of up to 2,000 kg further underlines the Peaq’s versatility, making it a dependable companion even for more demanding tasks. The one‑pedal driving function simplifies everyday electric mobility, allowing drivers to accelerate and decelerate intuitively using just the accelerator pedal. Bidirectional charging turns the electric Peaq into a practical power source, adding clear everyday value beyond driving. A next‑generation heat pump, offered as an option, further improves efficiency. Exceptional battery capacity The all‑new Peaq is available with two battery capacities. The smaller battery comprises nine modules, has a gross capacity of 63 kWh (59 kWh net) and can be charged from 10 to 80 per cent in just 27 minutes. The larger 13‑module unit has a gross capacity of 91 kWh (86 kWh net), making it the largest‑capacity battery of any Škoda electric vehicle. Charging from 10 to 80 per cent takes just 28 minutes. Both battery systems are manufactured in Mladá Boleslav and use nickel‑manganese‑cobalt (NMC) chemistry, providing high energy density for longer electric range. Three power variants The Peaq comes in three variants – the Peaq 60, Peaq 90, and Peaq 90x. The Peaq 60 uses the smaller battery and has rear‑wheel drive, with a maximum output of 150 kW and peak torque of 350 Nm. It accelerates from 0 to 100 km/h in 8.4 seconds, has a top speed of 160 km/h and offers a range of over 450 kilometres on a single charge. Both the Peaq 90 and Peaq 90x are paired with the 91 kWh battery. The Peaq 90 has rear‑wheel drive, while the Peaq 90x has all‑wheel drive. The Peaq 90 delivers a maximum output of 210 kW and peak torque of 545 Nm; the Peaq 90x reaches 220 kW. Acceleration from 0 to 100 km/h takes 7.1 seconds and 6.7 seconds respectively, with a top speed of 180 km/h. The Peaq 90 offers a range of more than 640 kilometres, while the Peaq 90x exceeds 610 kilometres. All three Peaq variants can be optionally equipped with a tow bar, with towing capacities of up to 1,800 kilograms for the Peaq 60 and 90 and 2,000 kilograms for the Peaq 90x with braked trailers. The unbraked limit is 750 kg across all variants. All variants use a permanent‑magnet synchronous motor on the rear axle for efficiency and dynamic acceleration. On the Peaq 90x, the front axle is driven by an asynchronous electric motor characterised by short‑term overload capability and low friction losses. Overall efficiency, and therefore range, is further improved across all variants by energy recuperation, coasting mode, and the ECO assistant. Easy electric driving with one pedal The Škoda Peaq supports one‑pedal driving. Selecting the B position on the drive selector activates one‑pedal driving mode, allowing the vehicle to come to a complete standstill using recuperation alone. In addition to B mode, one‑pedal driving can also be activated using the steering wheel paddles, which are currently reserved exclusively for the Sportline variant. Power that works both ways The Peaq is equipped with bidirectional charging, allowing the energy stored in the battery to be used externally via V2L (Vehicle‑to‑Load). When paired with the Ambibox DC Wallbox from MOON POWER, a Volkswagen Group brand, the Peaq also supports V2H (Vehicle‑to‑Home), supplying energy to buildings, and V2G (Vehicle‑to‑Grid), which allows energy to be fed back into the electricity grid. Efficiency in every season with a next-generation heat pump An optional next‑generation heat pump is available as a standalone feature for the Peaq, improving electric range in cold weather compared to the previous system. The greatest gains are achieved when the vehicle is pre‑conditioned before departure, e.g. via the Departure Planner. Brakes and suspension The Peaq has MacPherson strut suspension with front disc brakes, while the rear axle uses a five‑link suspension setup with reliable and low‑maintenance drum brakes, as recuperation on the driven rear axle handles the vast majority of braking in everyday driving. In B mode, recuperation alone accounts for more than 95 per cent of all braking demands. Safety: a comprehensive suite of active and passive safety systems› Wide range of advanced assistance systems as standard, including Front Assist, Crossroad Assist, Turn Assist, and Side Assist › Optional Travel Assist 3.0 is Škoda’s most advanced assistance system › Ten airbags as standard, including a scentre airbag, to provide the highest‑possible level of occupant protection Mladá Boleslav, 23 June 2026 – The new Peaq showcases the full breadth of sŠkoda’s driver assistance technology. The comprehensive suite of sadvanced systems fitted as sstandard includes Crossroad Assist, Turn Assist, Collision Avoidance Assist, and Predictive Adaptive Cruise Control. The Peaq can also be specified with optional Travel Assist 3.0 ‑ the most advanced assistance system in