Dati vetture wtcc
Technical Specifications BMW 320si WTCC.
trans.giftrans.gifFACTBOXlinie_factbox.gifLength 4,539 mm linie_factbox.gifWidth 1,858 mm linie_factbox.gifHeight approx. 1,350 mm linie_factbox.gifWheelbase 2,760 mm linie_factbox.gifVehicle weight 1,140 kg (with driver) linie_factbox.gifTank capacity approx. 45 litres linie_factbox.gifIn 2007, the BMW 320si WTCC entered the Touring Car World Championship as the defending champion. Like in the year before, the dynamic racing car provided Andy Priaulx of BMW Team UK with a further drivers’ championship title while BMW was once more able to defend the manufacturers championship.
The BMW 320si WTCC was developed by BMW Motorsport in Munich using the same template as the series model of the same name. It took just nine months to create a new car that was competitive right from the start. In the very first WTCC event of the 2006 season in Monza, Andy Priaulx clinched pole position and victory in round one. Ten more triumphs followed over the course of the year.
This car is the youngest offspring of the successful BMW 3 Series that has been celebrating title glory in international touring car racing for several decades. BMW has now won 24 European titles. Every World Championship title to date has gone to Munich.
The 280 bhp BMW 320si WTCC is the racing version of the special model BMW 320si. The motorsport version of the BMW 320si is driven by a powerful 2-litre four-cylinder in-line engine. A race kit can be purchased by BMW customer teams aroudn the globe. The 320si not only competes in the FIA WTCC, but in numerous national championships as well.
BMW Motorsport Director Mario Theissen says, “Touring cars without BMW is unthinkable – and BMW is equally unthinkable without touring cars. This is what made the brand grow, and we will stick to this tradition. Apart from works support we have always been keen to keep racing affordable for our customers and at the same time offer a high-performance package. This tradition is now continued by the racing version of the new BMW 3 Series. I am sure that this model will write further chapters of BMW’s successful history.“
HONDA ACCORD EURO R SUPER 2000Technical information Engine: Front transversal, 4 cylinders in line
Capacity: 1.998cc
Compression ratio / Valve lift: 11 : 1 – 11 mm
Fuel: Electronic fuel injection Intake:Single throttle (diam. 64mm)Data acquisition:Magneti MarelliTraction: Front wheel drive Clutch: Sachs Racing carbon single discs Gearbox:XTRAC 6 speed + reverse, sequential Differential: XTRAC adjustable mechanical limited slip differentialBrakes:Front: Brembo discs, Alcon callipers
Rear : Brembo discs and callipersSuspensions: 3-way adjustable shocks absorbers
Front: double wishbone arms
Rear: multilink Wheels: Aluminium alloy wheels 9 x 17 inches Aerodynamics:Front splitter (80mm from the ground) Adjustable rear spoilerDimensions
Lenght / width / wheelbase (mm): 4665 / 1831 / 2677 Weight (kg): 1.140 (driver included)
ALFA ROMEO 156 SUPER 2000 Technical information Engine: Front transverse, 4 cylinders in line
Capacity: 1.998cc
Power: 275cv at 8.450rpm
Intake: Single throttle (diam. 64mm)
Traction: Front wheel drive Clutch: Carbon double discs (diam. 184mm) Gearbox: 6 gear + reverse, sequential, front wheel drive Differential: N.Technology mechanical limited slip differential Brakes: Front: 330mm ventilated discs, 4-pot calipers
Rear: 278mm discs, 2-pot calipers
Brake bias adjustable on pedal box
Rear brake bias adjustable by driver
Steering: Rack and pinion, with electric pump servo assistance
Front: Double wishbone arms
Rear: MacPherson strut
9 x 17ins
Aerodynamics: Front splitter (80mm from the ground)
Weight:1.140kg (driver included)
Aggiungo le specifiche della Seat Leon turbodiesel
SEAT Leon TDI WTCC Specs
Engine
Type Turbocharged; 4-cylinder in line, transversally installed; distribution: two overhead
Distribution Two overhead camshafts, 16 valves.
Displacement 2.000 cc
Bore x stroke 81x95,5 mm
Maximum power 280 CV a 4000 rpm
Maximum torque 450 Nm a 2500 rpm
Lubrication Wet sump
Particle filter Dow Automotive
Transmission
Traction Front-wheel drive
Gearbox Hewland 6-speed, sequential shift
Clutch Twin-plate
Differential Mechanical limited slip differential
Chassis
Front suspension McPherson strut, coil springs, gas-filled dampers, anti-roll bar
Rear suspension multi-link axel, coil springs, gas-filled dampers, anti-roll bar
Steering Power assisted rack and pinion
Brakes
Type Not-assisted dual circuit system
Front brakes 4-piston calipers, 332 mm steel ventilated discs
Rear brakes 2-piston calipers, 280 mm steel discs
Dimensions
Length 4330 mm
Width 1849 mm
Wheelbase 2600 mm
Minimum weight 1170kg (including driver)
Rims / Tyres
Rims / Tyres 9x17 / Yokohama 240/610 R17
