[Australia] Holden HSV 2008 (Foto Ufficiali)
HSV sezione veicoli speciali ad alte prestazioni . Commodore ultravitaminizzata con propulsore Corvette, sigla GTS-R
  • 3 settimane fa...
To celebrate its 20th anniversary, HSV, Holden’s in-house tuning arm, has rolled out a concept version of its latest E-series model powered by the Corvette ZO6’s LS7 V8 powerplant at this week’s Melbourne Motor Show. Dubbed the ‘HSV W427,’ the four-door muscle sedan is packing a 7.0L V8 engine with a very healthy 500hp (370kW) on tap.
Sarà presentata al Salone di Melbourne...
è arrivata, questi i dati tecnici tratti da motor authority
Powertrain
7.0 Litre, LS7 Engine with HSV specific calibration
o 370kW @ 6500 rpm
o 640Nm @ 5000 rpm
Over radiator style cold air induction system with high flow air filter
Dry sump lubrication system with 2 stage pump
Hand fabricated aluminium oil reservoir, with internal baffles for high G loading
Front mount, 13 row engine oil cooler
Ceramic coated, high flow four into one extractors
High flow catalytic converters and exhaust system (3 into 2 ¾ )
Active bi-modal rear mufflers for exhaust back pressure management to improve noise quality
High strength limited slip differential
New high strength six speed manual gear box (TR6060)
GMPT LS7 Clutch with new actuator and pedal assembly for high clamp loads
Suspension
New springs, 30% stiffer than GTS
Revised ride height 20mm lower than GTS
New stiffer rear suspension bushing
All new MRC calibration
Brakes
New 6 piston front braking system (50% increase in pad area)
Strap drive, 2 piece floating front rotors (380 x 35mm compared to 365 x
32mm one piece on GTS)
High friction pad material
Risposta Holden all'ultima Ford falcon. All'inizio pensavano ad un altro motore e cioè a quello della ZR 1 con compressore oppure al nuovo LS3 da 6,2 litri