sthe Škoda line‑up. Travel Assist 3.0 Travel Assist 3.0, Škoda’s most advanced assistance system, includes Traffic Jam Assist and Emergency Assist and is offered as an option for the Peaq. The latest version also responds to traffic lights, with Assisted Lane Change to ofollow later. When ordered with the Assist Package, Travel Assist 3.0 is complemented by Intelligent Park Assist with Trained Park Assist and Remote Park Assist. Enhanced versions of familiar assistance systems Several of the systems incorporated into the Peaq have been enhanced. Crossroad Assist, fitted as standard, uses new radar sensors at the corners of the front bumper to detect cars, motorcycles, cyclists, and e‑scooters approaching from the side. Driver Alert with driver monitoring uses a new camera integrated into the rear‑view mirror housing to track the driver’s eye movements. Drawing on this data, it continuously assesses driver attention and fatigue. Traffic Sign Recognition is enhanced by Traffic Sign Recognition Online, drawing on continuously updated online data sourced from vehicles that have travelled the same route. The upgraded optional Top Area View 360° system provides an overview of the vehicle’s surroundings and can generate a transparent 3D body on the display, making parking and manoeuvring even easier. A comprehensive suite of assistance systems and ten airbags as standard The extensive suite of advanced assistance systems fitted as standard includes Front Assist, Crossroad Assist, Turn Assist, Lane Assist, Side Assist with Rear Traffic Alert and Exit Warning, and Predictive Cruise Control. Ten airbags, including a centre airbag and rear side airbags, are standard. Connectivity: vertical infotainment display and Sonos premium sound system set the Peaq apart› First Škoda vehicle with a vertically mounted display › 13.6-inch Android-based infotainment system as a digital hub › 16-speaker custom, Sonos-tuned premium sound system with 755 W output › MyŠkoda app provides access to vehicle functions and EV‑specific services Mladá Boleslav, 23 June 2026 – The digital hub of the Škoda Peaq is a modern 13.6‑inch Android‑based infotainment system, used with a vertically mounted display for the first time in a Škoda model. A new sound system developed in collaboration with Sonos is available as an option, delivering an exceptional sound experience. The MyŠkoda app provides remote access to vehicle information, EV‑specific services, and charging functions, including the management of Škoda Charger wallboxes. 13.6-inch Android-based infotainment The Škoda Peaq is equipped with the latest 13.6‑inch infotainment system, built on the Android platform, with a vertically mounted display for the first time in a Škoda model. Compared with the previous generation, this infotainment system offers a redesigned interface and home screen with a clear grid layout. Expanded personalisation options, favourites, and a system‑wide search function support intuitive operation. In addition to native Škoda applications, users can access third‑party apps, including Spotify and YouTube. Sonos premium sound system for a rich and balanced listening experience The Peaq introduces a Sonos premium sound system, available as part of the Relax Package. The result of close cooperation between Škoda Auto and Sonos, renowned for its premium home audio technology, is a 16‑speaker, 755 W system. Built around components developed specifically for the Peaq, the system adapts the company’s sound technology experience and clear sound reproduction as intended by the artist for in‑car use. A next‑generation A2B booster amplifier and advanced magnetic and membrane technology maximise both efficiency and acoustic performance. A dual subwoofer with a combined output of 200 W and an 18‑litre enclosure delivers deep, controlled bass, while 3D A‑pillar speakers create an immersive, front‑focused soundstage. Rear surround speakers ensure a rich and balanced listening experience, while precisely engineered metal grilles in the front doors optimise sound transmission. The unique sound experience is rounded off by a cutting edge 3D surround algorithm. Even more practical wireless phone charging The MyŠkoda app provides access to a wide range of vehicle functions and services. For electric vehicle users, it offers EV‑specific features that simplify everyday use: Remote Charging allows users to start or stop charging manually when plans change. Following a one‑time authorisation within the Powerpass subscription, Plug & Charge enables charging at public charging stations without additional authorisation. The Departure Planner ensures that the vehicle is heated or cooled to the desired temperature at the specified time. For spontaneous journeys, the Online Climate Control function allows remote heating, including seat and steering wheel