BMW M-Power...
BMW's M-Power division is planning a massive onslaught to gain it's performance crown back from it's main rivals. Four new models are planned including a V8 powered M3 (four-door varaint), an M4 (two-door coupe/convertible), & a V10 powered M5 saloon & M6 Coupe.
Under BMW's new badging all two-door variants are to get even numbers & four-door versions will be named with odd numbers. BMW has registered the names for it's sports car expansion, there is also a series of lightweight CSL specials that use Carbon-fibre materials with involvement from it's F1 division. The CSL's not only will have lighter body composits but more powerful engines.
The new M3 & M4 will use a 400Bhp V8 due on sale in 2006 starting at £45,000 at todays prices, also planned is an Estate (Touring) version to take on it's rivals like the Audi S4, Mercedes C32 AMG & forthcoming C55 seen as a large market share for Tourings. The V8 version is likely to be a 4.0 Litre with drive to the rear wheels & update version of the SMG Sequential Manual Gearbox through the traditional 6-Speed manual. Although heavier than the tradition 6-cylinder engine it will be off-set by the lighter hybrid construction on all new 3 & 4-Series.
The new M3/M4 will be based upon the forthcoming 3-Series due out in 2005 codenamed E90.
The new M5 & M6 will feature 5.5 Litre V10s with BMW's third-generation Vanos Varible Valve timing system. Using Aluminium forward of the windscreen contributing to a 50:50 weight distribution. Prices starting at £55,000 for the M5 available in 2005 & £80,000 for the M6. Both developing 500 Bhp with 450Ib ft torque, expect 0-60 Mph in approx. 4.5 secs, weight shouldn't be more than 1756Kg which means a power to weight ratio of approx. 300 Bhp per tonne for the M5. M6 is to take on the mite of Porsche's 911 Carrera, Mercedes SL55 AMG & the new Aston Martin DB8. Sharing modified suspension from the new M5 & using a carbon-fibre roof, boot floor, bulk-head, bonnet & boot lid for the new Super Coupe.
All M-Power models will have re-profiled front & rear bumpers with deep spoilers, large cooling ducts, flared wheel arches, beefed up side sills, deeper rear valance & four exhaust pipes. Also 19" alloys as standard on the M5 & M6.
Also testing is being carried out on a Z4M using the new V8, but is yet to be approved.
Also hot new Golf rival M2 based on the forthcoming 1-Series, with 220 Bhp high-reving 2.2 Litre
Belle....e che motori........
il paraurti anteriore sebbene di tradizione tipica delle serie M mi somiglia la versione estrema di quello della yaris restyling....
scusate la bestemmia...
:cry: per sicurezza controllate..... :oops:
mind the gap
Che dire veramente belle. Ma come farà l'Alfa a controbattere? Purtroppo ho la sensazione che come al solito ci troveremo a rincorrere, noi ancora aspettiamo il V6 o il V8 e questi ti sparano già il V10!!! E poi mi chiedo come sia possibile dover aspettare fino al 2006 per i nuovi Duetto e Brera. :?
Anche Alfa avra' tra poco la sua ipersportiva inizialmente da oltre 450cv.....e in un secondo tempo anche con V12 Ferrari con potenza ben superiore al V10 BMW.......
La 158/GiuliaGTA e 158/GiuliaSportwagonGTA avrano nella versione GTA Autodelta 400cv....
La Brera e Spider V8 e le versioni americane delle GTA avrano un 4.25V8 di origine Ferrari/Maserati da almeno 400cv..........
Mentre non sono improbabili versioni GTAm Autodelta da oltre 450cv........
La grande berlina forse 168 e la sua coupe' derivata(rivale 6)avrano un V10 progettato da Ferrari nel 2007/8 mentre probabile l'uso di motore V12 per la GTA Autodelta......
La 148/Giulietta GTA Autodelta avra' un 3.2V6 aspirato da 280cv.....mentre la versione GTAm Autodelta un 3.6lt da almeno 340cv........
Quindi Alfa non avra' nessun complesso..........
Sì Taurus, questo è vero me lo avevi già detto e io ci credo ciecamente. Il problema è che tu mi dici nel 2006 avrà nel 2007-8 avranno i Krukki invece sono già al V10 dopodomani, chissà cosa tireranno fuori per il 2006-7-8.E' questo che preokkupa, e che alimenta le critiche degli esterofili che dicono che il gruppo Fiat arriva sempre dopo gli altri. :(
Avrà... avranno... avremo... ci sarà... nel 2005... nel 2006...
intanto per il momento non c'è niente di tutto questo!
Velox ha ragione...sì d'accordo, bei programmi...ma intanto tutto ciò adesso non c'è, e ogni modello mancante o segmento non coperto è un regalo alla concorrenza...vedi discorso New Large Fiat/Lancia... :(
ma anche le M3/M4 V8 da 400cv non ci saranno prima del 2006/7 e lw M5/M6 V10 dei 500cv prima del 2004/5...........quindi anche loro avranno... :twisted:.....poi loro per il momento non hanno previsto una supersportiva come la nostra Sportiva..........
