Differenze tecniche tra 2.200 ecotec e 2.2 gdi
da un amico negli states.
il primo specchietto indica le differenze in potenza e consumo tra il 2.200 ecotec II a iniezione indireta, il 1 prototipo dell 2000, la versione definitiva
2.2 ecotecII 2.2 ecotecII GDI (1study) 2.2 ecotecII GDi
stratified homogenous
rated torque 203 210 220
in nm
rated in 108 kw 110kw 114kw
power
fuel consumtion 100% -10% -6%
in MVEG-B test
cycle
mentre il secondo elenca dati sulle parti interne in comune o meno
engine 2.2 ecotecII 2.2 ecotecII GDI
fuel port fuel gasoline direct
system injection pfi injection
displacement 2.198 cc
bore distance 96mm
bore/stroke 86/94mm
conrod 146,5mm 145.5mm
length
stroke/conrod o,294 0,296
length
conrod bearing- 49/20 mm
dia./width
main bearing 56/19.55 mm
dia./width
piston 20mm
pin diameter
piston 272g 320g
mass
valve DOHC w/
roller finger follwer
valve 35.1/30.1 mm
diameter i/a
valve 10.04/10.04 mm
lift i/a
valve openig e/i 235/240 degree ca
cam phasing 103/116 degree ca 107/120 degree ca
e/i
compression 10.0 12.0
ratio
rated torque 203 nm 220 nm
at engine 4000 3800
speed
rated power 108 kw 114 kw
at engine 5600 5600
speed
engine management delphi siemens
system hsf1- 2.2 simtec 81
fuel 91/95/98 roz 95/98 roz
quality
niente variatore di fase.