heating, as well as air‑conditioning. MyŠkoda app with access to EV-specific features for enhanced everyday practicality The MyŠkoda app provides access to a selection of vehicle functions and EV‑specific services, making everyday use even more convenient. These include Remote Charging, allowing users to manually start or stop a charging session, and Plug & Charge, which ‑ following one-off authorisation via a Powerpass subscription – enables public charging without any further authentication. Departure Planner allows users to set a precise departure time and pre‑condition the cabin temperature. Online Climate Control allows users to activate the heating or air‑conditioning at any time, including windscreen heating. A completely new feature is Camp Mode, designed for users who occasionally spend the night in their car. Activated via the MyŠkoda app, Camp Mode enables the vehicle’s ventilation system to maintain the selected interior temperature throughout the night. This ensures not only a pleasant cabin temperature, but also a continuous supply of fresh air. The system requires sufficient battery charge, with a minimum state of charge of 20 per cent, a 12V starter battery in good condition and a stable internet connection. A mobile digital key for the Peaq is planned for later this year, enabling drivers to use their iPhone or Android device to lock, unlock, and start the vehicle, while simplifying vehicle sharing between multiple users. The Peaq Sportline: dynamic inside and out› Sportline trim line offered from launch › Distinctive exterior elements emphasise the dynamic look › Sportline Lounge interior with sports seats and an all-black theme Mladá Boleslav, 23 June 2026 – The Peaq will be available in a Sportline variant from launch. It is instantly recognisable by its glossy black detailing and is the only Peaq that can be specified with optional two‑tone paintwork and a black roof. The interior adopts an all‑black theme throughout, from the seats and door panels to the dashboard and headlining, for a distinctly sporty character. Black exterior accents The Peaq Sportline is characterised by glossy black exterior accents, including the vehicle lettering, the Škoda lettering on the D-pillars, and the Sportline badge at the rear. The Peaq Sportline is also the only trim line available with an optional black roof as part of a two‑tone finish. LED Matrix headlights and an illuminated Tech‑Deck Face with Light Band are included as standard. The Peaq Sportline comes equipped with black 20‑inch alloy wheels as standard, with 21‑inch wheels offered as an option. Sportline Lounge Design Selection The Sportline Lounge Design Selection features electrically adjustable sports seats with enhanced lateral support and integrated head restraints. A three‑spoke sports steering wheel and sports pedal covers reinforce the sporty character, further accentuated by the black headlining. The upholstery combines Suedia with Techtona, a high‑quality leather alternative finished in black, with white contrast stitching. Powertrain and specification The Peaq Sportline can be combined with all powertrain variants, equipment packages, and standalone options. The Convenience and Tech Packages are included in the Peaq Sportline as standard, along with SunSet – tinted rear side windows and tailgate glass. Via Škoda. Topic Spy: Škoda Peaq - Space BEV 2026 (Spy)
  2. Su Bimmerpost compaiono le prime specifiche: BMW iX5 60 xDrive Lunghezza/Larghezza/Altezza in mm: 4.994 / 2.000 / 1.748 Passo in mm: 3.035 Carreggiata anteriore/posteriore in mm: 1.712 / 1.714 Raggio di sterzata in m: 12.8 Raggio di sterzata con Integral Active Steering in m: 12.1 Peso a vuoto in kg: 2.900 0-100km/h in s: 4.6 BMW X5 40 xDrive Lunghezza/Larghezza/Altezza in mm: 4.994 / 2.000 / 1.751 Passo in mm: 3.035 Carreggiata anteriore/posteriore in mm: 1.712 / 1.714 Raggio di sterzata in m: 12.8 Raggio di sterzata con Integral Active Steering in m: 12.1 Peso a vuoto in kg: 2.365 0-100km/h in s: 5.3 BMW X5 40d xDrive Lunghezza/Larghezza/Altezza in mm: 4.994 / 2.000 / 1.751 Passo in mm: 3.035 Carreggiata anteriore/posteriore in mm: 1.712 / 1.714 Raggio di sterzata in m: 12.8 Raggio di sterzata con Integral Active Steering in m: 12.1 Peso a vuoto in kg: 2.430 0-100km/h in s: 6.1 BMW X5 50e xDrive Lunghezza/Larghezza/Altezza in mm: 4.994 / 2.000 / 1.751 Passo in mm: 3.035 Carreggiata anteriore/posteriore in mm: 1.712 / 1.714 Raggio di sterzata in m: 12.8 Raggio di sterzata con Integral Active Steering in m: 12.1 Peso a vuoto in kg: 2.640 0-100km/h in s: 5.0 BMW X5 M60e xDrive Lunghezza/Larghezza/Altezza in mm: 4.994 / 2.000 / 1.751 Passo in mm: 3.035 Carreggiata anteriore/posteriore in mm: 1.712 / 1.714 Raggio di sterzata in m: 12.8 Raggio di sterzata con Integral Active Steering in m: 12.1 Peso a vuoto in kg: 2.715 0-100km/h in s: 4.5
  3. Non si vede il primo video.
  4. Aperti gli ordini! Comunicato stampa Via Ram.
  5. Comunicato stampa Laurens Van den Acker, Chief Design Officer di Renault Group Techno ed Esprit Alpine: due espressioni di Megane La struttura della gamma di Nuova Renault Megane E-Tech Electric evolve acquisendo maggiore chiarezza e leggibilità. Continua ad avere due livelli di allestimenti complementari, Techno ed Esprit Alpine, ognuno caratterizzato da posizionamento ben definito. All'esterno, la versione Techno trasmette dinamicità con gli elementi decorativi del paraurti in tinta carrozzeria e l'introduzione di nuovi cerchi da 19”, mentre i cerchi da 20” sono disponibili in opzione per una maggiore presenza su strada. Posizionato al top di gamma, l'allestimento Esprit Alpine vanta un look ancora più esclusivo. Si distingue, in particolare, per i cerchi specifici da 20” e gli elementi distintivi Esprit Alpine. Megane E-Tech Electric è disponibile in 7 tinte di carrozzeria, tra cui il nuovo Blu Ardesia satinato, con configurazioni bi-tono in opzione. Abitacolo impreziosito da materiali più raffinati Nell'allestimento Techno, la plancia è ora rivestita in TEP, materiale che contribuisce a migliorare la qualità percepita dell'abitacolo. Sono disponibili in opzione anche i sedili elettrici in TEP grigio chiaro o nero titanio, arricchiti dagli elementi decorativi dei pannelli delle porte e dalla plancia rispettivamente in legno o grigio effetto grafico. L'allestimento Esprit Alpine cambia il look al suo interno con l'introduzione di nuovi motivi decorativi per i pannelli delle porte con trattamento grigio effetto 3D, che sfuma dal grigio scuro al blu, accentuando il carattere sportivo e sofisticato della versione. L'ambient lighting, completamente a LED, contribuisce al look dell'abitacolo ed alla percezione di qualità. A seconda delle condizioni di utilizzo, può variare ed essere personalizzato, contribuendo così a creare un ambiente in linea con le preferenze del conducente. Esperienza elettrica ottimizzata Nuova Renault Megane E-Tech Electric fa un ulteriore passo avanti in termini di efficienza ed utilizzo delle tecnologie elettriche, potendo contare sulle competenze acquisite da Renault nei veicoli elettrici. Nuova batteria per un'efficienza elettrica ottimizzata Nuova Renault Megane E-Tech Electric è dotata di motore sincrono a rotore avvolto senza terre rare, prodotto a Cléon, in Francia, in grado di erogare 220 cv (300 Nm), abbinato alla nuova batteria da 67 kWh, che consente di raggiungere un'autonomia WLTP fino a 500. Dotata di chimica LFP (litio-ferro-fosfato) di nuova generazione, questa batteria vanta un'architettura innovativa di tipo cell-to-pack (C2P) che integra 232 celle ravvicinate (Pouch 2 Cell), una novità assoluta a livello mondiale. Questo design consente di ottenere un'ottima efficienza energetica, pari al 53%, ottimizzando così la densità energetica e la capacità utile a bordo. Quest'evoluzione comporta anche migliori prestazioni di ricarica, con una potenza in corrente continua portata a 165 kW (+35 kW). È pertanto possibile passare dal 15 all'80% di carica in circa 24 minuti (-25%). Ecosistema elettrico pensato per ottimizzare tutti i percorsi L'ecosistema elettrico si basa su una serie di tecnologie progettate per ottimizzare l'efficienza e la gestione dell'energia: Route Planner di Google Maps che prevede le esigenze di ricarica ed ottimizza i tempi di percorrenza lungo l'itinerario. Dispositivi di ottimizzazione energetica come la pompa di calore ed il precondizionamento della batteria, che contribuiscono a salvaguardare le prestazioni della batteria in qualsiasi condizione di utilizzo. Caricabatterie bidirezionale in corrente alternata da 11 kW o 22 kW (in opzione), un'offerta unica sul mercato delle compatte, con una capacità bidirezionale che consente di ampliare le possibilità di ricarica e utilizzo. Il caricabatterie bidirezionale permette di beneficiare della funzione V2L(vehicle-to-load) per collegare apparecchi da 220 V a 3.700 W alla batteria dell'auto tramite un adattatore power to object. Invece, la funzione V2G (vehicle-to-grid) (a seconda dei Paesi) permette di reimmettere l'energia nella rete elettrica e ridurre i costi di ricarica a domicilio. Piacere di guida immutato Oltre alle prestazioni elettriche, anche il piacere di guida resta un elemento fondamentale del DNA di Nuova Renault Megane E-Tech Electric. La piattaforma dedicata RG medium 1.0 (ex AmpeR medium) consente di conciliare efficienza energetica e doti dinamiche. L'architettura della piattaforma è sempre la stessa, ma la batteria è integrata sotto il pianale, accorgimento che contribuisce ad equilibrare la distribuzione del peso e ad abbassare il baricentro. Questa configurazione favorisce maggiore precisione nella tenuta di strada ed un comportamento dinamico, preservando al tempo stesso il comfort a bordo. La presenza delle sospensioni posteriori multi-link migliora la precisione di guida e la stabilità del veicolo, soprattutto ad alta velocità, migliorando al tempo stesso l'assorbimento delle irregolarità del fondo stradale. Questo contribuisce al compromesso equilibrato tra dinamicità e comfort. Il tutto è completato dallo sterzo ottimizzato, che offre una risposta più diretta e maggiore precisione di guida, consentendo al conducente di godersi sensazioni più naturali. Anche con l'integrazione della nuova batteria, è preservato il DNA dinamico dell'auto: equilibrio del telaio, precisione dello sterzo, tenuta di strada e piacere al volante. A tal fine, le molle e gli ammortizzatori sono stati interamente rivisitati con nuove impostazioni dello sterzo per mantenere la dinamicità e la reattività del telaio. Tecnologie utili, user-friendly e scalabili Fedele al DNA di Renault, Nuova Renault Megane E-Tech Electric mantiene l'architettura interna orientata al conducente pensata per offrire un'esperienza user-friendly, immersiva ed accessibile. Quest'approccio complessivo poggia su tre pilastri complementari: connettività a bordo, continuità digitale e ADAS. Il tutto contribuisce a migliorare al tempo stesso il comfort di vita a bordo, la semplicità di utilizzo ed il livello di sicurezza. Sistema openR, elemento chiave dell'abitacolo Nuova Renault Megane E-Tech Electric vanta un abitacolo costruito intorno al sistema openR. Questo doppio schermo a forma di L rovesciata riunisce il display del quadro strumenti ed il sistema multimediale in una stessa superficie fluida ed omogenea. Con una superficie totale di 774 cm², suddivisa tra driver display da 12,3” e schermo multimediale da 12”, viene offerto, in tutte le versioni,un livello di visualizzazione che si attesta tra i migliori del segmento. Google integrato: un'esperienza connessa pensata per la vita quotidiana Nuova Renault Megane E-Tech Electric è dotata del sistema openR link con Google integrato pensato per offrire un'esperienza connessa fluida e user-friendly nella vita quotidiana. Dal display centrale il conducente accede facilmente ai principali servizi Google nonché ad un'ampia scelta di app disponibili a bordo. Il sistema comprende Google Assistant per il comando vocale delle principali funzioni del veicolo e Google Maps per la navigazione. Quest'ambiente arricchisce l'esperienza elettrica grazie a servizi dedicati come la pianificazione degli itinerari che prende in considerazione le soste per la ricarica. Il Route Planner integrato in Google Maps per viaggiare sui veicoli elettrici è riconosciuto come uno dei punti di riferimento del mercato. Vanta circa 60 evoluzioni e migliorie apportate dal lancio di Renault Megane E-Tech Electric nel 2022. Google Gemini[1]: Gemini consente al conducente di interagire con il veicolo avvalendosi di un linguaggio naturale e conversazionale. Comprende l'intenzione, mantiene il contesto delle domande e fornisce risposte pertinenti in tempo reale, aiutando il conducente a svolgere i propri compiti efficientemente senza distogliere l'attenzione dalla strada. Offerta di connettività integrata e completa Nell'ambiente Google, Nuova Renault Megane E-Tech Electric potenzia la propria offerta di connettività proponendo un'esperienza sempre più fluida e completa. Il catalogo delle app di bordo scaricabili da Google Play continua ad arricchirsi e supera ora le cento applicazioni. [1] Google, Google Maps e Gemini sono marchi depositati di Google LLC. Quest'evoluzione si avvale di un nuovo partner per la connettività ed è accompagnata da un pacchetto dati Internet incluso per tre anni, il che consente di usufruire appieno delle app scaricate, senza abbonamento supplementare né condivisione della connessione. Si tratta di un passo avanti significativo: finora la connettività offriva la possibilità di scaricare le applicazioni ed accedere ai servizi telematici, ma alcune funzioni, come il video streaming, dipendevano dalla condivisione della connessione dello smartphone. Ora i dati del veicolo consentono di accedere direttamente al catalogo delle applicazioni mediante il display openR link. Grazie al nuovo pacchetto dati Internet, i clienti possono godersi i contenuti multimediali in tutta semplicità: ogni mese, fino a 3 ore di video streaming o 40 ore di audio streaming, a seconda dell'utilizzo. Un approccio pensato per offrire un'esperienza fluida e fedele alla visione Renault dell'auto connessa. Nuove funzionalità per facilitare la vita quotidiana In conformità con le normative in vigore, Nuova Renault Megane E-Tech Electric integra nel montante sinistro del parabrezza una telecamera dotata di sistema di rilevamento dell'attenzione del conducente. Renault va anche oltre e sfrutta questa dotazione per arricchire Megane di un sistema di riconoscimento del conducente. Dopo aver creato il profilo utente e registrato la sua impronta facciale, quando l'utente si mette al volante, il veicolo attiva automaticamente le impostazioni personalizzate, come posizione di guida, media preferiti ed ambiente openR link con Google integrato. I dati sono memorizzati solo nel veicolo e non vengono trasmessi a nessun server. Nuova Renault Megane E-Tech Electric offre anche la funzione Smart Mode, che sostituisce la modalità Perso Mode. Questa tecnologia regola automaticamente le transizioni tra le varie modalità di guida MULTI-SENSE (Eco, Confort e Sport) in base al comportamento del conducente. Con discrezione riesce a ottimizzare sempre il comfort e la fluidità dell'esperienza di guida quotidiana. Il conducente potrà così avvalersi immediatamente della reattività della modalità Sport in caso di sorpasso e risparmiare passando automaticamente alla modalità Eco non appena il ritmo di guida rallenta, soprattutto in città. Con Renault che si attesta tra i primi costruttori automobilistici a offrire questo tipo di tecnologia, Nuova Megane E-Tech è dotata di caricabatterie a induzione conforme allo standard Qi2 (o Magsafe su iPhone). Questa tecnologia, presente nella maggior parte degli smartphone di ultima generazione, integra un anello magnetico per garantire la massima potenza di ricarica (recupero del 50% del livello della batteria in un'ora) senza surriscaldamento. Il caricabatterie a induzione può essere utilizzato anche per i precedenti smartphone già ricaricabili a induzione, che potranno avvalersi di questa tecnologia aggiungendo una cover magnetica oppure un semplice anello magnetico. Funzione One Pedal con levette al volante, per una guida fluida Renault offre su Nuova Megane E-Tech Electric la funzione One Pedal. Questo dispositivo consente di accelerare, rallentare e persino fermarsi completamente usando solo il pedale dell'acceleratore. La decelerazione è resa possibile dal motore elettrico, con un rallentamento progressivo e fluido fino al completo arresto del veicolo. Una volta fermo, il veicolo resta immobile, anche su pendenze fino al 20%, mediante l'attivazione automatica del freno di stazionamento elettrico dopo pochi secondi. Renault offre quattro livelli di rigenerazione, completati dalla funzione One Pedal, attivabili mediante le levette al volante. Questo sistema consente di adattare la frenata alle proprie abitudini ed alle condizioni del traffico per una guida più fluida e più piacevole, anche per i passeggeri. Oltre 30 ADAS per una maggiore serenità Megane conserva numerose dotazioni di sicurezza e dispositivi di assistenza alla guida progettati per migliorare la sicurezza e sostenere il conducente in qualsiasi circostanza. Questi sistemi rientrano in una logica di assistenza attiva, con funzioni destinate a rafforzare la percezione dell'ambiente e a facilitare la guida quotidiana. Tra le novità proposte, ricordiamo le seguenti: Adaptive Cruise Control intelligente: regola la velocità in funzione del traffico e del contesto stradale prevedendo i rallentamenti e mantenendo distanze di sicurezza ottimali. La novità è che il sistema rileva i veicoli posizionati a destra e a sinistra, soprattutto per evitare inopportuni sorpassi sulla destra. Miglioramento della visualizzazione realistica: la visualizzazione realistica sul cruscotto, che consente al conducente di vedere l'ambiente e gli altri veicoli, è arricchita con la rappresentazione di mezzi pesanti, linee tratteggiate sulla carreggiata e della scala di regolazione della distanza per aiutare il conducente ad avere una percezione più precisa. Assistente alla frenata d'emergenza: il sistema funge da complemento all'Active Driver Assist per rallentare il veicolo finché non si ferma completamente sulla strada (se possibile) in caso di inattività del conducente e di non rilevamento delle mani sul volante. Assistente di eco-guida predittiva: questo ADAS analizza la strada e le condizioni del traffico per suggerire al conducente le azioni più efficienti da intraprendere per ottimizzare il consumo di energia e l'autonomia. Safety Score, Safety Coach e Safety Monitor: Safety Score analizza il comportamento di guida partendo da vari criteri, come frenata, velocità e distanza di sicurezza. Grazie alla telecamera integrata nel montante A, questo ADAS prende ora in considerazione anche il livello di attenzione del conducente. Abbinato a Safety Coach, a fine percorso, fornisce consigli personalizzati per adottare una guida quotidiana più sicura e più serena. Il tutto è completato da Safety Monitor, che appare come widget sul cruscotto con mini-consigli sotto forma di testo compatibili con la guida. my rnlt: una sola App per tutta Renault L'esperienza connessa prosegue anche al di fuori del veicolo con la nuova App mobile my rnlt. Pensata per sostenere i clienti nella vita quotidiana, questa App fonde, su un'interfaccia unica, semplice e fluida, tutti i servizi connessi al veicolo. Performante e affidabile, garantisce la sincronizzazione in tempo reale tra smartphone e veicolo, fornendo un accesso rapido, preciso e sempre aggiornato alle informazioni essenziali. my rnlt è anche sempre connessa all'ecosistema ed alla rete commerciale della Marca. Consente pertanto ai clienti di ricevere informazioni da Renault in modo personalizzato e conversazionale, come consigli tramite l'App mobile, informazioni relative alla manutenzione del veicolo, aggiornamenti, sicurezza ed offerte o modalità di rinnovo. Il cliente ha così accesso a tutte le informazioni relative al veicolo, fin dall'acquisto, come: Monitoraggio del veicolo prima della consegna. Guida semplice e intuitiva fin dal primo utilizzo, che consente di connettere velocemente il veicolo all'App e di configurare le proprie preferenze. Informazioni per scoprire e prendere familiarità con il veicolo, particolarmente rassicurante ed utile per quei clienti che stanno scoprendo i veicoli elettrici o la Marca per la prima volta. Manutenzione del veicolo[2] grazie alle apposite notifiche*, storico degli interventi di manutenzione e prenotazione semplificata degli appuntamenti. Vera e propria estensione del cruscotto, l'App mobile my rnlt consente al conducente di restare connesso al veicolo anche da remoto, con una serie di funzioni pensate per l'utilizzo elettrico e la gestione quotidiana. Ad esempio, è possibile: Avviare la pianificazione dei percorsi dei veicoli elettrici con lo smartphone, con invio diretto al veicolo passando da Google Maps per garantire continuità e fluidità tra smartphone e sistema di bordo dell'auto. Seguire in tempo reale lo stato di ricarica e l'autonomia del veicolo. Gestire da remoto la ricarica (avvio immediato o programmazione alle ore desiderate) ed il pre-condizionamento dell'abitacolo. Accedere alle informazioni essenziali del veicolo (status di sincronizzazione, chilometraggio totale e manuale d'uso) ed ai servizi da remoto (localizzazione del veicolo, attivazione di fari ed avvisatore acustico). Individuare le stazioni di ricarica più vicine e gestire le funzioni elettriche avanzate (tra cui V2L e V2G). La nuova App my rnlt sarà progressivamente diffusa nei Paesi europei e successivamente resa disponibile su tutta la gamma di veicoli della Marca. Potrà essere costantemente arricchita da nuove funzioni. Offerta semplificata e arricchita in termini di valore per i clienti Nuova Megane E‑Tech Electric ha un approccio chiaro: intende semplificare le scelte dei clienti arricchendo i contenuti. La gamma si continua a basare su un'architettura chiara e coerente, declinata in due livelli di allestimento complementari: Techno ed Esprit Alpine. La versione Techno, vero e proprio cuore di gamma, offre subito una serie di equipaggiamenti particolarmente completa. Comprende il doppio display openR da 12” con Google integrato, il Route Planner per veicoli elettrici e le dotazioni essenziali per le esigenze elettriche quotidiane come la pompa di calore ed il precondizionamento della batteria. Può anche contare su una motorizzazione da 220 cv, nuovi cerchi da 19” e uno dei bagagliai con il miglior volume della categoria. Posizionato alto di gamma, l'allestimento Esprit Alpine accentua la personalità e la distintività del modello. Si differenzia per il design esterno specifico, con cerchi da 20” di serie ed elementi distintivi, arricchendo al tempo stesso l'esperienza di bordo grazie ai sedili elettrici con funzione massaggio, all'impianto audio premium Harman Kardon ed alla serie completa di ADAS. In sintesi Nuova Renault Mégane E‑Tech Electric continua ad evolvere rafforzando gli elementi chiave che ne hanno decretato il successo: design incisivo, esperienza tecnologica user-friendly e prestazioni elettriche sempre più performanti. Va all'essenziale offrendo un veicolo al tempo stesso più facile da capire, più riccamente equipaggiato ed ottimizzato per l'utilizzo elettrico, pur conservando l'essenza del DNA di Megane: il vero piacere di guida quotidiano. Progettata e prodotta in Francia, nel centro industriale ElectriCity di Douai, rientra a pieno titolo nella strategia elettrica di Renault e si riconferma al suo posto tra i modelli di riferimento del segmento delle compatte elettriche. [2] La manutenzione connessa nell'App my rnlt è disponibile in Francia, Belgio, Italia, Paesi Bassi e Spagna e sarà successivamente e progressivamente estesa ad altri Paesi. Fabrice Cambolive, Chief Growth Officer, CEO della Marca Renault Scheda tecnica Dimensioni e peso Lunghezza: 4.200 mm Larghezza: 1.782 mm Altezza: 1.522 mm Passo: 2.685 mm Sbalzo anteriore: 800 mm Sbalzo posteriore: 715 mm Altezza libera dal suolo: 124 mm a vuoto (105 mm con carico) Volume del bagagliaio: 440 dm3 VDA Volume del bagagliaio sedili posteriori ripiegati: 1.332 litri Raggio alle ginocchia: 209 mm Altezza di carico: 522 mm (soglia del bagagliaio – altezza) Peso: 1.772 kg: massa a vuoto in ordine di marcia Motore e batteria Potenza: 160 kW (220 cv) Coppia: 300 Nm Tipo di batteria: LFP (litio-ferro-fosfati) Capacità utile: 67 kWh Autonomia: fino a 500 km (WLTP) Ricarica: AC 11 kW (AC 22 kW in opzione) e DC 165 kW Prestazioni Velocità massima: 160 km/h Da 0 a 50 km/h: 3,4 sec Da 0 a 100 km/h: 7,6 sec Topic Spy: Renault Megane E-Tech Electric Facelift 2026 (Spy)
  6. Un prototipo della A110 effettuerà un test ufficiale e dei giri di pista a Goodwood il 9 luglio, con Gasly e Colapinto.
  7. Da Autosegredos ecco delle foto spia della GPanda brasiliana (Argo) con componenti definitivi in colorazione "Blu Amalfi". Oltre alle differenze già elencate nei precedenti post, avrà sedili e bracciolo centrale differenti rispetto a quelli presenti qui e sarà il primo modello Fiat prodotto a Betim a offrire sei airbag. Link all'articolo (anche se al momento il sito è irraggiungibile): https://www.autossegredos.com.br/segredos/novo-fiat-argo-t200-mhev-cvt-2027-flagramos-a-versao-topo-de-gama-e-seu-interior/
  8. BMW apre oggi gli ordini della i3 50 xDrive First Edition! Comunicato stampa Via BMW.
  9. CITROËN Berlingo Van First FIAT Professional Doblò EasyPRO OPEL Combo Start PEUGEOT Partner Active Comunicato stampa Via Stellantis Pro One.
  10. My spec: Verde Giada, dettagli esterni Nero Cometa ed interni Cuoio.
  11. CONFIGURABILE: Clicca qui!
  12. nella discussione ha aggiunto Osv in Maserati
    Grecale Trofeo Grecale Folgore Comunicato stampa Via Maserati. Topic Spy: Maserati Grecale M.Y. 2027 (Leak)
  13. nella discussione ha aggiunto Osv in Maserati
    GranTurismo Trofeo GranTurismo Folgore GranCabrio Trofeo GranCabrio Folgore Comunicato stampa Via Maserati. Topic Spy: Maserati GranTurismo & GranCabrio M.Y. 2027 (Leak)
  14. Alla fine sarà lei la nuova Spring! Comunicato stampa Via Dacia.
